This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Feb 15, 2010, 08:26 AM
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
direct helicopter drive bldc motors
this long lost thread might interest someone, direct helicopter drive motor from 5.25" floppy drives
Direct Drive Main motor for microhelis finally ready!!!
z-matrix is offline Find More Posts by z-matrix
Old Mar 01, 2010, 01:15 AM
Arizona
Joined Apr 2009
Wrong thread
p51p51 is offline Find More Posts by p51p51
Old Apr 06, 2010, 01:15 AM
Joined Mar 2010
how do you extend the shafting of the cd-rom motor? thanks
gregg474 is offline Find More Posts by gregg474
Old Apr 07, 2010, 09:29 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Typically extending the shaft requires replacement. There are many vendors that sell 3mm shafts. However the rails to your CDROM and DVD drives are 3mm hardened steel. They make good replacement shafts.
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 08, 2010, 12:38 AM
VinCopter's Avatar
Singapore
Joined Apr 2005
I was to collect old and non working CDROM drive from my IT department. Almost free replacement.
VinCopter is offline Find More Posts by VinCopter
Old Apr 25, 2010, 11:22 PM
Joined Dec 2009
I got an old LG 52x cd rom n i removed the motor from it..Its now with the circuit board..I don't know how to remove the can n stator..Can any one explain me how to remove those things with some pics? Can i re wind this motor for using in planes? thank u..
xxkrishxx is offline Find More Posts by xxkrishxx
Old Jun 25, 2010, 11:44 AM
Joined Jun 2010
Top edge of every magnet should be flush with the edge of the bell and the bottom edge of the magnet about 1mm above the bottom of the bell (this is the level where GBL can has 3 tiny noches on the side. Make sure these noches are between magnets. This setup guarantees enough airgap between magnets and stator and leaves space for wire between front of the bell and the stator.
free games
vivan12 is offline Find More Posts by vivan12
Old Jul 16, 2010, 02:56 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Rewinding motors...
My brain cant seem to remember how many turns ive put round each of the sections, talk about short term memory loss , so I found this usefull counter..
counter 1.0 at www.dssf.net hit the space bar as you add a turn..simple enough for me...
davereap is offline Find More Posts by davereap
Old Sep 16, 2010, 02:44 AM
doggit's Avatar
northenden, manchester, england
Joined May 2009
i hope i dont sound like a complete idiot, but " what is meant by a short" i have been looking at rewinding my BW motors, and a couple of other motors, and i have watched a you tube vid, and after each faze you check for shorts, but thats the bit i dont get, what causes this short, is it when the wire touched the outside of the stator, i hope someone can explain this for me, as i dont want to fry my rewinds
carl
doggit is offline Find More Posts by doggit
Old Dec 20, 2010, 10:07 AM
Joined May 2007
What is a short?
carl
I only just joined, so sorry for the late reply. A "short" or "short circuit" is when any two conductors that need to be insulated from each other are in contact and conduct electricity.
In our case, if the corner of a stasor cuts through the insulation on a copper winding, that has the potential to connect it to a later winding that also gets nicked through the iron of the stasor.
Derek Hannan is offline Find More Posts by Derek Hannan
Old Dec 20, 2010, 04:12 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Carl,
As an example, and so you can see how your meter handles and displays it, if you put the meter on the Rx1 or lowest resistance scale and touch the tips of the test leads or probes together you'll get a displayed value of 0.0 Ohms or something close to it like 0.01 or 0.02 Ohms or so.
If you hold the probes in contact for a few seconds, the reading may drop to 0.0 Ohms as the meter stabilizes. And that is a dead short between the probes, no resistance.
Some meters will display 0.0 when the probes are not in contact because there is no resistance present, others (my Fluke for example) will display "O.L." to indicate an "open line" when you are in the Rx1 or Check for Shorts mode.
When you put one probe on a stator and the other probe on a wire end there may be small amounts of paint or insulation at the points where the probes make contact and those will change the readings you see on the meter as compared to the reading you saw with the probes shorted together. And things like the pressure you use and how well you make contact will change the readings.
If basically comes down to that the meter is just trying to do the best it can at showing you what the actual resistance, if any, is between the two probes.
So when you have a short between the winding and the stator it might have some small amount of resistance that is caused by the "quality" of the contact at the probe and the point where the short is.
If I check for shorts and see a low resistance like 0.4 or 0.6 Ohms or so and if the number is dancing up and down a little, it still a short. The difference in the numbers is the "quality" of the contact points.
I have meter probes with interchangeable tips and I can change from needle point probes to clip on alligator clip probes. So when I start a winding I scrape the start end of the wire so I can clip one alligator clip on there.
As I complete the turns on each stator arm, I clip on to the scraped and can just touch the tip of the other probe to a bare spot on the stator (usually the ends of the hammer heads are bare of insulation and that is a good spot) and check for shorts before I move on.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 13, 2011, 03:18 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Lots of goodies/tools/calculators for diy motor building/winding:
http://www.flugzeugseite.de.tf/
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 16, 2011, 12:16 PM
Joined Feb 2001
Try the diy electronics subforum Julian, plenty of ESC discussion there. I try to keep this diy motor tips & tricks thread lean and mean, every now and then I comb through it and remove posts. I will remove your post to, after a while.
Compilation of sensored and sensorless diy brushless controller designs:
http://www.rcgroups.com/forums/showthread.php?t=140454
Old Oct 17, 2011, 10:48 AM
Joined Oct 2011
There is the possibility to move the post?
iulian207 is offline Find More Posts by iulian207
cd-rom motor conversion homepages/tricks/sources/discussions Ron van Sommeren Parkflyers 5 May 21, 2008 05:50 PM
32X CD-Rom Drives--FOR SALE kist2001 Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2002 04:33 PM
Looking for dead CD ROM (36x or faster) Jim McPherson Aircraft - Electric - Airplanes (FS/W) 13 Apr 12, 2002 10:47 PM
Paul Matt on CD-ROM? tiggs Scale Electric Planes 2 Mar 26, 2002 08:07 PM
F/S Realflight Sim.. CD-Rom jfruge Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2001 08:17 AM
