This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Apr 30, 2008, 12:49 PM
prinz is offline
Find More Posts by prinz
Joined Nov 2006
edited
prinz is offline Find More Posts by prinz
Old Jun 05, 2008, 08:52 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
'Dry testing' brushless motors (in- and outrunner both)
http://www.wattflyer.com/forums/showthread.php?t=35216
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 02, 2008, 11:58 AM
Joined Feb 2001
Making stator isolation plates, video and pictures:
http://www.rcgroups.com/forums/showt...6#post10651516
Old Nov 13, 2008, 03:47 PM
simonjardine is offline
Find More Posts by simonjardine
MultiRotor Jedi
simonjardine's Avatar
Australia
Joined Apr 2008
Kv
Is it possible to have a motor which weighs around 70 grams, has a low KV rating of 500? I cannot find anything out on the internet. Is it possible to build a motor like this? Weight can be 70 - 100 grams.
Power 150-220 watts. Most importantly it has to be 400 - 500kv.
Am i dreaming?
Simon
simonjardine is offline Find More Posts by simonjardine
Old Nov 13, 2008, 10:37 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Am i dreaming?
Simon
http://www.rcgroups.com/forums/showthread.php?t=777998
This motor could take a few more turns of 22AWG and give you 500kv. Timocharis wound 18T of 22AWG and has pics that shows plenty of room for more winds.
SteveC68 is offline Find More Posts by SteveC68
Old Apr 18, 2009, 06:40 AM View Post
criminallawyer
A moderator felt this post violated the following rule: Excessive Advertising (Spam). It is temporarily hidden while criminallawyer edits it. Show it to me anyway.
Old Apr 19, 2009, 10:34 AM
unattainium is offline
Find More Posts by unattainium
Chicago
Joined Jan 2009
Originally Posted by olmod
You can line the existing bell with old transformer ( i ) lamination iron..a guilloutine helps in cutting the strip width to the depth of bell required, cut longer than needed, hand roll around something wich is about 4 mm smaller to allow for spring back, then start trimming the ends off as they will have a flat on them,when you get close to the inner diameter of your bell,lay on a flat metal surface,take fine flat file one with a smooth edge to go down on the metal surface,squeeze the ring together so you file both ends together on the draw back stroke.by trying you can get a push fit and a perfect butt join.I use a little loc tite black max to glue them in and spin them with a drill in a toilet roll tube to even out and get rid of excess loc tite. I place the first magnet over the but join, when finished placing the magnets,i place a single drop on each end of magnet and use the same spin technique.when fitting stator i use the black marker to show witness to any rubbing and grind accordingly. so i might not be able to use max' thickness magnets but the lamination iron flux ring helps too.
You don't need to use the lamination iron, which is high silicon and hard o handle. Any iron or steel will work well, even old tin cans. You could machine an inner ring from free machining steel like 12L14.
I make the flux rin a little smaller and mill or broach flats into it to hold each magnet and give the right air gap. This gives an optimal magnetic circuit by eliminating the air gap where the magnet meets the flux ring and also holds the magnets in position during assembly.
unattainium is offline Find More Posts by unattainium
Old Apr 19, 2009, 10:43 AM
Chicago
Joined Jan 2009
Originally Posted by Prop-er
I'm using a 25A car fuse between ESC and battery. If the current rises too much, the fuse blows, saving my ESC and battery. Easy and cheap.
Prop-er
I use a Variac transformer for the initial power up of new systems. The voltage can be lowered and the inherent current limiting helps keep the smoke inside electronic parts. I bought an old General Radio Variac on Ebay.
A Variac is an adjustable autotransformer with 110 volts AC in and output adjusted to be lower or higher than 110 AC.
Old Jun 18, 2009, 10:26 PM View Post
divorce certif
A moderator felt this post violated the following rule: Excessive Advertising (Spam). It is temporarily hidden while divorce certif edits it. Show it to me anyway.
Old Dec 07, 2009, 12:32 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
have not seen this tip in here yet, so I figured I'd add it:
http://www.wattflyer.com/forums/showthread.php?t=52081
creapyd is offline Find More Posts by creapyd
Old Jan 05, 2010, 07:09 AM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
Am i dreaming?
Simon
take a look at your old thrown out computer in the garage
ever wondered about what was spinning your floppy disc?
its a dream come true
take apart, bear it up, rewind, remagnet, there you go
z-matrix is offline Find More Posts by z-matrix
Old Jan 05, 2010, 08:24 AM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I have made several stylus winders the most effective has a ceramic bead in the tip all others including teflon dont last long before they wear/cut through to the holder.
I still use a fold of thin felt around the wire held in the tips of locking forcepts wich act as a resistive clutch and if i'm interupted i just let them hang with no slackening of winds.
olmod is online now Find More Posts by olmod
Old Feb 15, 2010, 09:26 AM
z-matrix is offline
z-matrix's Avatar
Joined Dec 2005
direct helicopter drive bldc motors
this long lost thread might interest someone, direct helicopter drive motor from 5.25" floppy drives
Direct Drive Main motor for microhelis finally ready!!!
Old Mar 01, 2010, 02:15 AM
p51p51 is offline
Find More Posts by p51p51
Arizona
Joined Apr 2009
Wrong thread
p51p51 is offline Find More Posts by p51p51
cd-rom motor conversion homepages/tricks/sources/discussions Ron van Sommeren Parkflyers 5 May 21, 2008 06:50 PM
32X CD-Rom Drives--FOR SALE kist2001 Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2002 05:33 PM
Looking for dead CD ROM (36x or faster) Jim McPherson Aircraft - Electric - Airplanes (FS/W) 13 Apr 12, 2002 11:47 PM
Paul Matt on CD-ROM? tiggs Scale Kit/Scratch Built 2 Mar 26, 2002 09:07 PM
F/S Realflight Sim.. CD-Rom jfruge Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2001 09:17 AM
