BBCC6- Rivets RC --> CL Conversion
Construction of the RIVETS:
Thursday, April 16, 2015 I came into the workshop and set in to building a 1/2A plane called the RIVETS. The plans I downloaded from the OuterZone collection were for the .02 Rivets designed by Owen Kampen back in 1967. The plans were for a 26" wingspan radio controlled model. The rules for the Cox Profile Scale Contest requires that the plane be control line with a profile fuselage and a minimum 12” fuselage and 15” wingspan. I opted to make the fuselage from ¼” sheet balsa, the wing was cut from a piece of Sig airfoil shaped balsa and the horizontal and vertical stabilizers were made from 3/32” balsa. The horizontal stab was outlined with four pieces of 3/32” x 1/8” balsa. Unfortunately I forgot to take a step by step progression of photos detailing the assembly of the project, from the making of the templates to the cutting out of the wood, so all I have is just a series of photos taken after I had essentially completed the assembly. It was at this point, where I remembered to begin the documentation, when it was ready for the mounting of the bellcrank and elevator controls. I tried to imagine what it would look like with a Tee Dee .051 and it really looked like it would be be too large for the plane not to mention it was so nose heavy it wouldn’t set up on the landing gear. So for the heck of it I used a dab of thick CA on one of the mounting ears of my Cox .020 and it looked just right. Oh well! As I mentioned, the plans for this plane are actually for a much larger full body R/C model. Friday, April 17, 2015 I completed the mounting of the bellcrank, elevator and pushrod using a Brodak 1/2A bellcrank, p/n BB-390, I set up the controls. The lead outs were made of .0.015” solid wire and the pushrod was made from a piece of .054” music wire. Now, I had to order an assortment of small Dubro wheels to get some suitable wheels. From the looks of it, the Cox .020 seems to be the better match because of the ground clearance for the propeller. With either engine mounted, it was definitely tail heavy and will require some tail weight just to sit on the wheels. By 1745 the RIVETS was ready for finishing. Sunday, April 19, 2015 I added some ¼” triangle stock to the underside of the horizontal stab of the RIVETS to provide a modicum of reinforcement. Once I was satisfied with the finished sanding and shaping, it was ready for the application of its finish. Wednesday, April 22, 2015 I applied a coat of Coverite to both of the RIVETS it up to dry. Then I spent a couple of hours making up a set of 35 foot, .008” steel flying lines for my 1/2A’s and when I finished, I did a Google search for what I thought would be a kool finish and began covering the RIVETS using Monokote. Thursday, April 23, 2015 I resumed work covering the RIVETS. I could not complete the covering scheme as planned because I ran out of yellow Monokote for the bottom so I had to settle for covering the bottom of the wing and the horizontal stab in red. I think it looks all right! By 1540 I completed the covering process and was ready to apply the trim and mount the engine. Unfortunately, the wheels I ordered had not yet arrived. I worked until 1830 or so to complete the trim for the RIVETS. I hammered a 1/4 ounce fishing sinker flat to about 1/16" thick such that I was able to use the Dremel router bit to inset it flush into the outboard wing; then it was covered with with a piece of Monokote. Next, I mounted the Cox 020 engine to document the construction finish but now I have to wait for the wheels. I think it looks pretty good. Tuesday, April 28, 2015 I received my order from Tower Hobby with the wheels I needed for the RIVETS and some APC 6” propellers. I chose to mount the Dubro MW100 foam wheels, since they weighed only 1.1 grams each, on the RIVETS and it really looks nice now. So my final numbers for the Rivets are: Cox 020 engine with a Thimble Drone 4.5 x 2P propeller, 15.75” wingspan, 13.25 fuselage length, 15.125” L.O.A. with a final ready to fly weight of 3.3 ounces. Now, to set a date for a documented flight!! |
Thanks for the kind words ! Yeah, you're probably right about the power / performance but I'm hoping for the best . I do know that the build was enjoyable and it turned out pleasing to the sight so to speak. If I do end up needing / wanting better performance I'm pretty sure I'll have to build another slightly larger variant . Well until I get a chance to put'er in the air .... !!
You are so very welcome! Put this in the CL forum, too! I'm sure everyone there would like to see it and hear about how it flies. My very first 1/2A profile was a Cassutt. I finished it very nice and it ended up being a dog due to it's weight. I go easy on the finish, now, and they fly pretty good.
Well just a quick and brief update, yesterday morning I decided to give the Rivets a try. I fueled that little Cox .020 and carefully adjusted my panel mounted glow driver and after a handful of flips and priming it fired up and once the needle was adjusted it ran wonderfully . I was so pleased. Well, I opted to let it cool a bit, refueled and figured I'd give it one more check run before hooking up the lines . Wouldn't you know it .... it wouldn't fire !! I did some checking to find that the little glow head had burned out and I didn't have a replacement !! Oh was that frustrating but I s'pose there's always another day .... once I find a replacement glow head !
Jim |
Reason: typo
Possibly someone is machining a substitute? Not much of a market these days though. Google perhaps? |
Perhaps..
Not like there is an increasing supply of 020's, or Any cox's for that matter. Besides Most of the Kids who bought 'em, are now well into in their 60's... arguably 70's TD020's Are 40 watters on 30% nitro. More Noise than go. PeeWee's are like ~25 watts Not much of a business plan in supplying a few dozen Free Flighters. IMO. Besides, the question was on the availability of an adaptor head.. Which even IF one could screw in a Nelson/ Turbo or Glo Bee type plug, it would have even poorer performances because of the unavoidable increased Comb Chamber volume. |
Thanks Bare!! Thanks Andy!!
OKAY!! OKAY!! OKAY!! I DID IT!! With the help of my loving wife and a couple of new .020 glow heads form Cox Int'l, the Rivets finally .... finally got into the air today at 1642 (4:42 p.m. 'fer y'all civilians) I used some of the last of my Sig 25% and oh man .... what a wonderful sound to hear a full tank run!! I just had to do it a second time just to convince myself that it was really happening. A couple of minutes later it was off to the tarmac where I attached the little thing to my inverted stooge.
I worked with my wife to get her cell phone camera setup because for some reason my Kodak Easyshare DX6340 just wouldn't stay powered up. Nevertheless, when she was ready I handed her the stooge release line, fired up the Rivets and ran out to the grab the handle. This process had to be repeated a couple of times because the needle setting seemed to vary significantly and intermittently thus reducing the takeoff power . However, the third try was a charm ! In about 8 feet she lifted off quite smartly. What a joy to see it in the air!! Then ... in a flash .... in the twinkling of an eye .... it was heading into an uncommanded wing over!! Just then, I saw the 35' of .008"steel cables dangling with the little bird heading towards me at full power !! I ran backwards then tried to run to an upwind position and get the lines tight but to no avail ! The Rivets was down (thank goodness for thick grass)!! A sense of doom and horror gripped my mind, my heart pounded, my eyes began to cloud up!! I went over to see my little gem, expecting to see the worse but to my surprise and amazement, there was no damage .... other than to my pride Well, I gently picked the precious little thing up, and carried it back to the pit area where I cleaned her up and made a joyful noise!! THE RIVETS FLEW!! I/We made the deadline and lived to fly another day!! Next time, I'll be using some shorter lighter lines. (p.s.: I know, I know !! My wife thinks there's something wrong with me too ) |
