Old Jun 13, 2004, 05:07 AM
yclui is offline
Find More Posts by yclui
Joined May 2002
Wing repair
yclui is offline Find More Posts by yclui
Old Jun 13, 2004, 09:15 AM
trippme is offline
Find More Posts by trippme
Laguna Beach, CA
Joined Mar 2003
Impressive tutorial!
trippme is offline Find More Posts by trippme
Old Jun 13, 2004, 09:53 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Pretty slick repair job; I bet you'll be happy to get the MiraJ back up.
Good luck with whats left.
Target
target is offline Find More Posts by target
Old Jun 13, 2004, 11:01 AM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
Pretty impressive! That kind of damange would have had me looking for a new wing.
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Jun 13, 2004, 11:05 AM
dutchydawg1 is offline
Find More Posts by dutchydawg1
dutchydawg1's Avatar
Nor. Cal.
Joined Jan 2004
unbelievable !!!...... let me guess, your either a "plastic surgeon" or a "rocket scientist" ? increadable repair !!!
dutchydawg1 is offline Find More Posts by dutchydawg1
Old Jun 13, 2004, 04:02 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
hi, yclui-
Where did you get the thermal switch that you are using to turn on and off your heat source, and how much did it cost you?
Right now, I use an electric heater with it's own thermostat, but it doesn't work as reliably as I would like.
Thanks in advance, Target
Old Jun 13, 2004, 07:21 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Yep. 99.9 percent of the modelers I know would have put that wing in the trash and bought a new one. I would have never even considered trying to repair it.
You did an excellent job. There is more engineering and high tech techniques in that repair than there is in any of the planes I've built! I build my planes by sheeting foam cores with wood and contact cement. Then I glue the wing and balsa tail to a fiberglass fuse. Paint it, hook up the radio. Done. I love to see all that carbon and mylars and vaccuum bagging and hot boxing stuff being done. Very cool.
Thanks for posting such a great photo series!
Brian Courtice is offline Find More Posts by Brian Courtice
Old Jun 13, 2004, 07:46 PM
Pegasus is offline
Find More Posts by Pegasus
Pegasus's Avatar
Austin, Tx
Joined Nov 2003
What is the "hot boxing" for ?
Incredible workmanship!!
Steven
Pegasus is offline Find More Posts by Pegasus
Old Jun 13, 2004, 08:53 PM
trippme is offline
Laguna Beach, CA
Joined Mar 2003
Cures the epoxy harder when you heat cure it at bout 120 degrees F
Old Jun 13, 2004, 11:47 PM
Cody WIlson is offline
Find More Posts by Cody WIlson
plane obsessed
Cody WIlson's Avatar
Denver, CO.
Joined Nov 2003
I Can Feel My Head Expanding........
Cody WIlson is offline Find More Posts by Cody WIlson
Old Jun 13, 2004, 11:53 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Wow!
Truly amazing.
InTheLift is offline Find More Posts by InTheLift
Old Jun 13, 2004, 11:55 PM
legliderman is offline
Find More Posts by legliderman
All work and no play
legliderman's Avatar
Lucas, KS
Joined Apr 2003
WOW!! Doctor YCLIU, your needed in the OR!
legliderman is offline Find More Posts by legliderman
Old Jun 14, 2004, 10:40 AM
yclui is offline
Joined May 2002
Guys,
Thanks for the compliments. Just before losing it’s wing, the Miraj was racing with a Nemesis over the slope and the two planes collided almost head on in the air. The first picture is the re-construction of that moment. Much to our surprise, the damage received by the Nemesis was far less sever. That made us wonder whether carbon is really tougher than glass.
This is in fact my first vacuum bagging “project”. I have always wanted to give vacuum bagging a try but making a wing from scratch is kind of too challenging for me so I decided to experiment with my friend’s broken wing first. Most of the techniques shown in the pictures were learned from Phil Barn’s excellent vacuum bagging video http://www.paonline.com/hayman/PAGE2.htm which I highly recommend to those who are interested in this special fabrication process .
Hi Target,
I got that thermal switch from an electrical supply store. My original plan was to use a thermostat for water heater but the store keeper suggested that I should use an electronic thermal switch as it is more sensitive. It has cost me about US$30.
Cheers,
Y C Lui
Old Jun 14, 2004, 05:38 PM
It could happen...
InTheLift's Avatar
Joined Jan 2004
WHAT?!? Surely you jest!?!!?!
Old Jun 16, 2004, 09:41 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
yclui,
I kinda agree with glenn(InTheLift), about the only thing you need to make your own wings is a setup to cut the cores, and you'll be there. I encourage you to do this.
Thank you for the info about the thermal sensor, I'll look into it.
Good luck(on making your own wings),
Target
Bandit wing repair (for tic's future reference..) tim hooper Electric Sailplanes 7 Jul 08, 2002 04:45 PM
Tipsy Wing Repair Help! SCOTT LINDSAY Foamies (Kits) 3 Jun 14, 2002 02:00 PM
Zagi wing repair? Nobody-Orti Foamies (Kits) 2 Jun 13, 2002 10:03 PM
Question GWS Cub wing repair Dan Reid Parkflyers 11 Dec 30, 2001 04:37 AM
GWS wing repair? estill Parkflyers 7 Dec 15, 2001 03:43 PM
