Old Jun 14, 2004, 07:27 AM
J.E. Johnson is offline
Find More Posts by J.E. Johnson
Newcastle
Joined Oct 2003
very nice! Where did the c of g end up on that?
J.E. Johnson is offline Find More Posts by J.E. Johnson
Old Jun 14, 2004, 10:38 AM
blueman is offline
Find More Posts by blueman
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
cg
Dammit- the cg was found with the "half span, 25-30% of the chord" rule. that gave me a good starting point. As of this moment, I haven't had a chance to actually measure it.
Robb
blueman is offline Find More Posts by blueman
Old Jun 14, 2004, 12:26 PM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Bits and pieces
Here's another small chunk of video, sorry for the bits and pieces. I'm going to piece the bits together tonight into a full length feature.
http://rcgroups.com/gallery/showphoto.php?photo=8487
Old Jun 14, 2004, 12:40 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
OK, another question
How is the wing constructed ? Is it single or double ply FFF ? I know on some of your other designs you've done a single ply and then put a little roll on the leading edge. How 'bout this one ?
Thanks !
Paul
pcaffeldt is offline Find More Posts by pcaffeldt
Old Jun 14, 2004, 12:54 PM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Paul- This wing is just like all my other wings. I start out with a flat sheet of foam and peel the paper off the side with the writing on it to give me a nice blue outer surface with skin intact to give it strength. This particular wing started out as a 11x22" sheet, then I mark the upper center of the long side. Then from the top center mark, draw a straight line down to the lower opposite corner. This is now the folding line. I don't score the foam before folding, it seems to be stronger that way. Before folding, I put a strip of packing tape on the opposite side that still has the skin along the fold line. This keeps the skin from splitting when I fold it. The two top corners bend down to meet at the center and I lay a couple of strips of tape across them. Then I pin the trailing edge together about every 3" to hold it together and squirt hot glue into the spaces in between the tape and squeeze it together. Sometimes there's a gap in the center if I don't fold it just right, Then I just fit a foam spacer in between the two. as long as there's a tight fit, the wing will be very stiff with no need for a spar. The biggest wing I have with this construction and no spar is about 42" wingspan. It is still very stiff. this folding gives you a more symmetrical than semi-symmetrical airfoil, depending on how you fold it. gotta go back to work now.
Robb
Old Jun 14, 2004, 01:16 PM
Arizona Rim Country
Joined Nov 2001
Thanks a Ton, Robb !
A friend of mine and I are working on a Delta type wing, too, at this thread:
http://www.rcgroups.com/forums/showt...99#post2274899
The first one we folded under about 3 inches of leading edge similar to what you do, but we didn't put in the spacer you've mentioned.
The second one we made a " Delta-ized" type Zagnutz.
Both are working well, but if they each fly about the same no point in spending time working in the airfoil.
I appreciate you giving us the details on your wing construction. I'll build #3 Delta using your method. We'll scale them all to the same wing area and see how they compare.
Thanks Again !
Paul
Old Jun 14, 2004, 05:47 PM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
anytime
Paul- Glad I could help with your wing building. So far this is the best method I've found for building wings. You can make a small or large wing with an airfoil to increase lifting efficiency, and your making the wing without making any cuts in the foam. Very strong, the wing on my Insulator feels like it has three spars in it.
Old Jun 15, 2004, 06:58 AM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
video woes
Okay, I pieced the video together and it ended up being a 19 MB zipped file. A little too big for the Gallery. Any Ideas on where I can Upload it?
Robb
Old Jun 15, 2004, 07:09 AM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Do you have plans available?
Bill Bergman is offline Find More Posts by Bill Bergman
Old Jun 15, 2004, 07:12 AM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Nope
Bill- Sorry, no plans as of now. possibly in the future. If that happens, I'll be sure to post them here. Thanks for looking.
Robb
Old Jun 15, 2004, 07:16 AM
Houston, Tx.
Joined Jan 2003
Will it fly slow or does it fly well only fast?
Old Jun 15, 2004, 07:27 AM
rcnutt is offline
Find More Posts by rcnutt
Centerville, In. USA
Joined Jul 2001
I have a couple of questions, if you don't mind. What prop and battery did you use. Also is the wing a single layer of fan fold? Did you use a GoBrushless kit? If so did you use the standard bearing sleeve or make your own with the high speed bearings? RCNutt
rcnutt is offline Find More Posts by rcnutt
Old Jun 15, 2004, 12:39 PM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Bill- It has a very wide speed range, it will cruise around pretty slowly, considering the type of plane it is.
RCNutt- the battery is a Apogee 830 2 cell. I sure am itching to try a three cell, though. Prop is a 3030 GWS direct drive prop drilled out to 3mm to press onto the motor shaft. and the motor was built by myself from a dead CD drive. I studied up on all the hundreds of CDrom motor threads, man there's alot of them! The motor has an oddball size bushing, 3x5mm, so I can't find a bearing that'll fit. The wing contruction is explained in detail on this very thread, post 20. Thanks for looking.
Old Jun 15, 2004, 01:00 PM
Houston, Tx.
Joined Jan 2003
blueman, I sent you an email.
Old Jun 16, 2004, 05:24 AM
hummingbird111 is offline
Find More Posts by hummingbird111
what wing man??
hummingbird111's Avatar
Nashville Tennessee
Joined Jul 2003
is that a car crash sound i heard in the background audio,,,in the video??
hummingbird111 is offline Find More Posts by hummingbird111
Pushing the limits of FFF - Part 2 wrenwright Foamies (Scratchbuilt) 191 Feb 04, 2012 01:04 PM
Help! Zagi XS Pro Kit -- I Need Help Pushing The Limits Plat3au Power Systems 1 Feb 14, 2007 03:19 PM
Discussion Charging - Pushing the limits of 1C flying evader Batteries and Chargers 5 Aug 06, 2006 10:53 AM
Pushing the limits on 1406 2y? Steven D Electric Plane Talk 2 Jul 01, 2001 05:53 PM
