Old Jun 12, 2004, 10:28 PM
paul747 is offline
Find More Posts by paul747
Joined Jun 2004
foam safe glue?
anyone know of a good glue that is foam safe and dries fast?and u can buy at any store ,walmart places like that?
paul747 is offline Find More Posts by paul747
Old Jun 12, 2004, 11:18 PM
Chris7 is offline
Find More Posts by Chris7
Class of '05
Chris7's Avatar
QLD Australia
Joined Jan 2004
5 minute epoxy is good, dries fast I'm not sure if you could get it at a walmart as I don't know what theyre like. Epoxy can add a bit of weight, so be easy with it.
Chris
Chris7 is offline Find More Posts by Chris7
Old Jun 12, 2004, 11:52 PM
Steve Guinn is offline
Find More Posts by Steve Guinn
Steve Guinn's Avatar
Country Rds.
Joined Sep 2003
Hmmmm....no Wal-Marts down under?
Must be paradise.
Are your immigration laws still so strict?
Steve Guinn is offline Find More Posts by Steve Guinn
Old Jun 13, 2004, 12:03 AM
Country Rds.
Joined Sep 2003
Oh....almost forgot.
Polyurethane glue works great. Elmers Pro-Bond or Ultimate glue can be found at Wal-Mart.
Gorilla glue is another poly glue, but needlessly more expensive.
Old Jun 13, 2004, 12:10 AM
Country Rds.
Joined Sep 2003
Oops...not real fast.
Old Jun 13, 2004, 10:59 AM
Chris7 is offline
Class of '05
Chris7's Avatar
QLD Australia
Joined Jan 2004
Steve, yes it is paradise.
I'm not too sure on what the immigration laws are like at the moment.
Chris
Old Jun 13, 2004, 12:33 PM
Country Rds.
Joined Sep 2003
I visited Perth when I was in the Navy. Lovely time, lovely city.
Old Jun 13, 2004, 05:46 PM
paul747 is offline
Joined Jun 2004
Is J-B KWIK WELD a good epoxy?
Old Jun 13, 2004, 05:53 PM
DoctorFive is offline
Find More Posts by DoctorFive
Joined Jun 2004
Remember that not all brands of adhesive are the same. I have found that some 5 minute epoxies harden slowly starting at 5 minutes while others (like Devcon) harden much faster. The adhesiveness and flexability after hardening also differs. Once you find an adhesive that suites your needs, stick with it. Also, it is well worth the effort and expense to have some foam safe CA handy for those quick fixes.
Jerry
DoctorFive is offline Find More Posts by DoctorFive
Old Jun 13, 2004, 09:39 PM
ronmar1 is offline
Find More Posts by ronmar1
FREEDOM IS NOT FREE!!
ronmar1's Avatar
Knoxville Tyson, Tennesse, United States
Joined Feb 2004
JB weld has a metalic base that makes it heavy. It works great for metal parts though. I used it to repair my SS fuse.
Ron
ronmar1 is offline Find More Posts by ronmar1
Old Jun 13, 2004, 09:55 PM
defranci is offline
Find More Posts by defranci
Central Ohio
Joined Feb 2003
If you check the Foamy Forum, you'll find that many people over there are building Fan Fold and Depron planes using nothing but a Hot Glue Gun. You got 20 seconds to get things aligned before it sets up (you said fast).
The guys in Parkflyers lean toward the Polyurethane glues when they have the time (slow setting up, but lighter and stronger than Epoxy). The Slope guys are mainly using Goop, Shoe & Marine Goo on their EPP Slopers (Don't use this stuff on other foams).
defranci is offline Find More Posts by defranci
Old Jun 14, 2004, 10:33 PM
paul747 is offline
Joined Jun 2004
I used hot glue and it melts the foam
Old Jun 14, 2004, 11:23 PM
ronmar1 is offline
ronmar1's Avatar
Joined Feb 2004
Use a low temperature glue gun and glue. You can buy Low, Medium, and Hot
glue guns and glue sticks at Wally World (Walmart) and most craft stores. The low temperature glue gun won't heat the glue enough to melt the foam.
Ron
Old Jun 15, 2004, 07:18 PM
defranci is offline
Central Ohio
Joined Feb 2003
My dual heat gun lists the high temp as 330 deg F which will melt most foam. The low temp is 220 which is well below the melting point of most foams. By the way, Wally World has a cordless dual heat gun for 10 bucks that is great for field repairs.
Old Jun 15, 2004, 07:42 PM
paul747 is offline
Joined Jun 2004
thanks i will get one
Question About foam safe glue item Magrat HobbyKing 11 Jun 01, 2007 09:00 AM
New Product New Foam Safe Glue! racer78bu Foamies (Scratchbuilt) 7 Sep 19, 2006 05:52 PM
Foam Safe Glue cruisefor2 Foamies (Kits) 8 Oct 17, 2005 07:57 PM
Where to find a value on Foam Safe Glue -=SLaPPiE=- Foamies (Kits) 22 Feb 13, 2005 11:36 AM
Foam Safe Glue SACS The Builders Workshop 5 Sep 09, 2004 10:29 AM
