Old Jan 14, 2002, 09:54 AM
Ron D is offline
Find More Posts by Ron D
Harrisburg, PA - USA
Joined May 2001
Wattage WindCruiser Mods-Now it flies!
I bought the Wattage WindCruiser realizing that it would probably fly much the same as the Firebird XL (both 2 channel), but because it wasn't a pusher, I would probably break more props. I was right on one count and wrong on the other.
It doesn't fly anywhere near as well as the XL setup stock. It won't climb worth a damn, which I attributed to the "cheapo" prop, and it has an annoying tendancy to porpoise (a problem with no elevator). I was, however, right about the prop. I tried two landings and broke two props. Without an elevator to flair the plane, the props are going to suffer.
So - I went to work. I removed the receiver and the servo and installed a Hitec feather receiver, and 2 Hitec HS 55 servos. Both were an easy fit since the WindCruiser is ready to accept two servos and a feather receiver. My Hitec focus III TX has a mixer - so - after hooking up the two V-tail flaps I was almost ready. I used the Firebird XL battery pack - 6 cell, 900 mah NiMh. I installed a Graupner 6x3 folder on the nose, a 3/16th" shim under the trailing wing edge to eliminate the porpoising - and now I was ready.
My first flight was more than I had hoped for! Wind was about 5 mph. The plane climbed steadily with authority to several hundred feet. I throttled back and flew mostly at 3/4 to 1/2 throttle for 18 minutes. The landing was perfect - the flair was what I needed to save the prop.
It ain't a Tipsy, but it really did fly almost as well - a bit faster than the Tipsy, but stable and responsive. With the nylon fuselage and tough, skin covered foam wings and tail, it will take more abuse than the Tipsy. I expect to fly this plane a good bit.
Ron D is offline Find More Posts by Ron D
Old Mar 20, 2002, 08:30 PM
birdman is offline
Find More Posts by birdman
Joined Mar 2002
WIND CRUISER
Wow !!!. It sounds like you did alot of workto that plane .Then again ,I am just a nubee.
birdman is offline Find More Posts by birdman
Old Mar 22, 2002, 03:04 PM
ToddNicholson is offline
Find More Posts by ToddNicholson
ToddNicholson's Avatar
Anacortes, Wa. USA
Joined Aug 2000
I flew one for awhile and I thought it flew great. I landed on grass and never had a problem breaking props. It would climb nicely, and was pretty fast as well.
Todd
ToddNicholson is offline Find More Posts by ToddNicholson
Moller Skycar now flies! How about a model of it? e-sailpilot86 Electric Plane Talk 42 Aug 01, 2006 08:17 PM
wattage sukhoi SU-31 flies barn buster 50 Foamies (Kits) 4 May 15, 2002 09:12 AM
wattage sukhoi mods?? buzzsaw 46 Parkflyers 7 May 06, 2002 09:27 AM
Wattage Hawk mods Marksl Foamies (Kits) 7 Nov 29, 2001 07:39 AM
Wattage Hawk mods/ideas go here! pullin-gs Foamies (Kits) 22 Jul 06, 2001 07:24 AM
