Old Jun 09, 2004, 10:05 PM
rickc is offline
Find More Posts by rickc
rickc's Avatar
United States, IL, East Peoria
Joined Jun 2002
Outlet for a 9 tooth 48 pitch 2.3 mm pinion for a Shogun
Now that I have my B20-15L on its way now the next item I need to run down is a pinion for it. I've done some searching and there is hours of information but most that I have seen on the Zoom pinions is the for the HiMaxx and a 2 mm bore. Can someone point me in the right direction to get a 9 tooth pinion 2.3 mm in the states if possible to save on shipping or does anyone have an extra they could sell?
Thanks.....
Rick
rickc is offline Find More Posts by rickc
Old Jun 09, 2004, 10:30 PM
14U2NV is offline
Find More Posts by 14U2NV
14U2NV's Avatar
Philadelphia, PA
Joined Mar 2004
Rick,
I gave up trying to find one for my Hacker B20 18L. I ended up buying two 2mm pinions and drilling them out to just under 2.3mm. They're brass and really soft and easy to drill. Suprisingly, they came out perfect! If you want to drill them out, I'll check later for the bit size (it was from a Dubro tap/drill set).
The pinions I used were from a local slot car track/store and are typically used in slot cars and are 48 pitch, which is what you need for the Shogun.
These pinions are actually a bit shorter than most pinions I've used in the past and even with my tail gear reversed, I had to use two pinions stacked together to completely engage both gears (where some people are using one regular pinion). If you do this, youhave to make sure the teeth on both pinions mate up perfectly, since the seam where the two pinions come together will ride on the main gear. If they're not matched up properly, you'll tear your main gear up.
Anyway, the whole thing worked out perfectly an I'm getting 13min flight times with the B20 18L, 9T pinion and ThunderPower 1320. I originally had the 10T pinion on the Hacker, but the batteries were getting too hot, besides, I picked up an extra two min of flight time with the 9T.
John
14U2NV is offline Find More Posts by 14U2NV
Old Jun 10, 2004, 12:39 AM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
I "think" that like90 stock these already. It's worth emailing them or checking their website.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Jun 10, 2004, 04:31 AM
rickc is offline
rickc's Avatar
Joined Jun 2002
I thought about drilling out a 2 mm but only as a last resort. I have number bits so the correct size should not be a problem. Getting it true or centered was my concern.
I've never heard of like90 OzzieFlyer, do you have a web address? I'll at least check it out.
Thanks guys.....
Rick
Old Jun 10, 2004, 05:47 AM
Melbourne Australia
Joined May 2003
Rick
www.like90.com
They do upgrades for micro helis and were getting some pinions specially made for the hb, aerohawks, dragonflys..etc. From memory they were the 48 pitch ones which are hard to find.
Old Jun 10, 2004, 08:55 AM
aplphabandaid is offline
Find More Posts by aplphabandaid
Alphabandaid
Marshfield, Wisconsin, United States
Joined May 2003
For my own information, what is pitch on a gear? Teeth I know, but.....
aplphabandaid is offline Find More Posts by aplphabandaid
Old Jun 10, 2004, 09:23 AM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
48p
Hoverup is offline Find More Posts by Hoverup
Found 2.3 mm 9 tooth pinion for T-Rex RobDog Aircraft - Electric - Helis (FS/W) 2 Apr 11, 2006 01:51 PM
Discussion Found the elusive 12T 2.3 mm pinion zmonte Micro Helis 1 Jan 16, 2006 06:56 AM
WTB: GY240, Berg 5 DSP, etec 1200 3s, 2.3 mm pinion 11T microflite Aircraft - Electric - Airplanes (FS/W) 0 Oct 18, 2004 12:51 PM
Putting a GWS 300C - D pinion on a 2.3 MM Shaft boomerace Power Systems 3 Feb 06, 2004 02:14 PM
10 tooth/48 pitch pinion gear, where at ? William A Sport Planes 7 Sep 28, 2001 12:52 PM
