Old Jun 08, 2004, 11:22 AM
enigmabomb is offline
Find More Posts by enigmabomb
TeamZiering
enigmabomb's Avatar
United States, CA, SF
Joined Mar 2002
Reworking a Pack with a bad cell...
I have a 14 Cell 2600mah Pack that was involved in a SERIOUS crash. One of the cells was punctured, and went nuts. So I have this end to end pack that has a bad cell RIGHT in the middle. Can it be saved? (HOW?!) I can't see a soldering iron fitting between these cells.
-Josh
enigmabomb is offline Find More Posts by enigmabomb
Old Jun 08, 2004, 12:58 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Sticks of end-to-end soldered cells will break apart quite easily if cooled first. Put it in the freezer for a little while, or the fridge overnight, then put the stick on the edge of a table with the joint you want to break at the edge. Give it a quick snap, and it will come apart.
..a
Old Jun 08, 2004, 01:51 PM
rms59 is offline
Find More Posts by rms59
Electric Flyer
Connecticut, USA
Joined Oct 2003
I do exactly that but I don't refrigerate them. Once broken, use a good iron and solder the new one in....
BUT.....discharge the pack first.......
rms59 is offline Find More Posts by rms59
Old Jun 08, 2004, 03:16 PM
TeamZiering
enigmabomb's Avatar
Joined Mar 2002
Does one bad cell ruin all the other cells?
GREAT information guys, You probably saved me 80 bucks.
-Josh
Old Jun 09, 2004, 03:05 PM
rms59 is offline
Electric Flyer
Connecticut, USA
Joined Oct 2003
No....if the cell opens the pack draws no current.....If it shorts internally, it just shorts that cell.
Old Jun 10, 2004, 11:33 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
What about the difference with putting a new cell or cells that has only been slow charged at C/10 and cycled 5 times in with cells that have 30+ cycles on them?
I just added two new cells to an older KAN 1050 8-cell pack to make it 10 cells, and I am wondering what it will do to the pack.
FoamCrusher
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jun 10, 2004, 11:35 PM
TeamZiering
enigmabomb's Avatar
Joined Mar 2002
This pack had about 3 cycles on it.
-Josh
Old Jun 11, 2004, 05:51 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The cells could get out of balance and you'd end up damaging more cells in the pack.
3 cycles probably won't make much of a difference, however..
..a
Discussion Rebuild 3S1P with bad cell? gkjake Batteries and Chargers 3 Nov 29, 2006 12:49 PM
Discussion Year Old Trans. Pack develops bad cell. Sanyo 2500 Green Sleeve (Industrial ) everydayflyer Batteries and Chargers 4 Aug 04, 2006 12:22 PM
3S pack with middle cell with zero voltage Nethole Batteries and Chargers 1 Jul 22, 2005 09:06 AM
1.7C on a NMH pack produce a bad cell? JamesD Parkflyers 7 Mar 10, 2002 01:06 AM
Symptoms of a bad cell in a pack? YVR Power Systems 4 Nov 28, 2001 06:32 AM
