Old Apr 12, 2015, 12:33 AM
Harcoreta is offline
Find More Posts by Harcoreta
Harcoreta's Avatar
Spain, Community of Madrid, Madrid
Joined Apr 2014
Build Log
GE GEnx-1B 100mm 3D Printed EDF
Update 06-07-2015
FINISHED!
Video...
GE GEnx-1B 3D Printed B787 Jet Engine with Thrust Reverser (3 min 51 sec)
Photos on post N#41
http://www.rcgroups.com/forums/showp...6&postcount=41
Hi to all!
Last year, I built a 3D printed EDF prototype, It works! but only flew in the maiden flight, only had some overheat issues remember....
http://www.rcgroups.com/forums/showthread.php?t=2150450
I decided to build a improved new design, a scale Boeing 787 turbofan. I like too much this aircraft, but for now too much work for build a whole plane xD. When it be done, It'll be tested on bixler plane mounted on top side.
I've almost finished this long time design and finishing to print all parts too, lots of them
Some specs...
100mm diameter 18 blade main fan scale looking. 24 outlet guide vanes.
34 mm diamenter 18 blade internal turbine, installed on the back shaft of the motor, It's designed only for cooling the motor. Over this section there are a sequence of stator vanes and supports to optimize the airflow. This internal airflow could produce thrust but in any case it'll be a few grams xD.
Scale looking nacelle, the major differences are the simplified engine pylon and the minor reduction on the exhaust area, about 95% fsa
Thrust reverser, complete system with translating cowl, blocker doors and cascades. The most complicated parts that must works (fingers crossed xD)
NTM 1400kv 35mm motor. Thrust target > 0.5Kg with 3S or 4S maximum.
I've attached some renders for the desired goal, the internal airflow section detail, and finally the first sections to be assembled
For now and in the future posts, sorry for my poor English.
I'll be updating soon...
Harcoreta is offline Find More Posts by Harcoreta
Old Apr 12, 2015, 12:57 AM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Looks cool!
AceMigKiller is offline Find More Posts by AceMigKiller
Old Apr 12, 2015, 06:50 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Great rendering, good luck, keep posting
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Apr 12, 2015, 09:17 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Harcoreta :
You are a talent so don't worry about your English...........I speak "Southern" and it is a good thing I don't write that way(an inside joke).
I am wondering how the blades on the fan will hold out under high speeds.
I am subscribed.
Madmax1965 is offline Find More Posts by Madmax1965
Old Apr 12, 2015, 04:07 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Wow!
You should get in touch with Ming
http://www.rcgroups.com/forums/member.php?u=9896
from Windrider
http://www.windrider.com.hk/index.asp
With beautiful fans like that he might produce some new generation large models!
787, 777, 747
4stripes is offline Find More Posts by 4stripes
Old Apr 12, 2015, 08:32 PM
Harcoreta's Avatar
Joined Apr 2014
Thanks guys!
Madmax1965, for the start I'm going conservative. I'm looking for low thrust, only 0.5Kg, It's very low for a 100mm diameter fan. I suppose enough for flight a 1.5Kg plane + motor combo. Printed parts are not stronger than a manufactured one. Possibly when the experiment is completed I'll do a destructive testing on a simplified second unit for go to the limits
Other option is manufacture the fan with other materials/technique, nylon, SLA resin 3d printer...
The fan is printed but not finally assembled, I attached some photos... printing process, post finish with a acrylic thinner bath for improve strength and a shiny finish, and a provisional assembly. Edge painting needed also.
4stripes, I like very much his 737 windrider model, might be interesting trying to powering this model
Ups! first problem with the motor mount section, reprinting part. I've attached too the first assembly goal
Old Apr 13, 2015, 04:36 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Amazing work!
Eddie P is offline Find More Posts by Eddie P
Old Apr 13, 2015, 11:43 AM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Really cool! Subscribed.
I didn't know you could apply something to the printed parts to improve their texture and make it smooth, care to share details on this? Seems like an easy way to get a nice looking part quickly.
Castel101 is offline Find More Posts by Castel101
Old Apr 13, 2015, 07:05 PM
Harcoreta's Avatar
Joined Apr 2014
Castel101. Yes, you can apply acrylic thinner or acetone, only for ABS plastic. I prefer acrylic thinner, I'm getting better results. I bought one liter bottle in a paint shop (+-5$).
For blade finish, I'm putting the the entire blade inside a bottle filled of thinner for 1 min and then left to air dry. 24 hours later can operate with it, time to total cure two days.
For smooth large parts you can apply the liquid with a brush directly to the surfaces.
I'm going to use the thinner too for bonding all parts. You can apply a fine layer of thinner with a brush to all contact surfaces in two pieces. Repeat the operation three times, after, you can bond the two parts. Bonding time over 15 minutes, total fixation over one hour.
New printed part is ok! motor installed and first guide vanes. Turbine photo added.
Old Apr 14, 2015, 12:14 PM
Castel101's Avatar
Joined Sep 2011
Looks awesome! Thanks for the details!
Old Apr 16, 2015, 09:29 PM
Harcoreta's Avatar
Joined Apr 2014
Motor assembly Finished!
Detailed photos of sections and turbine installed. Next step outlet guide vanes assembly and Translating cowls.
Old Apr 16, 2015, 09:37 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Looking very good, but I have one suggestion...
Mounting the motor at the aft end creates a very long moment to where the fan is mounted. Any imbalance will create strong forces on the motor mount. I prefer having the mounting area between the motor and fan to have support closer to the center of spinning mass.
Your design limits the motor length as well.
Old Apr 16, 2015, 11:04 PM
Harcoreta's Avatar
Joined Apr 2014
you're right! also, any fast acceleration or crash will be dangerous. It isn't the ideal position, very difficult to make an internally similar design to the original.
Old Apr 17, 2015, 08:47 AM
park aviator is offline
Find More Posts by park aviator
park aviator's Avatar
Australia, NSW, McGraths Hill
Joined Mar 2008
That is amazing mate your fan would look terific on a scale 747 or maybe a viking
park aviator is offline Find More Posts by park aviator
Old Apr 17, 2015, 07:52 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
holy crap....that's awesome!!!!!!
corsair nut is offline Find More Posts by corsair nut
Cool 3D printed Vectored Thrust nozzle unit and EDF housing (new 64mm EDF housing) Arxangel Foamy EDFs 22 Jan 19, 2016 02:17 AM
Discussion 3D Printed EDF Flying Wing DR_G Flying Wings 18 Jul 16, 2015 02:21 PM
Discussion Motor/ESC for a custom 18 blade EDF 3d printed Harcoreta Electric Ducted Fan Jet Talk 19 Apr 29, 2014 08:04 AM
Build Log Micro EDF Hawker Hunter - CAD, 3D Scanning, 3D Printing etc meerkat13 CAD/CAM 1 Mar 14, 2014 08:02 AM
Build Log F-Sweep XL KFm4 64mm EDF /w 3D printed EDF housing (64mm EDF housing installed) Arxangel Foamies (Scratchbuilt) 1 Jul 30, 2013 03:30 PM
