Old Jun 07, 2004, 03:57 AM
saitrix is offline
Find More Posts by saitrix
Specialist in Crashing
UK, Loughborough
Joined Jan 2004
what brushless motors are people using with their formosa's?
hi,
what brushless motors do you recommend with the formosa? also what batteries are people using with their brushless? one last question, what torque do they give out for your formosa? thanks, Dan
saitrix is offline Find More Posts by saitrix
Old Jun 07, 2004, 09:37 AM
csisfun is offline
Find More Posts by csisfun
Balsa!!!
Singapore
Joined Sep 2003
Himax 2025-4200... universal stuff. C gearing and an 11x8 prop with 3s and you're good to go!
Get a Hacker heatsink. xD
Cheers,
UZ
csisfun is offline Find More Posts by csisfun
Old Jun 07, 2004, 09:56 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Depends on the performance you are looking for. I am very happy with the Himaxx 2015/5400 propped for 10 amps. That motor is good for 15, but gets very very hot approaching that.
I use the 5.33 gearbox (the one the kit comes with) and an GWS 9x5 DD prop. It is an excellent combo and I can fly at full throttle (old habits die hard) and not get my motor, or LiPolys (3s) too hot.
For all out I would up that to the 2025 motors at about 15 amps and really go.
Mine goes up till it is a speak even on my setup - plenty of power for any pattern maneuvers.
Old Jun 07, 2004, 10:08 AM
saitrix is offline
UK, Loughborough
Joined Jan 2004
Hi,
what do people think to the HET-RC Typhoon Micro 6 motor to use as an outrunner in it? Dan
Old Jun 07, 2004, 02:59 PM
DEWorley is offline
Find More Posts by DEWorley
Joined Feb 2002
AXI 2208/26 & 8x6 & 7.4/1500 LiPoly flies mine very well, 10-12 minutes
DEWorley is offline Find More Posts by DEWorley
Old Jun 07, 2004, 03:44 PM
saitrix is offline
UK, Loughborough
Joined Jan 2004
Hi,
is the AXI 2212/34 good to use on both 7 cell nicads and 3 cell lipos? Also is it powerful enough or too powerful for it? Thanks, Dan
Old Jun 08, 2004, 10:53 AM
charlie2020 is offline
Find More Posts by charlie2020
Taipei Sung Shan, Taiwan
Joined Feb 2004
An efficient Brushless motor with the strongest Gearbox for GWS models:
Look at this thread:
http://www.rcgroups.com/forums/showt...&page=13&pp=15
80% efficiency & Direct fit to the 10x10x100mm wood stick with exactly the same set up for GWS models.
charlie2020 is offline Find More Posts by charlie2020
Old Jun 08, 2004, 03:41 PM
PaddyinDublin is offline
Find More Posts by PaddyinDublin
poiteen power
Dublin City, Republic Of Ireland
Joined Jan 2004
Hi Dan
I've recieved my formosa last week, i have a Himax 2015-5400 for it , going to use EPS350 D ratio gearbox and an 11x7 apc-e prop and a 3 cell TP1900 li-po battery should be a blast
CHeers
PiD
PaddyinDublin is offline Find More Posts by PaddyinDublin
Old Jun 08, 2004, 04:57 PM
tkgavette is offline
Find More Posts by tkgavette
√-1 * ∞ = Inverted Flight
tkgavette's Avatar
Sioux Falls SD
Joined Apr 2004
Check out the motor chart at Parkflyermotors.com I've found it extremely helpfull in picking out prop, gearing, and amps. Motocalc scrambles my melon.
tkgavette is offline Find More Posts by tkgavette
Discussion What Flightpower Lipos are you using with your T-Rex? Tweeky Mini Helis 5 Jun 25, 2007 07:40 AM
Discussion What Power Systems are People Using With the Electric Chrysalis? ransom peek Electric Sailplanes 4 Aug 16, 2006 09:45 PM
Question what brushless motor are you using? thriller Motorcycles 9 Mar 28, 2006 10:02 AM
What CC125 settings are you using with your hot motors + run-in IB3800 ? Protocooler High Performance 24 Dec 05, 2005 11:44 PM
Question What type of connector are you using on your Lipo's? mr_ken Batteries and Chargers 14 Jan 15, 2004 01:11 AM
