Old Jan 12, 2002, 09:53 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Smooth Finish on Foam?
WHat is the best way to get a chrome finish on a Foam Fuselage?
Kirby
kepople is offline Find More Posts by kepople
Old Jan 13, 2002, 09:10 AM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
"Chrome Foam"
Sounds like a real challenge. Never done it but found some chrome "duct tape" at a liquidator store. Thought about making panels out of it, just like the real ones. The tape had several flaws in it so didn't pursue. Top flite makes a chrome trim sheet that might work if the adhesive will hold up.
For sanding foam, try drywall sanding screen. Works good.
Rot-so-ruck..
RonJ is offline Find More Posts by RonJ
Old Jan 13, 2002, 10:12 AM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Kirby,try this link(www.scaleaero.com) look for a link to finishing material.i bought some aluminum finish but its a pain in the a## to put on.Also wrinkles easy.maybe it will work for you. stefanP
Ghost rider requesting a fly by.......
KOMET 44 is online now Find More Posts by KOMET 44
Old Jan 13, 2002, 11:09 AM
Dave Seay is offline
Find More Posts by Dave Seay
Faded away
Joined Nov 2001
What about first putting on a light coat of FG/PolyUrthane varnish like the suggest for finishing the foam fuzes on those 'park fighters'?
http://webhome.idirect.com/~manuel/html/cover.htm
Dave
Dave Seay is offline Find More Posts by Dave Seay
Old Jan 15, 2002, 08:25 PM
thin wing is offline
Find More Posts by thin wing
ireland
Joined Apr 2001
chrome is difficult to see
Once saw a guy with fast 40 glow plane mustang looking type cool on the ground but against a grey sky very diffucult too see crashed and wiped out on first flight suspect he lost orientation Insisted it was interference
Not my problem
Having seen a few foamies covered in paper pva method not impresssed even when one was over covered again in Ora cover white unless you do a lot of sanding the bumps seem to jump out
For me when I have cracked my epoxy fibre glass ship (losses it gloss with my flying style low and fast touch and goes no undercarrage wears out the belly quickly) I use solor film over sanded down zone and it looks ok
Suggest fibre glass with water paint will make better surface and then recover in chrome oracover or other branded chrome shrink film
Fly low and fast and scrath the belly
David in Ireland
thin wing is offline Find More Posts by thin wing
Old Jan 15, 2002, 10:30 PM
Ken Manuel is offline
Find More Posts by Ken Manuel
Unregistered Foamsmith
Canada
Joined Nov 2001
Aluminium finish maybe?
I have painted and covered alot of foam in all sorts of colours imaginable.
I find that chrome coloured Solar Film works well if you dont overheat the iron. But Solar film is very thin and doesnt cover well, but that's why it also doesn't require much heat. Proper prepping of the aircraft with a base colour before will give you a nice finish.
Most other chrome iron on coverings like Monokote require too much heat and deform the foam underneath long before they adhere to the foam itself.
I find acrylic paint over polyurethane the most reliable and best way maintain foam aircraft. But chrome is hard to do.
There is a section on "How to cover your fighter" on my website. Please feel free to try these techniques on your own creations and let me know how it works out.
Good luck Kepople.
Here's what aluminium looks like.
Ken Manuel is offline Find More Posts by Ken Manuel
Old Jan 16, 2002, 12:59 AM
iankraus is offline
Find More Posts by iankraus
iankraus.com/rcvideo
iankraus's Avatar
Joined Jun 2001
I really like the polyurethane over light glass or kite fabric method. For some applications 2.2 mil uline tape is hard to beat. very strong. hardly weighs more than film repairs can be invisable (and are super fast). The tape also covers the bead of foam without the weight of fillers. The model can be recovered at the end of the season! very economical, no fumes no cleanup
even works with glow planes. I like kite fabric too.
This model below is covered in tape. The canopy is 99cent store gift wrap mylar and 77 spray. I roughen the mylar with 220 wet and dry lightly first.
I am working on some inkjet decals for this plane. I hope it is still looking pretty for the WRAM show here in NY.
iankraus is offline Find More Posts by iankraus
How to get a smooth finish on foam? Bonez Foamies (Kits) 3 Mar 28, 2005 02:23 PM
Good surface finish on foam Scaledown Foamies (Kits) 12 Dec 17, 2004 02:44 AM
smooth finish on glassed GWS plane new2heli Parkflyers 5 Jun 20, 2004 12:40 PM
How to get the best finish on a foam model bluespier Foamies (Kits) 12 Jul 14, 2003 03:11 PM
Getting smooth finish on Foam? kepople Scale Kit/Scratch Built 3 Jan 13, 2002 02:33 AM
