Old Jun 05, 2004, 11:53 PM
petn7 is offline
Find More Posts by petn7
Joined Apr 2000
using a motor as a servo?
anyone know how (assuming it's possible) to turn a continuous turning motor into a servo or give it "servo-like" control? basically i have a motor i can control remotely to go full on, off, or reverse. i want to be able to use this to move a control surface
petn7 is offline Find More Posts by petn7
Old Jun 06, 2004, 02:56 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
http://www.uoguelph.ca/~antoon/hobby/servo1.htm
Starting from just a motor will need a lot of extras. You need something to sense the servo position and feedback control electronics to drive the motor to the correct position.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jun 06, 2004, 11:28 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
You add a gear train to a motor to slow the motor's many revolutions down to the 1 or less at the output.
I have used slot car gears to do this.
The selection of direction and amount is as simple as an On-off-on switch, or a feedback system that controls the position.
There's two hard parts. Aligning the gear train, and creating the feedback loop.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 09, 2004, 03:58 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
You could just use the motor to turn a length of threaded rod with a free running nut connected to your control surface (screw jack) and ideally use limit (micro)switches to stop where you desire. Your 'start' switch would then short out the appropriate limit switch to get things moving in the right direction....no need for feedback electronics then.
John
jetstuff is offline Find More Posts by jetstuff
Old Jul 16, 2004, 11:13 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
You should be able to take the circuit board out of a servo, use the motor wires to drive your motor (possibly with something to increase the power) and use the pot (or a similar one) to sense the position.
I say 'should' because changing the motor doesn't always work, but I don't know much about electronics! You can certainly remove the pot from a servo and attach it to something else.
RobinBennett is offline Find More Posts by RobinBennett
Using Acetone as a CA debonder? Mike C The Builders Workshop 11 Feb 13, 2005 04:00 PM
Help with re-using a Fighterbird motor as a puller Timeetyo Power Systems 2 Jun 25, 2004 03:24 PM
Pager motor retract servo, how to build? JonB Scratchbuilt Indoor and Micro Models 1 Apr 04, 2002 01:29 AM
Question Using Wingo as indoor flyer? JensJakob68 Parkflyers 9 Dec 14, 2001 05:06 AM
traxxas motor as e-flight sampah Electric Plane Talk 3 Oct 01, 2001 04:18 AM
