Going from 2.5 to 3 is a 20% pitch increase, creating about 15% more pitch speed at the expense of a slightly higher current draw. You may see a small increase in maximum speed, and slightly better climb rate.
Code:
Power System: EPS100C-B (4.43:1), 3S ET-1200 Lipoly. Prop Volts Amps rpm Thrust(g) ====== ===== ==== ==== ======== EP9070 9.7 3.0 3780 220 EP9070X3 9.7 3.1 3772 216 |
Have a look at the Q&A section at:
http://www.djaerotech.com/dj_askjd/ Don Stackhouse there designs full size propellers as a day job (the runs DJ Aerotech at other times selling the roadkill series of models). What he doesn't know about propeller design simply isn't worth knowing! Cliff |
It seems that the efficiency of a 3 blade propeller is very low! I would have choose a smaller diameter 3 blade prop to match a 2 blade one with the same pitch, to keep all other specs the same. Could the results of your test confirm the theory of turbolence in a scale propeller? It seems that the third blade is almost transparent. Anyway I agree with you about the use of a 3blade prop: just for a scale plane! Piero. |
| Thread Tools | |
| Discussion Prop Pitch vs the dreaded "stall, spin, crash" syndrome | ken_keeler | Electric Plane Talk | 10 | Jul 21, 2006 11:05 AM |
| Discussion rpm vs volts vs prop size? | grant31781 | Power Systems | 5 | Mar 13, 2006 01:08 PM |
| Ion prop size vs battery size | EricSoar | High Performance | 3 | Jun 07, 2005 02:39 AM |
| In flight prop "unloading" vs. current draw. | nadt770 | Power Systems | 11 | Feb 01, 2003 06:22 AM |
| Props..pitch vs. speed.... | Franck | Power Systems | 4 | Feb 25, 2002 06:05 PM |
