Old Jun 04, 2004, 06:11 AM
EddieNewYork is offline
Find More Posts by EddieNewYork
EddieNewYork's Avatar
Los Angeles, CA
Joined Apr 2004
Please help me with my gobrushless DIY kit
Hi,
I ordered the DIY kit from gobrushless.com, and I want to build it with a 2mm shaft, but the bell that came with the kit has a 3mm hole. I purchased the 6x2 bearings for a 2mm shaft, and I would just order a new bell with a 2mm hole; however, they only sell it for the 25mm stators, and I'm using the 22.7mm stator which comes in the kit. What do you guys think is most economical way to fit a 2mm shaft into a 3mm hole.
Cheers,
Eddie
EddieNewYork is offline Find More Posts by EddieNewYork
Old Jun 04, 2004, 06:45 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Get a 3mm shaft and turn the end down to 2mm.
..a
Old Jun 04, 2004, 07:18 AM
Los Angeles, CA
Joined Apr 2004
..a
How does one turn the end down? Do you mean on a lathe? And if I don't have access to one, is there an alternative solution?
Old Jun 04, 2004, 08:38 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Find a piece of 3mm OD 2mm ID material and use it as a sleeve, but I doubt you'll have success here.
..a
Old Jun 04, 2004, 08:47 AM
Twister6er is offline
Find More Posts by Twister6er
United States, NC, Leland
Joined Dec 2003
You might find it easier to just adapt your prop/pinion or whaterver to the 3mm shaft. Thats what I did with my heli.
Twister6er is offline Find More Posts by Twister6er
Old Jun 04, 2004, 12:14 PM
Bob Chiang is offline
Find More Posts by Bob Chiang
Ithaca, NY USA
Joined Oct 2000
Hi Eddie,
Maybe the bell for the 25mm stator would work with the 22.7mm stator if you used 2mm thick magnets instead of the 1mm thick magnets provided in the kit.
-Bob
Bob Chiang is offline Find More Posts by Bob Chiang
Old Jun 04, 2004, 01:25 PM
Los Angeles, CA
Joined Apr 2004
I'll see what I can come up with, thanks guys. btw, Twister6er how did you get a 2mm pinion to fit? Did you just drill the hole in the pinion larger?
Old Jun 04, 2004, 01:41 PM
Cyberman is offline
Find More Posts by Cyberman
Mad Max meets the Thinker
Cyberman's Avatar
Pittsburgh, PA
Joined Apr 2004
Are you planing on swinging a really big prop with the motor? Most people avoid gearing down the output of these motors. What often they do is decrease the RPM/v and raise the voltage and direct drive a prop. Unless it's a monster this is a much better route and less work on your part.
Perhaps a better thing is, what are you trying to swing with the motor?
Cyb/Stephen
Cyberman is offline Find More Posts by Cyberman
Old Jun 04, 2004, 01:53 PM
kenkey is offline
Find More Posts by kenkey
GreeneAeroFlyers
kenkey's Avatar
Greeneville, TN
Joined Mar 2004
Most the pinion gears for the 2mm shaft are also available for the s400 with a 3mm shaft.
Ken
kenkey is offline Find More Posts by kenkey
Old Jun 04, 2004, 03:19 PM
Joined Dec 2003
Eddie, I just bought a 48 pitch pinion for a 3mm shaft. I think it was by HPI for an RS4 street car.
Old Jun 04, 2004, 06:00 PM
Los Angeles, CA
Joined Apr 2004
Its actually for my micro heli's (Century Hummingbird) main motor . I use a 10 and 11 tooth pinion for them. I also use micro rs4 pinions, but I don't think those come in 3mm, do they?
I'm also building a second for my tail, but I think the 3mm will work fine for that since I think I can just push the prop on with a gws rubber prop adapter.
Old Jun 04, 2004, 06:29 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
buy the big bell .. use your 22.7 stator buy 2mm mag and your set here is a pic... of the modified motor useing what parts steve sells.. use his motor bearing tube it will work with your 2mm bearings..
AIR MOVER is offline Find More Posts by AIR MOVER
Old Jun 04, 2004, 06:34 PM
Los Angeles, CA
Joined Apr 2004
Do you mean just I should just buy the stock can for the 25mm Stator, and use my 22.7mm stator, like what Bob said? Will I need to order the thicker magnets too?
Old Jun 04, 2004, 08:08 PM
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
yes it will give you a more powerful motor for sure I have done 3 motors this way.to include a amazeing 12mag 12 pole this way.
Old Jun 18, 2004, 08:00 AM
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
Hey Air Mover
What did you use for the shaft in this setup?
Steve
davidsons is offline Find More Posts by davidsons
please help me with my little HB!! birdie_in_texas Micro Helis 19 Jun 03, 2004 12:47 PM
Question Please help me with my kyosho megaforce MEGAFORCE Off-road Cars 0 Sep 06, 2003 08:51 AM
Please help me with my zero throttle respone from my Futba Skysport Radio mike93 Parkflyers 5 Jun 14, 2002 09:45 PM
PLEASE Help me with my zero throttle response on my radio!!! (Please read) mike93 Electric Ducted Fan Jet Talk 2 Jun 14, 2002 07:52 PM
