Old Jan 12, 2002, 11:06 AM
Jon h is offline
Find More Posts by Jon h
Waterford, Mi, USA
Joined Jul 2001
Aluminum Servo mounts for 120 degree mixing on ECO-8!
Hi guys, I have just finished my ECO-8 and am waiting for the Mega motor to come in. Anyway I made these really neat aluminum srevo mounts that give nearly perfectly vertical linkages.
Go here for pictures http://www.geocities.com/jonh48327/ECO8.html
What do you guys think?
NJJ061801
Jon h is offline Find More Posts by Jon h
Old Jan 12, 2002, 03:11 PM
rtront is offline
Find More Posts by rtront
Vancouver, B.C., Canada
Joined May 2001
I too have created aluminum motor mounts for 120 CCPM for my Eco of a different design. However, now that I want more negative pitch, I have put longer servo arms on and the servo arm balls are no longer directly under the swash balls. I need to re-engineering.
Anyway, I was wondering exactly how long your servo arms are from rotation axis to ball center?
And, with your current servo arms, do the mounting brackets rub against the heli body?
Thanks, Russ Tront.
rtront is offline Find More Posts by rtront
Old Jan 12, 2002, 04:23 PM
Jon h is offline
Waterford, Mi, USA
Joined Jul 2001
No, the mounts or servos do not touch the body. I measured the servo arm, from center of the rotation axis to the center of the ball it is 13mm. Thats plenty long enough for right now since I won't be doing any areobatics soon. Those are the arms that come with the HS- 81 servos.
Old Jan 13, 2002, 10:03 PM
rtront is offline
Joined May 2001
In order to do aerobatics I need a fair amount of negative pitch (currently -5 degrees but I could go to -9 with my current arms). With the standard head, I am using 19mm long servo arms (axel to ball center). I bought some massive 'super strenght' servo arms from Dubro. You can get them in different flavors for different brands of servos. I cut a lot of the extra material off, but keep enough length to give me 19 mm. However, I suspect if I mounted my servos the way you do, but far enough out to allow these 19mm arms room, I might hit the body. I have another idea in mind for mounts and will say something to the group if it is sucessful.
You should all note that to get even 5 degrees of negative pitch on the standard plastic head (and still retain aileron control without jamming) I had to shorten the very short push rod between the seesaw and the mixing arm. However, this is not shortenable without cutting off some material and weakening it because there is not much for the threads of the rod to bite into any more. So I made the hole that is threaded into deeper, until it almost breaks through to the ball.
For real aerobatic, you probably want to go to the aluminum head. I am trying to put my new aluminum head together now. Regards, Russ Tront.
Old Jan 14, 2002, 07:23 AM
ECOFlir is offline
Find More Posts by ECOFlir
ECOFlir's Avatar
Gardners, Pa. 17324
Joined Sep 2001
John H,
That's a nice and clean looking mount. How much extra weight did that apply?
Art
ECOFlir is offline Find More Posts by ECOFlir
Old Jan 14, 2002, 08:19 PM
Jon h is offline
Waterford, Mi, USA
Joined Jul 2001
I just shortened the link between the flybar and mixer lever and I now get +11 to -10.
The mounts weigh 5 grams each. So there not really a significant weight gain.
NJJ061801
http://www.geocities.com/jonh48327/Jon_s_E-Helis.html
dfx file for a 120 degree servo mount plate mattijs321 Micro Helis 4 Jul 26, 2006 02:34 AM
Looking for Power System advice on ECO 8 simonbryant Electric Heli Talk 14 Aug 07, 2005 12:17 AM
Belt for main-gear on Eco 8? sizam Electric Heli Talk 2 May 10, 2004 02:05 PM
blade shaft too short on Eco 8 aluminum head? rtront Electric Heli Talk 4 Aug 16, 2003 09:54 AM
servo placement for 120 swash on eco gregh Electric Heli Talk 19 Dec 17, 2001 07:44 AM
