Old Jun 03, 2004, 01:01 PM
ManWithNoName is offline
Find More Posts by ManWithNoName
Joined May 2004
Update on Alfa Model MiG-15!
I just received an email from Antonín Alfery at Alfa Model. He said the MiG left past week and he estimates it arriving here in 3-4 weeks.
ManWithNoName is offline Find More Posts by ManWithNoName
Old Jun 05, 2004, 12:31 AM
bboydeezturb is offline
Find More Posts by bboydeezturb
bboydeezturb's Avatar
West Chicago,IL
Joined Oct 2003
cool ...did he said anything about price
bboydeezturb is offline Find More Posts by bboydeezturb
Old Jun 05, 2004, 01:29 AM
Joined May 2004
Nope.
Old Jun 07, 2004, 05:30 AM
RoverTomcat is offline
Find More Posts by RoverTomcat
Zoom-Zoom
RoverTomcat's Avatar
Switzerland, ZH, Dietikon
Joined Jun 2004
Hi Guys,
mine will be here early next week!
I can hardly wait, the complete R/C gear, Hacker B20-12-L and Vasafan 55 is ready for installation in the MiG...
By the way - the price over here (Switzerland) is around the 150$ - Mark, including the standard fan.
Best regards
Paco
RoverTomcat is offline Find More Posts by RoverTomcat
Old Jun 07, 2004, 03:08 PM
Pilot44 is offline
Find More Posts by Pilot44
Let er Rip
Pilot44's Avatar
Long Island, NY
Joined Oct 2003
Man with no name, or location ...
Arriving where.....in USA at Hobby Lobby. in a few weeks or what.... enlighten us.....
Jim G
Pilot44 is offline Find More Posts by Pilot44
Old Jun 07, 2004, 03:10 PM
Pilot44 is offline
Let er Rip
Pilot44's Avatar
Long Island, NY
Joined Oct 2003
Rover,
Please give us your early impressions of the the plane.....and what setup you will use for power...Sure would be helpful to us waiting in the wings.
Jim G
Old Jun 07, 2004, 05:54 PM
Joined May 2004
Jim G
He didn't say. I hope he ment hobby lobby.
Old Jun 08, 2004, 03:50 AM
Zoom-Zoom
Joined Jun 2004
Rover,
Jim G
Hiya Jim,
sure - no problem! I'll keep you updated on the progress of the MiG...
By the way, I intend to use the same power setup as in my first e-ducted fan plane, Alfa's Huckebein.
- Hacker B20-12-L
- Vasafan 55
- Hacker Master 18A ESC
- Schulze receiver
- Graupner 1041 Servos
As far as I know, the standard fan that comes with the MiG is the same as in the Huck - it can be used to fly the plane when the stock speed 300 is replaced with something brushless, but with the Vasa, the weight/power ratio of the MiG will be better then 1:1... Which is nice...
Looking at the detail piccies on Alfa's website, it seems like they also improved the plane's aileron pushrod routing - instead of bending it into a "S" shape, it is now routed much less restrictive!
I can hardly wait to lay my hands on the kit..
Best regards - Paco
Old Jun 08, 2004, 05:20 PM
teli88 is offline
Find More Posts by teli88
Go for it
teli88's Avatar
Hässelby, Sweden
Joined Jun 2003
The fan unit is a new design from what i've heard.
Looks very similiar though.
Hopefully they will arrive this week to Sweden.
/Terje
teli88 is offline Find More Posts by teli88
Old Jun 08, 2004, 07:53 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
RoverTC, what pack are you planning to use? I have a vasa55 with the hacker b2012L on 3s lipo (3s2p tp2100), good for about 270watts, but have to run a heat sink on the motor for that, also pulls about 27 amps.
dave morris is offline Find More Posts by dave morris
Old Jun 08, 2004, 08:25 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
Well, It is good to have good power on the Alfa Mig 15. But the way this mig is designed, I do not think it could take too much power. 270 watts may cause a serious issue about overpowered, overweight the Alfa Mig 15, unless you heavily reinforced the body. That would be a very different story then. I think the key to keep it handlaunchable is to build it strong and light as possible
rcguy01 is offline Find More Posts by rcguy01
Old Jun 09, 2004, 08:51 AM
Zoom-Zoom
Joined Jun 2004
Hi Dave,
I'll use 3s2p 1200 E-Tecs which are okay for 24Amps continous current, and 40Amps peak.
Or maybe, I'll restrict the ESC's power output to around 80% via the transmitter's ATV, this worked fine in the Alfa Huckebein. I just had to make sure that the ESC had enough cooling air streaming over it!
I had an Amp-meter wired in and reduced the ATV while the engine was running so that the amps were around the 15A - Mark.
Still the Vasa would deliver around 450g static thrust - more then enough for the Depron Huck!
I guess that I'll use a bungee to start the MiG though, bad hand launching was what costed me the TA183. With no propeller blast on the elevator, there was no way to compensate my brother-in-law's bad throw. She went vertical, dropped a wing and crashed from about 15m height.
Not an experience I want to have soon again...
Best regards from Zuerich (and 31°C outside) - Paco
Old Jun 09, 2004, 12:15 PM
orlando fl
Joined Oct 2000
Try launching at 50% power, my minx does the same thing, if you launch at full power it noses up big time, and with no elevator authority,well you know what happens. After launching at 50% and getting up to speed there is no problem at all. I think it has something to do with thrust line in relation to the wing, someone else suggested the airblast below the stab was reducing the pressure below the stab, causing it to be pushed down, and the nose pivioting up. The Migs layout may not have the same problem.
Sounds like a very strong setup, should be light too using the 3s2p 1200's, good luck with it.
Old Jun 15, 2004, 01:32 AM
Zoom-Zoom
Joined Jun 2004
Mornin' guys,
well, yesterday the MiG arrived safely at my home! My first thought was "Uh-oh, this is going to take a while to finish"...
The parts are very nicely done and come wrapped in bubblewrap - like the other Alfa planes.
The MiG's fuselage is virtually empty, just the intake duct is installed by the factory... All the R/C mounting plates, reinforcement strips and exhaust duct have to be installed by the builder.
I'll keep you updated on the building progress!
Cheers - Paco
Old Jun 15, 2004, 09:06 AM
Pilot44 is offline
Let er Rip
Pilot44's Avatar
Long Island, NY
Joined Oct 2003
Paco,
Glad to hear your off and running with the Mig15, please do keep us posted on your progress and thoughts.
Might I ask how much you paid for the plane? Converted to USD. I'm curious to know if its priced as the the Alpha 183 jet is....
Jim G
Wanted WTB: Alfa Model MIG-15 kit yankeecanuck Aircraft - Electric - Jets (FS/W) 0 Aug 05, 2006 02:52 AM
Alfa Model MIG-15 electric DF... awesome... tnsfrk Parkflyers 24 Apr 23, 2005 07:12 PM
Alfa Model Mig 15 Lucam Electric Ducted Fan Jet Talk 6 Sep 28, 2004 12:28 AM
Yippee! Anyone else here waiting for the Alfa Model MiG-15? ManWithNoName Electric Ducted Fan Jet Talk 5 May 30, 2004 03:20 AM
Whats the latest on the Fantastic Model Mig-15/F-86? mike93 Electric Ducted Fan Jet Talk 11 May 31, 2002 04:11 AM
