Old Jun 02, 2004, 10:03 PM
apodoc is offline
Find More Posts by apodoc
Joined Jun 2004
Rookie. E-Starter first 10 flights. Questions
Ok, I have had the E-starter for quite sometime now. Today, is was the first day I had 10 successful flights. However, I had some issues today. The nose seemed to shoot upward. Everything looks like it is trimmed ok. It also feels like I dont have enough power to go higher. Everything is still the stock equipment. Fully charged brand new Duracells in the transmitter. And 3 new battery packs.
When I take off the nose does not want to come up with full elevator deflection. Then when proper speed is achieved it takes off. But it feels like I need to climb into the wind to gain altitude. Then the nose almost goes up 90 degrees. I have to play with the elevator alot and point it down.
First question is: Is it normal to pitch up and down constantly and adjust power to keep the plane level?
2nd Question. Are there any threads on this forum for me to do some reading on how to tweak the plane for optimum flight.
Abe
apodoc is offline Find More Posts by apodoc
Old Jun 03, 2004, 03:49 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by apodoc
And 3 new battery packs. Abe
What kind of cells? If they are brand new Nimh's they should be cycled for a few times to acheive optimal performance. They get better after everything from 3 to 7 charging / discharing cycles.
That depends on how your plane is trimmed, and if the CG is correct. It should fly straight in level, when trimmed right.
I would recomend that you take the time to read the article of Keith Shaw found here. In the third part you will find very useful info on finetuning the CG and trimming!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Video My e-Starter first flights also showing transmitter ChromeDome Electric Plane Talk 4 Sep 07, 2006 09:14 PM
First E-Starter and first attempt at a paint job Skawrpion GWS (Grand Wing Servo) 7 Nov 01, 2003 01:30 PM
E-Starter first flight in Woodland, WA dotyj Parkflyers 22 Jun 11, 2003 04:55 AM
Slow Stick & E-Starter first flights Jakester Parkflyers 17 May 12, 2003 08:12 AM
E-Starter first flight Caveman Parkflyers 7 Apr 09, 2003 06:44 AM
