Old Jan 11, 2002, 08:38 PM
Mikado Logo's 3D
Inverted-3D's Avatar
Joined Oct 2001
Logo 20 Tail Boom Belt Installation doesn't feel right?
I am converting my Logo 16 to a long boom Logo 20. When setting up the rubber belt it seems like it would create a lot of drag. I have check and double-checked the installation but nothing seems to free it up like a wire or carbon shaft setup. Do any of you Mikado owner ever notice that the belt doesn't seem to spin the tail freely?
Inverted-3D is offline Find More Posts by Inverted-3D
Old Jan 11, 2002, 10:43 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
On the 10 it feels tighter than I'm used to with a shaft/wire drive.
But the motor spins it up just fine.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 12, 2002, 10:44 AM
Mikado Logo's 3D
Joined Oct 2001
Fred
What did your Logo 10 come with for a pinion gear? I am thinking I will need a 16t and 12 cells with a Fun 600-18. Have you tryied 14 cells and larger blades? Are you still using the woodies?
Old Jan 12, 2002, 01:10 PM
-Flight enthusiast_
gpeden's Avatar
Lake Louise, AB, Canada
Joined Feb 2000
Hello Mr. Inverted,
When I assemble a LOGO tail boom, before I add the front assembly I hold a little tension on the belt, make sure that it is engaged on the sproket on the tail rotor shaft and give it a tug. If the tail rotor does not spin freely then something has changed during assembly and tightening of the rear case. Once the front part is added, there is a feeling of taughtness and a bit of drag, but the tail rotor will still freewheel somewhat when the front gear is run across your hand.
Unless I am having a "senior moment" there is no pinion included with the kit because of the wide range of gearing that might be required. I would suggest getting the 15T and 16T pinion.
Keep in mind the 1600rpm limit without thrust bearings, too.
Cheers!
Glen
gpeden is offline Find More Posts by gpeden
Old Jan 12, 2002, 05:28 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I am starting with the 14t on 12 cells with the 600-15 and woodys.
At 75% throttle I get 1320 HS on nicads and 1350 HS with zapped nimh's. Both packs are fresh of the charger, but only cycled a few times.
I have some head wobble to addres before flying though. Looks like the paddle arms may be out a little.
But HS and control seems pretty good.
Logo 20 - Tail drive belt failure Ben74 Electric Heli Talk 6 Jan 28, 2003 11:19 AM
Superbrain - DC Doesn't work right Xoltri Batteries and Chargers 0 Dec 07, 2002 01:20 AM
Logo 20 tail pitch slider range MikeStammer Electric Heli Talk 3 Jul 15, 2002 08:12 AM
Logo 20 tail pitch lever Mark Simmonds Electric Heli Talk 11 Mar 12, 2002 05:53 PM
LOGO 20 – Tail-wagging help please! rbull Electric Heli Talk 2 Jul 01, 2001 10:45 AM
