Old Jun 02, 2004, 05:25 AM
atid is offline
Find More Posts by atid
Joined Jun 2004
Rossi 40 vs OS 46AX
What are your thoughts?
atid is offline Find More Posts by atid
Old Jun 02, 2004, 12:17 PM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
I would not think they are comparable engines.
My first thoughts were 'not suitable for a Bleriot'.
What do you want to use it for?
Tony
Tony Oliver is offline Find More Posts by Tony Oliver
Old Jun 02, 2004, 02:23 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
I have had both. My Rossi was the most contankerous (sp?) engine I ever had. Very powerful when it ran but -ell getting the thing started and keeping the needle set. If the temp went up or down, start all over. My OS 46 fx was a nice little engine. Easy starting, held a setting, dependable, decent power. I opted out of 2 stroke in favor of 4 stroke engines. Lots of pulling power, easy on gas. Other's experience may vary.
mode1 is offline Find More Posts by mode1
Old Jun 02, 2004, 02:34 PM
treym7 is offline
Find More Posts by treym7
Greenville, SC
Joined Sep 2003
Like tonyo said, what is this going to be used in, that will make a big difference. I don't have first hand experience with the 46AX, but I have several 46FX's and they are wonderful engines. I also have a Rossi that I just love, gobs of power, but she likes to rev to make the power.
Trey
treym7 is offline Find More Posts by treym7
Old Jun 02, 2004, 02:40 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Rossi motors are very powerful and take much more care to run and keep running properly. They perform very well piped on low nitro fuel.
OS makes excellent no fuss engines. They are reliable and forgiving - they also don't make the most brute power. That is a trade off.
I have run many types of engines. All of my higher performance engines (Rossi, MVVS, JET and Nelson) are much pickier. So what I started to do was quit buying them and use a larger displacement TT or OS and put that on my plane. It was nice not to mess with pipes and burning plugs etc.....
So the question really is what are you looking for - all out power this starts with JET and Nelson then Rossi MVVS or less power and user friendly OS, TT, Supertiger etc.
Trust me go with the OS or TT or other sport engine and get a bigger displacement engine if you need raw power.
Old Jun 03, 2004, 02:41 AM
atid is offline
Joined Jun 2004
Thank you all for the answeres
I wanted to verify my thoughts about the engines.
I'm a newbie to the RC airplane world, and I use a very old (about 20 years old) Enya 40 engine. I use it on a Hirobo sky trend.
I wanted to buy a new engine that will give me more power and will take me to the next level of planes.
The one thing I'm not interested in is frequently adjusting the engine and having to use only best quality fuel. Is that the case with the rossi 40 engines? Is the rossi 40 comparable to the OS 60 engines? (As was claimed by the shop I'm buying at).
thanks again for your help
Ari
Old Jun 03, 2004, 03:09 AM
North-East England
Joined Mar 2002
The power is probably comparable with a 'cooking' 60, but at a price - and not only financial.
The Rossi motors, as Mode 1 suggests, can be a temperamental engine as most thoroughbreds are. It's not an everyday use motor and requires some experience to run consistently (and not always possible).
There are advantages of using a high power/ lower weight motor but consistency is probably better for your needs.
I'd go for the motor which starts easily and runs reliably. It needs to have a consistent idle and good pick-up. There's no substitute for those items. It's similar to Formula 1 and any other vehicle. You can use F1 for one use only but it's no use in everyday traffic where there is a wide range of others all reasonably happy.
I'd go for the Rossi only because it's a lovely motor, makes a great noise and is totally impractical (I've a small collection of such motors - no real application for them, but I like them).
Old Jun 03, 2004, 08:23 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
If you are new to engines get the OS max. The .46 will give you a nice boost. You might also want to consider the Irvine .53 from Just Engines in the UK. Awesome little engine!
Old Jun 03, 2004, 11:26 PM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
I've got the Rossi 45 but it should be similar to your 40. It starts first flick every time on zero nitro fuel and I treat it just like any normal sports engine and it's never let me down. I use an 11x6 prop because I'm not looking for speed but I know it'll handle an even bigger prop if I wanted to use one. The idea that they're only good at high revs is quite wrong. If you get a Rossi then take off the backplate and admire the engineering and machining
downunder is online now Find More Posts by downunder
Old Jun 03, 2004, 11:42 PM
mode1 is offline
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Go to your local rc flying field. Observe what other flyers are useing with good results. Ask lots of questions.
Old Jun 04, 2004, 08:25 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Don't get me wrong I love the Rossi engines - they are nearly works of art. But I will disagree with you all day long about being as newby friendly as OS. They simply have the easiest to start and run engines for new fliers.
Old Jun 04, 2004, 03:24 PM
ETIGER05 is offline
Find More Posts by ETIGER05
Joined May 2004
motor reliability
pda4you is quite correct . Os will give you reliability. where they screwed up is with their remote needles . TT46 is not a bad motor for the money either no hesitation recommending them. .ST- Ive had great luck with the 40-45 . some others havent
ETIGER05 is offline Find More Posts by ETIGER05
Discussion os .46ax vs magnum xls .52 Crashinator Engines 3 Jul 25, 2007 07:57 PM
Question ASP40 vs OS 40 vs Enya 40 etc... ExtremeSkyes Fuel Plane Talk 4 Jul 08, 2006 04:10 PM
Discussion OS .46AX in Four-Star 40 squeakywaffle Beginner Training Area (Fuel) 7 May 12, 2006 10:01 PM
Better than new motors (Rossi .40 & .46, OS .46LA) Jeff_Berg Aircraft - Fuel - Airplanes (FS/W) 7 Oct 11, 2004 11:01 AM
Aveox DS-40 Vs Castle Dragon 35 mickydee Electric Plane Talk 0 Sep 22, 2001 02:27 PM
