Old Jan 11, 2002, 06:09 PM
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Brushless motors;Can they be set up in a multi motor project??
I 'm reading all the good things about these new motors and wonder Can i set them up in a multi motor project?? like say 6 motors? i have a Gigant project on the summer horizon any comments would be great.Many thanxs stefanP
Ghost rider requesting a fly by...............
KOMET 44 is offline Find More Posts by KOMET 44
Old Jan 11, 2002, 07:53 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Yes. Either with separate ESC's or in parallel using a sensoreless ESC.
Check out the Russian B-29 copy (TU-54?) pictured on the MaxCim web site.
jrb is offline Find More Posts by jrb
Old Jan 12, 2002, 04:20 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Focke Wolf Ta400 & 6 (six) lrk-torquemax brushless motors
Have a look and a read at this 6 motor beast by Soren Kjaer Nielssen:
http://users.cybercity.dk/~ccc16084/ta400a3.html
My FW Ta 400 have the following data:
  • Build comlete in balsa covered with epoxi and light fiberglass (a few parts will be in waccum formed plastic).
  • Wingspan 4,35 m (app. 14.5‘)
  • Target weight is 12-14 kg.
  • 6 pcs. Robart mechanical retracts
  • Fowler flaps (can’t find information about the flaps on the real plane) I build the plane with fowler flaps because these flaps are a challenge to build, and they look and work very good in the air)
  • Motor: 6 pcs. S600 race 7.2v, 4.8:1 gearbox, 13x10 props (that is my standard motor/gearbox – if you have one of these motors, use it with a highrate gearbox, a big prop, and 10 cells…wow!!!) That was my target, but then Graupner, that supply this motor, changed the motor: The new S600 RACE 7,2v is not the same as the good old one !!!
    Therefore I have changed the 6 motors to homebuild brushless LRK 345-20 motors with homebuild speedy BL controllers, look at: LRK. and at: Speedy BL.
  • 60-72 RC2400 cells. (10-12/motor).
  • Expected flying time: 10 – 12 min
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Discussion gws brushless motors for war bird set up? racer_dan GWS (Grand Wing Servo) 5 Aug 07, 2007 01:30 AM
Question Can the HoneyBee CP2 be set up as an FP? Retrorocket Micro Helis 13 Jan 18, 2007 10:32 AM
Kontronik ESC's-- Can they be used for any dual brushless? Clayton Power Systems 1 Feb 01, 2003 12:00 AM
Question receiver antenas, can they be attached like with a connector of some sort? dave rave Power Systems 0 Feb 08, 2002 01:41 AM
