Old Jun 01, 2004, 11:11 PM
MagicFlyer is offline
Find More Posts by MagicFlyer
Atlanta
Joined May 2003
Katana 1.40
I am looking for an awsome power setup for the cheif aircraft Katana. I was playing with moto calc and found the b5014xl with 30 cells or a 8s4p on a 20X12 prop was a good combo. My ? is, is this the best motor and can it handle 30 cells. I would like to stay with one motor.
MagicFlyer is offline Find More Posts by MagicFlyer
Old Jun 01, 2004, 11:24 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
From a thread a while ago when I was trying to figure out how to electrify it:
"are you looking for a cheap solution? If not, a Hacker B50-14XL, 5.2, 17x10 and 24 cells should power this plane pretty well but it depends on the AUW. I had a 70" Extra powered with this system. It is now being powered with Lipos and flies extremely well.
-- Kyle"
This was in reference to a H9 Cap 232 72 incher... so I'm assuming it would be fine for this one as well....
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Jun 01, 2004, 11:28 PM
Arbo is offline
Joined May 2000
Ah, and a fellow atlanta flyer had this for input:
"I was just running some numbers on this setup. If you only wanted sport flying, you could power it with a Mega 22/30/2 geared 4.6 in a MEC Superbox swinging a 16X10 on 19 2600's. This would give you just over one to one and keep your amps around 58.
Here is what Motocalc predicts:
MotOpinion - Katana
1000ft above Sea Level, 29.92inHg, 80F
Motor: Mega AC 22/30/2; 1770rpm/V; 2.6A no-load; 0.014 Ohms.
Battery: Sanyo HR-SC2600; 19 cells; 2600mAh @ 1.2V; 0.004 Ohms/cell.
Speed Control: Castle Creations Phoenix 80; 0.001 Ohms; High rate.
Drive System: Model Electronics 4:1 Gearbox; 16x10 (Pconst=1.31; Tconst=0.95) geared 4.6:1 (Eff=95%).
Airframe: Giantscale Katana; 992sq.in; 146.9oz; 21.3oz/sq.ft; Cd=0.049; Cl=0.45; Clopt=0.58; Clmax=1.11.
Stats: 116 W/lb in; 99 W/lb out; 23mph stall; 32mph opt @ 54% (24:26, 108F); 37mph level @ 60% (20:39, 111F); 1976ft/min @ 44.3; -294ft/min @ -6.
Power System Notes:
The full-throttle motor current at the best lift-to-drag ratio airspeed (55.4A) falls between the motor's maximum efficiency current (52.5A) and its current at theoretical maximum output (532.3A), thus making effective use of the motor.
The voltage (18.3V) exceeds 12V. Be sure the speed control is rated for at least the number of cells specified above.
Aerodynamic Notes:
The static pitch speed (63mph) is within the range of approximately 2.5 to 3 times the model's stall speed (23mph), which is considered ideal for good performance.
With a wing loading of 21.3oz/sq.ft, a model of this size will have trainer-like flying characteristics. It would make an ideal trainer, for use in calm to light wind conditions.
The static thrust (158.3oz) to weight (146.9oz) ratio is 1.08:1, which will result in extremely short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and vertical climb-outs. This model will probably be able to perform a hover or torque roll.
At the best lift-to-drag ratio airspeed, the excess-thrust (98.6oz) to weight (146.9oz) ratio is 0.67:1, which will give steep climbs and excellent acceleration. This model should be able to do consecutive loops, and has sufficient in-flight thrust for almost any aerobatic maneuver."
Old Jun 01, 2004, 11:37 PM
Atlanta
Joined May 2003
Yeah I did find the thread and I guess Ill just have to wait till i get the plane from you at seff and total the weight of everything
Old Jun 02, 2004, 01:15 AM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
MagicFlyer
If the plane is a 140 size, then the power system won't be enough. Do you know the weight that they spec? I would assume that this plane is around 12lbs+ for glow.
In any case, if it is a 140 sized plane then you want a C50-14XL, 6.7:1, 10s3p or 10s4p Lipo, and a 22x12 APCe prop. You'll have a 2400 watt system and excellent performance.
-- Kyle
kmashima is offline Find More Posts by kmashima
Old Jun 02, 2004, 02:19 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Ln, Ljungby
Joined Jan 2001
C50 14XL 6.7:1 APCE 20x13 on 30x2600 gave very good sportflying capabilities for my 14lb 1/4scale extra. no 3D but 8min of aerobatics. ~1700watts in. very mild setup for this motor.
henke is offline Find More Posts by henke
Old Jun 02, 2004, 08:37 AM
Atlanta
Joined May 2003
The plane is 11-11.5 lbs glow and I found in another thread where the owner said the naked airframe weigh 92 ozs.
Old Jun 02, 2004, 08:47 AM
Arbo is offline
Joined May 2000
That's about 5 3/4 pounds? Not far off.. The problem is the cowl is heavy (i think), and the gear is almost a pound by itself, so carbon gear would work better and save loads of weight... I don't think there's too much else that could be done, but between carbon LG and making a plastic cowl (strech method over the current cowl) I think you'd hit under 5 pounds easy...
Paul
Old Jun 02, 2004, 09:16 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
Magicflyer
so the setup I suggest would be perfect. You'll have ballistic performance - more than 200 watts per pound.
-- Kyle
Old Jun 02, 2004, 09:31 AM
Atlanta
Joined May 2003
Would 30 cells work on that same setup Kyle and how many amps would it draw for the lipos. Would it be possible to use like an 8s pack.
Old Jun 02, 2004, 09:39 AM
Atlanta
Joined May 2003
One more thing, would it be possible to use the acro 12xl and 8s4p to save on weight. I would like to stay with those batts if possible. I cant find the c50 in motocalc.
Old Jun 02, 2004, 08:44 PM
Bill K. is offline
Find More Posts by Bill K.
Husband, Dad, Skydiver, RC'r
Bill K.'s Avatar
United States, NC, Waynesville
Joined May 2002
Originally Posted by kmashima
MagicFlyer
-- Kyle
Kyle,
Would this plane 3D on that setup?
http://www.chiefaircraft.com/cgi-bin.../CAYAK-54.html
Bill K.
Bill K. is offline Find More Posts by Bill K.
Old Jun 02, 2004, 08:48 PM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
You can estimate the C50XL with a B50XL. The issues is watts = volts x amps. It's always more efficient to get the watts from more volts and less amps since the amps tend to turn into heat. It will be a matter of how much power you want. If the model is 12lbs and you want 150 watts per pound then = 1800 watts. 8s = about 4v per cell = 32 or more like 30 volts. 1800 watts/30 volts = 60 amps. This is well within the limits of a 4p pack. How much power you want is a matter of expectations. I don't know what you fly. You can also fly this with 30 cells. It should work OK.
My 3W Xtrafun is 12 lbs and 80 inches. I flew it initially with 30 cells and then with a 10s4p setup. It flies very well. You can pull out of low hovers with no problems. It is also generating more like 2300 watts or almost 200 watts per pound.
The problem with an aerobatic plane is that you need both pitch speed and thrust so you can't trade them off like you can with a pure 3D, fat wing, low wing loading plane that doesn't need to fly very fast. These planes can be gears for big slow turning props for max thrust. So the watts per pound can be much lower and still be good flying.
-- Kyle
Old Jun 02, 2004, 08:59 PM
Bill K. is offline
Bill K.'s Avatar
Joined May 2002
Kyle,
What would you recommend for this plane:
http://www.aero-works.net/store/detail.aspx?ID=192
It's bigger brother also:
http://www.aero-works.net/store/detail.aspx?ID=195
Would you do the smaller one on a B50-XL something? It's 7-9 LBS, and the bigger one says 11 to 12 LBS...
Sorry to keep coming back, just trying to learn, hoping to start on something in this range soon...
BK
Old Jun 02, 2004, 09:03 PM
Rob Honeycutt is offline
Find More Posts by Rob Honeycutt
Extra 330L
Rob Honeycutt's Avatar
Pawleys Island, South Carolina
Joined Apr 2002
a lot of the planes that chief has are the same as giant scale planes.com like the katana.. I noticed that they were pretty heavy when I saw them at a show last year...
The new electric funtana 140 size is supposed to be out this month sometime and I would hope it might be nice and light? It is purple and white like gary wright's model and ready for a hacker!
Rob Honeycutt is offline Find More Posts by Rob Honeycutt
Sold CMP/GSP Katana 1.40 RCFEVER Aircraft - Fuel - Airplanes (FS/W) 0 Mar 05, 2007 04:55 PM
Discussion katana 1.40 redflyboy122 3D / Fun Fly Fuel Planes 3 May 24, 2006 11:48 AM
For Sale Katana 1.40 MagicFlyer Aircraft - Fuel - Airplanes (FS/W) 6 Nov 25, 2005 08:27 AM
GSP Katana 1.40... best powerplant? RCFEVER Giant Scale Airplanes 37 Feb 11, 2005 06:58 AM
FS: CMP/GSP Katana 1.40 ARF N925WB Aircraft - Fuel - Airplanes (FS/W) 8 Sep 28, 2004 04:37 PM
