Old Jun 01, 2004, 08:12 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Pictures: Please read this
If you want to post your pictures then they must be two things:
1. About 640pixels wide or less
2. A small file size
I don't intend to bust anyone for a 641pixel wide picture and this is only rough but there are far too many huge pics appearing. All you have to do is resize/resample your image in a paintshop type program before optimising a little. Photos should be saved as Jpegs, something around 75-80% on the quality when it comes to export is normally OK.
Graham
p.s. Anyone who might know some simple and free software for this process or likes a particular package then please post.
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jun 01, 2004, 08:41 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
JPEG Optimizer from http://www.xat.com is a nice tool for reducing the file size of pictures by increasing compression.
Michael
epilot is offline Find More Posts by epilot
Old Jun 01, 2004, 12:36 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
There is a WindowsXP PowerToy named "Image Resizer" which can be downloaded for free on the Microsoft webpage. It works by right-clicking any image, then choosing "Resize Image". Choose "small". The image size is usually around 40kb. The nice feature is that you can even use this tool in the file select box which appears when you choose a picture for uploading, so there is no excuse like "I was just in a hurry".
I have to confess that I sometimes have chosen "medium".
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Jun 01, 2004, 12:45 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Here's the most readily available way to do it. Virtually every Windows computer comes with an application called "paint" which generally can be found under the "accessories" group from the "start" menu. It is a very simple paint program. Just open up your jpg file from within paint, then go to the "image" menu, the choose "stretch/skew" and type in numbers like 30 (for 30% in both "horizontal" and "vertical" boxes, which will shrink the photo to 30% of its previous size in that dimension. Save the file as a new name, and upload this smaller file for your picture in a thread.
Or, go download one of the resizing utility programs mentioned above. The only advantage of "paint" is your computer almost certainly already has it.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jun 01, 2004, 01:05 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
To me, the major problem is that when a picture or drawing excedes 640 pixles, the text box above it is increased to the same width. It is a royal pain scrolling side to side to read the post, which is now in long lines, which are also difficult to read. I am a bit surprised that the ezone software even allows excessivly wide pictures because of that. I would think it could be "globally" controlled to just chop the picture off. Posters would get the idea quick enough. {off soapbox}
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jun 01, 2004, 01:12 PM
Sticky Shepherd
Oxford/England
Joined May 2001
I aggree Dave!!
So A: resize less than 640 (600 better for printing I think) and B: compress for small file size.
RCgroups has the latter sorted but not the former.
Graham
Old Jun 02, 2004, 12:12 AM
bleriot 11 is offline
Find More Posts by bleriot 11
Cannes Mandelieu, France
Joined Jun 2003
how to resize videos?
patrick.
bleriot 11 is offline Find More Posts by bleriot 11
Old Jun 02, 2004, 03:38 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Videos are genrally going to be too big to attach but there is a nice bit of software called virtualdub that is free and can be used to convert video into DivX and also compress it if it needs to be. It is much better to get some free webspace and put the video there most of the time.
Graham
Old Mar 11, 2005, 12:15 PM
Boston, Mass
Joined May 2001
I just stickied this thread so people who may not have seen it some time back can read it now.
Gordon
Old Mar 12, 2005, 01:23 AM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Picasa 2 from Google allows you to export your pictures into any size and compression you want.
Daniel G is offline Find More Posts by Daniel G
Old Mar 12, 2005, 10:51 AM
watersharer is offline
Find More Posts by watersharer
Time wounds all heels.
Phoenix, AZ
Joined Jul 2001
I use GIMP.
Its free (open source), frequently updated and improved, and much more powerful than I really need.
Plus its a small download.
www.gimp.org
watersharer is offline Find More Posts by watersharer
Old Mar 12, 2005, 01:48 PM
Josh_high_flyer is offline
Find More Posts by Josh_high_flyer
London, England
Joined Dec 2004
I think paint is the easiest
Josh_high_flyer is offline Find More Posts by Josh_high_flyer
Old Mar 12, 2005, 02:23 PM
Bschulz is offline
Find More Posts by Bschulz
Eat, Sleep, Fly..........
Waukesha, Wisconsin, United States
Joined Jun 2003
Just thought I'd add my advice, there's plenty here already but.. I found a generally easy way to do this is Powerpoint. No extra downloading and the result is a picture with good quality and in most cases a file size well under 100kb.
Just open a new blank slide
Goto "Insert" on the toolbar menu
Chose "From file" under "Picture"
Find your picture and insert
Resize it (a bit smaller than the slide itself works out well for RC groups)
Go to "Save As" under "File"
Give it a name, then below that textbox in the "Save as Type"..
chose JPEG File Interchange Format
and save!
Make sure you remember where you saved it!
Brandon
Bschulz is offline Find More Posts by Bschulz
Old Mar 12, 2005, 05:49 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
I like Compupic Pro from Photodex, its a file manager as well as an image manager. You can adjust/resize/convert image's, open /read/modify images/text docs from within zip archives too try a 30day demo http://www.photodex.com/downloads/
some Linux/Mac support too.
Stewart
clipclop is offline Find More Posts by clipclop
Old Mar 13, 2005, 11:04 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
I am a screen shot junkie!!
We use Irfanview, it is free and a wonderful photo program, it will resize and
keep quality even in a small file!! You can add effects or correct color or
about anything else you need to do!!
Just do a search at Download.com!!
Kimber is offline Find More Posts by Kimber
Cybird Update.... [please read this post] pascal Ornithopters 7 Jul 27, 2003 07:25 AM
Please read this.....Is anyone out there using netscape as there browser? kushal_22 Parkflyers 21 Feb 27, 2003 02:26 PM
Before you post here, please read this thread. Andy W Beginner Training Area (Aircraft-Electric) 0 Dec 07, 2002 06:45 AM
If you were cheated by Shawn @ eflightpower....please read this rcdude Vendor Talk 32 Feb 27, 2002 09:49 PM
PLEASE READ THIS before posting yet another "too many forums" topic! Andy W Site Chat 0 Oct 05, 2001 08:15 AM
