Old May 02, 2001, 12:19 AM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Micro ESC that can handle 10 cells???
I have a new robin heli, and during this learning process I'm going through quite a few battery charges. Unfortunatly, I'm using tadirans on the Robin and my charger takes 10 hours to recharge them. So I purchased 3 12 volt 4aH batteries to run my Robin teathered to. However my ESC is only rated at 8 cells, but 12 volts equates to 10 cells. What can I do? I need a 5-7 amp controller with 12 volt operation with BEC.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old May 02, 2001, 12:56 AM
Make Haste Slowly
realdeal's Avatar
USA, KY, Lexington
Joined Nov 1999
How many servos do you need to run? Since you're eliminating the weight of the power batteries it may be easier, safer and a more realistic practice to just put a receiver pack onboard for tethered flights.
There are a few ESCs like the Castle Creations Pixie 14 and the Jeti 110 that are fairly small and handle 10-cells with BEC, but they are limited to 2 or 3 servos when operating on BEC. This is even more critical when talking about a helicopter as the servos are in constant motion.
Keith
realdeal is offline Find More Posts by realdeal
Old May 02, 2001, 01:52 AM
Chilliwack, Canada
Joined Sep 2000
This esc is kinda large for your heli but the great planes c 30 can handle 30 amps , 10 cells 4 servos and weighs .7 ounces.
fourstarforty is offline Find More Posts by fourstarforty
Old May 02, 2001, 02:48 AM
Austin, Texas USA
Joined Mar 2001
And the C-30 is cheap. I have heard good things about it, especially for the price.
sf_247 is offline Find More Posts by sf_247
Old May 02, 2001, 06:44 AM
Let's Fly
gbagley's Avatar
Metairie, Louisiana
Joined Apr 2001
http://www.officeshops.com/esc.htm
Hi jim,
I have some speed controllers that handle 6-10 cells. both 15 and 30 amp. However, i do not know how many servos they can handle. Does anyone reading this know if these will work for him?
-gerald
gbagley is offline Find More Posts by gbagley
Old May 02, 2001, 07:11 AM
Joined Aug 2000
-gerald
Thanks, those ESC's are a bit big, and have a brake. A brake is about the worst thing you can do to a heli.
What are you guys with 10 cell IFO's and Tiny's flying with?
-Jim
Old May 02, 2001, 11:11 AM
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
The SIRIUS GFS will handle 16 cells and up to 10 amps (unofficially 14 amps)
It has a 1.5 amp BEC and weighs 1 gram without wires.
Not good for tail rotor control though as the filter software was the trade off for less throttle steps.
frankenfoamy is offline Find More Posts by frankenfoamy
Old May 02, 2001, 11:12 AM
niek's Avatar
Almere, Netherlands
Joined Mar 1999
Schulze has a new one, the shulze slim10.
niek is offline Find More Posts by niek
Old May 03, 2001, 12:10 AM
Joined Aug 2000
That Sirius GFS looks perfect! I've already got the tail rotor ESC, it doesn't have to have BEC so I'm using a GWS 2 amp control. Thanks for the suggestions.
-Jim
Question Are there Nicad chargers that can handle 50+ cells in series ? Protocooler Batteries and Chargers 4 Nov 09, 2005 07:54 PM
Wanted Brushed ESC that can handle 60 amps+ Vamooska Aircraft - Electric - Airplanes (FS/W) 5 Sep 28, 2005 09:13 PM
WTB: an esc that can handle around 10-12 turns. bassplay Cars - Cars and Parts (FS/W) 0 Jul 09, 2003 01:44 AM
Lightest ESC that can handle 3 servos V-Raptor Parkflyers 4 Oct 23, 2001 12:15 PM
Graupner 480 with inline 4:1 geared: can it handle 10 cells? Ryan Nau Power Systems 4 Jun 07, 2001 07:27 PM
