Old May 29, 2004, 09:35 PM
RobDog is offline
Find More Posts by RobDog
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
Need help cnc foam cutting tapered wings
Hi,
I have been cutting constant cord wings and depron planse for some time now with a foamlinx cutter using the Giles GMFC software. But everytime I try to cut a tapered wing win any sweep to it, the software gives me a -(insert value here) error. I can see on the approximation display that the software "thinks" the wire is going to go below the cut point, but even when I specify for the block to start cutting higher it has issues. I got one to attempt a cut recently using a custom drawn airfoil and one side stayed still while the other appeared to be trying to catch up.
Can anyone send me a sampe .cnc file for doing this? I feel like a moron.
Thanks in advance,
Robert
RobDog is offline Find More Posts by RobDog
Old May 30, 2004, 03:19 AM
max z is offline
Find More Posts by max z
max z's Avatar
The Netherlands, ZH, Boskoop
Joined Mar 2001
Are these -X or -Y errors? How did you specify starting higher?
Maybe you could email me a typical .cnc file that displays the error, and your table configuration file ( "default.bd" or "<tablename>.bd" file, to be found in whatever installation directory you defined in GMFC under GMFC>files>installation directory. ), and I can try to find the cause of your error messages. I'll send you a PM with my email adress.
Max.
max z is offline Find More Posts by max z
Old May 30, 2004, 07:31 PM
averen is offline
Find More Posts by averen
Love my Pike Superior!
averen's Avatar
Austin, TX
Joined Jul 2003
This could be a couple of things
Your cutting speed might be too fast...try slowing it down.
Depending upon your setup you might need to move the foam block around on the table to cut the taper. I like to keep the root close to one of the axis...but sometimes if the taper is high I have to move the foam closer to the center of the table...and sometimes even closer to the rear of the table...depending upon the taper...
If you could take a screen shot of GMFC when it's giving you this error it would be helpful
Averen
averen is offline Find More Posts by averen
Old Jun 01, 2004, 01:16 PM
RobDog is offline
RobDog's Avatar
Tampa, Fl
Joined Jan 2002
I think I got the error message problem solved. I cut the block raised up about 8 inches of the table, but did not have that set in GMFC. I've now set that and it worked out for getting the cut to start. Now my problem seems to be the heat on my wire is WAY to hot to go as slow as it has to go for the cut. I'll have to get a smaller output (rehostat?).
Thanks guys,
Rob
Foam cutting tapered wings splatman The Builders Workshop 14 Jul 15, 2005 07:17 AM
More CNC foam cutting help please! corey The Builders Workshop 1 Jan 02, 2005 09:02 PM
Need Help to Find Foam cutting and cuter Guide Here.. nuspeed88 Foamies (Kits) 1 Dec 23, 2004 11:37 AM
need cnc foam cutting info new flyer The Builders Workshop 33 Nov 29, 2004 10:04 AM
CNC Foam Cutting Avro Vendor Talk 0 May 26, 2002 11:39 AM
