Old May 28, 2004, 05:13 PM
bobbart is offline
Find More Posts by bobbart
Joined Nov 2003
***Help on Battery for GWS A-10*****
What Battery should I purchase for GWS A-10 EDF-55? I'm looking for engine power.. I'm getting so many suggestions that I don't anymore. The hobby shop told me to purchase Li-Poly 1200 7.4, can I go higher? Again I'm looking for engine power without burning the motors out. Also, I have a GWS gs-100 SPEED CONTROLLER....will this speed controller have anything to do on what size battery I get? If you can help me on the best battery and Quick field charger to purchase. The hobby shop has the Li-Poly 1200 7.4 for $60.00 and the Hobbico Quick field charger for $80.00....if you have a suggestion, please let me know and place to purchase online.
Thanks so much
Bob
bobbart is offline Find More Posts by bobbart
Old May 28, 2004, 06:56 PM
Bthree is offline
Find More Posts by Bthree
NW Victoria Australia
Joined Sep 2003
The GS-100 will only just do one motor you will need another one the same or a 15-20amp speed controller to run both, stick to Nimh batteries.
If you are going for LiPo batteries you will need a speed controller with low volts cutout to suit a LiPo CC Pixie 20 or Jeti JES-020 (GS100 will kill a 2cell LiPo and murder a 3C)
2 cell LiPo will not give you enough power for this bird, a 3cell will work or 9 or 10 1050mah Kan cells but for better performance a Tanic or similar 3C 2200mah will really work.
http://www.aircraft-world.com have all you need and fast.
Bthree is offline Find More Posts by Bthree
Old May 28, 2004, 07:48 PM
bobbart is offline
Joined Nov 2003
Bthree Help again
I can't find the Tanic or similar 3C 2200mah. Can you please point me to this Battery. Also what speed controller should I get? does the servo s matter?
I purchase 3 sub-micro servos for this plane. Thanks for your help
Bob
Old May 28, 2004, 08:20 PM
Bthree is offline
Joined Sep 2003
On site above, Poly-Quest AC-PQ1500-3S or AC-PQ1800-3S or AC-PQ2200-3S
Servos will be fine, you only need two !
Cheapest option (but not as good) is to purchase another GS-100 (then you have one for each motor, use a Y lead from Receiver to the two GS-100s) and run a set of 9 or 10 KAN cells, people are getting good results on the GP equiv. do a search around for recent threads
Old May 28, 2004, 08:46 PM
bobbart is offline
Joined Nov 2003
Bthree question again ???
I understand the battery part now. what if I don't use the two ICS-100 speed controllers, what other better option do I have?
Can you point me to the site and part #.
Thanks so much
Bob
Old May 28, 2004, 08:49 PM
Orcoz is offline
Find More Posts by Orcoz
Clueless, but trying
Orcoz's Avatar
United States, CA, Walnut Creek
Joined Nov 2001
What is your budget? I'm on the cheap side, but you could check out the combos at e-flightline.com
Orcoz is offline Find More Posts by Orcoz
Old May 29, 2004, 01:22 AM
billsmithjr is offline
Find More Posts by billsmithjr
billsmithjr's Avatar
Amishtown, Maryland
Joined Sep 2003
My advice- Get a FMA lipo specific esc , you can set it to one to four cells . I recommend a 20 amp controller.The Gws 100 doen't even come close to what you need and getting another ,one for each motor, doesn't make sense when ten more dollars will buy the one you need.I've been flying mine on a 3s 2100 lipo for some time now (six plus hours now on motors) and I get great performance without any problems . I've heard some arre using 2s 2p 1350 but I'm almost sure that I'm getting better performance but I think I am stressing the battery (comes back hot !) 2s 2p users report cool batterys.
billsmithjr is offline Find More Posts by billsmithjr
Old May 29, 2004, 03:18 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
www.GWSExpert.com Mr. Jerry Chen use a 1s3p 2000mAh Li-Poly cells pack. He said this will fly more than 15 minites!
GWS4CEO is offline Find More Posts by GWS4CEO
Old May 29, 2004, 04:23 AM
bobbart is offline
Joined Nov 2003
******Confuse
OK, lets say I purchase this battery for my GWS A-10 EDF-55....Poly-Quest 10C Lithium-Polymer 2200mAh 3S PACK (11.1V, 22.0A) at
http://www.aircraft-world.com/shopdi...ithium+polymer
What 20 amp speed controller would you recommend? Please state site and part #.... since I'm confuse.
Thanks again
Bob
Old May 29, 2004, 05:27 AM
Bthree is offline
Joined Sep 2003
From Aircraft the Jeti JES-020 would be good only they are out of stock, the FMA above sounds good also.
You would need Deans Ultra connectors on the Battery
A slightly smaller 1800 poly-Q would also do the job, and a 3cell LiPo charger is required.
Old May 29, 2004, 04:51 PM
bobbart is offline
Joined Nov 2003
Bthree
Can you please give me a part number for the Jeti JES-020 and the FMA.
Also a part number for the Deans Ultra connectors on the Battery
I don't want to order the wrong items....this hobby is costing $$$$$$.
Thanks so much
Bob
Old May 29, 2004, 11:45 PM
dbl8ts is offline
Find More Posts by dbl8ts
dbl8ts's Avatar
Kansas City
Joined Apr 2004
Thanks so much
Bob
Bobbart:
Try www.hobby-lobby.com Part # JES020 @ $39.90; or,
www.castlecreations.com and look for the Pixie 20 ($39.95); and, I believe Tower Hobbies carries the FMA line www.towerhobbies.com. Whichever site you select, do a search on the site. It will take you directly to the item and part #. Also, try www.gwsexpert.com and search there if you would like to stay with the GWS ESCs. A 300 should do; however, with Li-pos, you may need the 400-480.
Blue skies and calm winds!
P.S. Which EDF-55s do you have? The 150s or the 300Hs. In previous threads, flyers were reporting good results with 2s Li-Pos on the 150s. 3s is tricky and can fry em up. Alternately, the 300H motors do not run for any appreciable flight time. One even described it as a long coast (from hand launch) to the ground. Here, the 3s Li-Pos work well with ATV and/or throttle management. With either, you cannot go wrong with MiMHs, but GWS did not include NiMH nor Ni-CAD recommendations in the EDF-55 kits, nor AUW and CG location.
dbl8ts is offline Find More Posts by dbl8ts
Old May 30, 2004, 05:50 AM
bobbart is offline
Joined Nov 2003
****Tell me If I have this correct Please****
I have the EDF-55 300H
1. I will need to purchase a Poly-Quest AC-PQ2200-3S (11.1V, 22.0A)
2. I will need to purchase a Jeti 20 Amp Microprocessor Motor Controller
( For 4 to 8 Ni, 2 to 3 Li-Po cells, 20 to 22 Amps )
JES020 www.hobby-lobby.com
Do I need a Deans Ultra connectors for the above setup? if so, what site?
Will the above work well with my GWS A-10 EDF-55 300H? I don,t want to cause more problems by going with the above items.
Bob
Old May 30, 2004, 08:28 AM
Bthree is offline
Joined Sep 2003
You can get the Deans Ultra from aircraft, you will need a male for the speed controller, a female for the battery, and a male for the charger.
If you go with the LiPo 3C batteries remember you will need the correct type of charger ET-SMARTCHG-4 .. NEW! Li-Poly Safe 1-4 Cell SMART CHARGER 250-2500mA, from Aircraft @ $49.95 will do, DON'T use the older chargers meant for Nicad or Mimh batteries
Old May 30, 2004, 03:22 PM
bobbart is offline
Joined Nov 2003
Thanks Bthree and others for your help..below are the Items
Thanks so much Bthree and others for your help....
Below are the items that I will purchase for my A-10 EDF-55 300H
.......Is this correct before I make the purchase?
Thanks again
Bob
1. Poly-Quest AC-PQ2200-3S (11.1V, 22.0A) (from Aircraft)
2. Jeti 20 Amp Microprocessor Motor Controller (from Hobby-Lobby)
3. Li-Poly Safe 1-4 Cell SMART CHARGER 250-2500mA (from Aircraft)
4. Deans Ultra two males, one female (from Aircraft)
Need help deciding on LiPo for a Logo 10 e-heli Electric Heli Talk 8 Mar 14, 2005 01:39 PM
Need Battery for GWS P-51 austinflyer Foamies (Kits) 15 Jan 28, 2003 11:45 AM
Battery for GWS Zero CaptDH Foamies (Kits) 3 Oct 03, 2002 04:39 AM
Which Battery for GWS Zero Jholt Parkflyers 3 Jul 10, 2002 11:08 PM
RX battery for LOGO 10? fjhdavid Electric Heli Talk 1 Jan 21, 2002 11:22 PM
