Old May 28, 2004, 12:49 PM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
My Beaver Build
Thought I would try my hand at the DeHaviland DHC2 with maybe some Floats for the lake this summer. Here's the real thing that I am following for my build. According to the DHC-2 website, it is currently "docked" at Nestor Falls Ontario near Lake of the Woods, one of the best Musky Lakes in the world.
Several pics to follow……
Beagle
Flying Beagle is offline Find More Posts by Flying Beagle
Old May 28, 2004, 12:51 PM
Joined May 2004
Here are the mods that I did to the fuse. Opened up the motor wire hole a little larger for Deans connectors.(red line) I also carved an airway from the cowl to the battery compartment, (blue line) maybe this will help keep my KANS cool...
Beagle
Old May 28, 2004, 12:52 PM
Joined May 2004
I altered the battery box to fit my “brick” 8cell KAN 1050’s
Beagle
Old May 28, 2004, 12:53 PM
Joined May 2004
Here's my Beaver's feathers. I epoxied carbon rods at the hinges for strength, and also added a "U" wire under the tail. Tried something a little different with the elevator, instead of cutting it straight across, I altered the tips to look more like the real deal. I epoxied carbon tape on the underside for strength.
Old May 28, 2004, 12:55 PM
Joined May 2004
Here’s the Beaver Tail assembled
Old May 28, 2004, 01:01 PM
Joined May 2004
And here’s a close up of the stab and elevator…… not sure if this has a special aeronautical name…..?
Beagle
Old May 28, 2004, 01:02 PM
Joined May 2004
The stock main wing dry-fit……. at this point in the build I was waiting for my 350C…………
Beagle
Old May 28, 2004, 01:05 PM
Joined May 2004
I bought the sloper version of the DHC2 from one online store and then bought the motor and elec stuff from another place…..
but the 350C motor was on back order……
this gave me time to think……….
How ‘bout a 4 channel Beaver with ailerons ?!?!?!!!!
so I ordered a set of custom wings from barrettsrcplanes@yahoo.com Here’s the wing halves epoxied together with the ailerons cut out
Beagle
Old May 28, 2004, 01:06 PM
Joined May 2004
I chose to use one servo with linkages like the estarter, here’s the channel cut
Sorry for the fuzzy pics…..
Beagle
Old May 28, 2004, 01:08 PM
Joined May 2004
I read several threads on fiberglass techniques, so I thought I would give it a try. Here’s the wing with the glass laid onto the bottom side dry. I couldn’t find Varathane, but I did find a brand called Zar, the "Aqua" can clearly stated on the label Water Based Poyurethane (WBPU).....
Beagle
Old May 28, 2004, 01:10 PM
Joined May 2004
I just started in the middle and brushed the poly onto the wing, working out towards the edges. Then I used a credit card to scrape the excess off. This is easier than I thought!!!!!!
Beagle
Old May 28, 2004, 01:13 PM
Joined May 2004
After a couple of hours, the poly was dry enough to be trimmed with an exacto knife, the glass is easier to cut if you brush the poly off the edge of the wing into the weave….
Beagle
PS sorry for the pics, must have had the camera un-focused......
Old May 28, 2004, 01:15 PM
Joined May 2004
After glassing both sides, I mixed in baby powder with the poly for the next coat……., the key to avoiding a lot of sanding between coats is to “think thin” !!!! I learned this from my friend in the drywall business….
Beagle
Old May 28, 2004, 01:16 PM
Joined May 2004
While the wing dried, I cut down the fuselage to fit the full wing,
to compare, the farther side hasn’t been cut yet
Beagle
Old May 28, 2004, 01:19 PM
Joined May 2004
Here’s inside the fuse with gear installed
I really didnt want to use the rubberbands, so I bridged two pieces of balsa ply and inserted four 4-40 blind nuts, then used nyon bolts thru the wing
Beagle
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
My Beaver pc_pilot Parkflyers 5 Nov 17, 2002 01:56 PM
My Beaver Tenlado Parkflyers 17 Oct 29, 2002 11:58 AM
I fly my Beaver am I ready for my Spirit sailplane? spd37 Parkflyers 5 Aug 20, 2002 03:51 PM
My Beaver b0gh0s Parkflyers 10 Aug 14, 2002 08:31 AM
