May 28, 2004, 01:36 AM
Southern California
Joined Feb 2003
Hobby Lobby Super Cub--clipped wing
Hi guys,
Finally gave in and ponied up all of $32 for the kit. Really nice for the money, as the die-cutting for the ribs is nice and clean, and all the wood is really straight.
I figured it might be a little sedate for me, but I thought a clipped-wing version with big ailerons and a good brushless might be just the thing. My favorite gas plane (still hanging in the garage) is a 6' span Carl Goldberg Clipped Cub with a .91 4-cycle that was an absolute giggle to fly, and I want to re-create that in a smaller electric version.
Plans are for a Razor 400 in a GWS "C" gearbox swinging a 9x7 prop, powered at first by 3s1p Etec 1200s (thanks again, Shaun, over in Power Systems). A set of Trexler wheels/tires are a must too.
I've read all the horror stories about the wing folding, so I'll mount the struts more securely and go with either carbon-fiber dihedral braces, or just a stronger grade of plywood (the ones in the kit are light but flimsy). Looks like the cabin will need some beefing up, so I'll back the balsa pillars with bass wood. I'm going to really make an effort to strengthen only where necessary.
Here's progress so far. I'm going to use one aileron servo per wing. Outboard strut mounts will be plywood tabs that will glue in perpendicular to the ribs...you can see the balsa mounts I've glued in to accept them. Struts will connect to tabs with steel clevises, most likely. Wing feels nice and strong, even without LE sheeting.
I'm thinking of zero dihedral with the ailerons. Do you guys think this is good, or should I give it just a touch?
--Doug
P.S. I "clipped" it by one rib per panel, which takes the wingspan from 46" to about 41".
