Old May 27, 2004, 09:43 PM
GTOVR4 is offline
Find More Posts by GTOVR4
Vancouver Intl, Canada
Joined Apr 2004
question about soldering ESC&Motor
HI Guys
finally i am going to have my motor for Logo10 soon
but here is another question about soldering esc and motor together
also battery conneters
i hear about someone said the wire can not be cut on the ESC
and does any other thing i have to watch out? what kind tools
do i need and where can i need them?
looks likely it will be little different compare normal soldering...
i just want to make sure that everything goes right and try not mass up
anything.....since they are lot of $$$$$`~
thanks again for helping!!
GTOVR4 is offline Find More Posts by GTOVR4
Old May 27, 2004, 10:10 PM
lawrend is offline
Find More Posts by lawrend
RockFlyer
Cocoa Merritt Is, Florida, United States
Joined May 2004
It's not the ESC wires you should not cut, it's the wires from the motor. The motor wires are tinned from the factory to ehance soldering. Your speed controller wires should be kept as short as possible to reduce resistance. As for soldering, the wire is heavy guage and will require a soldering iron that is 45 watts or higher. I currently use a 75 watt iron with no problem. Just be sure to keep things clean with contact cleaner and use a high quality solder.
Dave
lawrend is offline Find More Posts by lawrend
Old May 28, 2004, 03:14 AM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
GTO, I was the one who asked about cutting ESC wires over in the Castle Creations Vendor Forum.. look for a thread titled "Phoenix 45 instructions.. translation, please?' The concern over cutting the motor wires seems to be aimed at those motors whose armature windings are simply extended outside the motor, rather than having a different, heavier gauge wire attached internally. Even though my AXI motor obviously has the heavier, more flexible leads, I left them full length and shortened the ESC motor wires instead, mainly because I have a C/F crutch on hand which will require a different layout for the ESC and motor. No problems so far.
BobRCnut is offline Find More Posts by BobRCnut
Question About Soldering Bullet Connectors on Himax and ESC grantorino Beginner Training Area (Aircraft-Electric) 8 Jan 27, 2006 12:35 PM
question about connecting wires to motor/esc tukkus Beginner Training Area (Aircraft-Electric) 2 Jul 25, 2005 07:57 PM
HELP: Soldering ESC to motor wires on a Hacker B40 Drivie Power Systems 11 Sep 20, 2003 10:55 AM
Question about POT 02a motor locking up. sky guy Parkflyers 3 May 29, 2003 07:36 AM
