Old May 27, 2004, 01:18 PM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Aveox F10 (36/15/1) and F10CS (36/24/1) vs. Hacker B50 6s on 10 cells
How does the Aveox F10 (36/15/1 w/ 3.7:1 GB) or the F10CS (36/24/1 w/ 3.7:1 GB) compare to the Hacker B50 6s (w/ 6.7:1 GB) on 10 cell in F5F competitions?
Regarding the Aveox motors without the integrated IMS 3.7:1 gearbox, what is required to install a 6.7:1 Maxon gearbox? Does it bolt straight to the motor or is a special adapter plate required. Also, as the drive shaft on the Aveox is 5mm, does Maxon have a pinion for this diameter shaft?
down_shift is offline Find More Posts by down_shift
Old May 27, 2004, 02:24 PM
sayno2glo is offline
Find More Posts by sayno2glo
I plan to take over world
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
You can't put 5mm shaft to any of Maxon boxes AFAIK. 3.2mm shaft maybe fits 5.2:1 maxon. Reason is that 6.7:1 has pinion milled directly to the shaft. When you compare two quality motors it's good to look weight and kv. if those match it's up to personal preference which one to choose.
/Antti
sayno2glo is offline Find More Posts by sayno2glo
Old May 27, 2004, 03:09 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
I looked at this before Russ, the Aveox motors suffer from low KV, and the need for a lot of cells to get the most from them, and the lack taller gearing in their gear boxes. I decided that by the time I buy the motor and the hassle of doing the gearboxes its just better to get the hacker/plett setups. The other option is to go with the F series of aveox.
What aveox needs is a 27/39/.5 and a 5.2/6.7 to one gearbox....
soholingo is offline Find More Posts by soholingo
Old May 27, 2004, 03:59 PM
down_shift's Avatar
Joined Feb 2003
Jay, how about the Aveox F10CS? This appears to be the 36/24/1 with an integrated 3.7:1 IMS gearbox. Again, attempting to use the B50 6s as the benchmark on 10 cells.
Old May 27, 2004, 04:39 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
You would have to ask Efren about this. But if his Victor is any indication of how fast the f10 makes a plane go the NIKE 2 on the b50 6s was faster.
Old May 27, 2004, 05:14 PM
rafaelABN is offline
Find More Posts by rafaelABN
rafaelABN's Avatar
Indialantic, FL
Joined Dec 2000
The F10 and F10C are not the same motor. I have all three the F10, F10C, and and Hacker B50 6S. I use both the F10C and the B50 6S with 10 cell and a 16*16, the F10C spins the 16*16 faster than the B50 6S. The F10C is a 36/24/1 with a 3.7 gb, the F10 on the other hand is a 36/15/1.5 with a 3.7 gb. In theory the 36/15/1 with a 6.7 gb also makes an interesting 10 cell combination at a really good price!, but I don't have one of those yet.
rafaelABN is offline Find More Posts by rafaelABN
Old May 27, 2004, 05:48 PM
down_shift's Avatar
Joined Feb 2003
Tell me more!! So the F10CS out turns the Hacker B50 6s on 10 cells on the RFM 16x16. Any chance you can tach the difference or have a current draw? I like the Aveox 27/26/1.5 and would like to stick w/ Aveox on the larger sizes. It is just that there does not seem to be many out there.
Old May 27, 2004, 06:03 PM
down_shift's Avatar
Joined Feb 2003
Jay, Efren was using the Aveox F12S which is the 36/24/1.5 (Kv 2580, Io 4.30, Rm 0.010, 120 amp peak). Prop was the RFM 15x15.
The F10CS uses the hotter 36/24/1 (Kv 3724, Io 5.40, Rm 0.005, 140 amp peak)
Both are permantly mated to the same german 3.7:1 gearbox.
Old May 27, 2004, 06:45 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Ok, that explains the speed difference. I wish you guys could have seen that nike fly....
Old May 27, 2004, 09:15 PM
rafaelABN's Avatar
Indialantic, FL
Joined Dec 2000
I used a tach to measure RPM, but I neither recorded the numbers nor measured current. All I have is an Astro meter not a clamp meter and at this power levels I don't want to risk it. IMHO, if your plane can handle the larger, then at $209 the 36/15/1, 3.7 or the 36/241, 6.7 is the way to go. The 27/26 series motor are fine for the smaller frames like the Smart or Banana. What plane do you have in mind?
Old May 27, 2004, 10:00 PM
eye_rc_soar is offline
Find More Posts by eye_rc_soar
corrupted - 17x18 or more
eye_rc_soar's Avatar
College Park, Maryland, United States
Joined Nov 2003
How does the Aveox 36/15/1 compare to the Hacker B50 6s on 10 cell in F5F competitions?
The 3615/1 with a 5.2:1 GB was reviewed by Steve Neu in the March Quiet flyer magazine. The motor does not become alive until you get above 80 amps and looks like it can handle about 1000 watts.
Repeating second hand information (from Dave Sieger), this motor is being used very successfully in European F5F competitions with 6.7:1 GB and 16x16 prop which has had the tip trimmed slightly.
I've got one of these motors with a 6.7:1 GB coming in to try out. We'll see...
Hopefully when Dave gets a chance from his traveling and flying with the San Diego group this weekend, he can comment.
don
eye_rc_soar is offline Find More Posts by eye_rc_soar
Old May 27, 2004, 10:22 PM
rafaelABN's Avatar
Indialantic, FL
Joined Dec 2000
From the labels:
Prop. RPM ~ KV / gb ratio
36/24/1: 3724/3.7 = 1006 RPM
B50 6s: 6150/6.7 = 918 RPM
However, the best way to compare is to measure RPM and current...[IMG]http://[/IMG]
Old May 27, 2004, 11:21 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Aveox F10CS
Hello:
The F10CS will be installed in our new Zoom F5B, for some serious testing..
We have heard very good reports on this motor. We can also have the factory make up different gear combinations.
Happy Landings!
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old May 28, 2004, 01:52 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
/Antti
Sure it is possible--you need the right pinion gear--I have done it. A turned down shaft from 5mm to 3mm and the stock IMS pinion fits just fine. FYI--all the gear boxes you are calling Maxon are in fact made from IMS parts.
Steve
sneu is offline Find More Posts by sneu
Old May 28, 2004, 07:28 AM
down_shift's Avatar
Joined Feb 2003
Steve
Steve, do the Maxon 6.7:1 gearboxes that come with the Hacker B50 have needle bearings for the planetary gears?
I believe the planetary gears on the IMS 3.7:1 gearboxes that are mated to the F10CS motors do not have bearings.
Is this correct? Any thoughts? Pro / con?
Wanted Mega 22/20/1, Hacker B40 8S or Aveox 36/15/1 tufnik Aircraft - Electric - Airplanes (FS/W) 1 Jun 01, 2005 03:39 PM
WTB> Aveox 36/15/1.5 Thavillan Aircraft - Electric - Helis (FS/W) 0 Mar 01, 2005 09:14 PM
WTB> Aveox 36/15/1.5 Thavillan Aircraft - Electric - Airplanes (FS/W) 0 Mar 01, 2005 09:14 PM
Aveox 36 15 1.5 + 6.7:1 tomv36 Aircraft - Electric - Airplanes (FS/W) 0 Jul 12, 2004 03:02 PM
almost new aveox 36 30 1.5 and new B50 11L FS or trade misskimo Aircraft - Electric - Airplanes (FS/W) 3 Jun 05, 2003 12:11 AM
