Old May 27, 2004, 09:40 AM
jfail is offline
Find More Posts by jfail
jfail's Avatar
Mesa, Arizona
Joined Sep 2003
C-47 and C-130 Availability
I got an e-mail from Andrew at GWS this morning saying that C-47's for early birds will ship late this week or early next week. C-130's will not ship until September.
Anyone out there flying the Multiplex Cargo that I can consult with on thrust alignment etc?
jfail is offline Find More Posts by jfail
Old May 27, 2004, 01:39 PM
MGBGTRacer is offline
Find More Posts by MGBGTRacer
RCAPA #005
MGBGTRacer's Avatar
USA, VT, Springfield
Joined Jan 2004
I fly a cargo- went 3 degrees downthrust from stock
MGBGTRacer is offline Find More Posts by MGBGTRacer
Old May 27, 2004, 05:03 PM
jfail is offline
jfail's Avatar
Mesa, Arizona
Joined Sep 2003
Hi Mgbtracer
Thanks for info. How did you make the adjustment for the 3 degrees? Also did you find the COG to be correct as per the manual and did you move it at all? How does the plane fly? I keep seeing references to a severe pitch up problem on throttle.
Old May 27, 2004, 06:35 PM
RCAPA #005
MGBGTRacer's Avatar
Joined Jan 2004
A toothpick wedged between the motor and the mount is about all there is to it. I will need to measure the CG, as I don't recall... it is such a forgiving plane that it can fly with the CG all over the place- loading it up with payload, cameras etc doesn't seem to change how it flies. I haven't found the perfect CG location because it doesn't seem to change how it flies when I shift the battery back or forth.
It still pitches up a lot with throttle and climbs like crazy- you have to lay the power on kinda scale if you want it to look scale. Sometimes in a small area with a pretty big plane, the ability to stand it on the tail quickly is a good thing. My speed control went out last time I flew it and it's grounded now until I can go through and fix the minor damage that occurs when the speed control nukes on final approach- taking the BEC with it. ouch
Old May 27, 2004, 08:27 PM
Catkicker is offline
Find More Posts by Catkicker
Nevada City, California, United States
Joined May 2004
mgbgt, would you say it would be a decent 2nd plane then? im learning on the estarter now, was thinking that the c47 would make a good 2nd plane if it were fairly easy to fly, but a lot of people into gas have kept telling me muli-engines are hard to fly. not sure if its the same with electrics.
Catkicker is offline Find More Posts by Catkicker
Old May 27, 2004, 09:28 PM
RCAPA #005
MGBGTRacer's Avatar
Joined Jan 2004
With electrics, I don't think multi-motors are really a big deal at all. What makes the glow multis kinda hard is if an engine quits or they don't sync well. That's not likely with electrics.
Not having flown the DC3, it's hard to say. The Cargo is like a big parkflyer if it is set up correctly, but the speed is a little surprising at first. Mine was radared at 64MPH. For a plane that size, that's moving pretty good and requires a LONG approach to land.
For a second plane, maybe the smaller Islander might be a consideration. I guess it just depends on how much space you have, but the videos I've seen of the DC3 show it to fly well.
Old May 27, 2004, 10:36 PM
Joined May 2004
ah, i thought you meant you had a c47 painted up as a cargo plane, didnt know there was another plane altogether
Old May 27, 2004, 11:36 PM
RCAPA #005
MGBGTRacer's Avatar
Joined Jan 2004
yeah- someone asked if anyone was flying a multiplex cargo... that's the plane I fly. I'll be getting a DC-3 too though.
C-130 Fat Albert Scheme? Troy Scale Kit/Scratch Built 29 Sep 19, 2016 11:53 AM
Questions and thoughts about Palmer Plans C-130 Lucas in Alaska Scale Kit/Scratch Built 35 Oct 30, 2008 05:00 PM
HERCULES C-130 JIMFRISKY Electric Plane Talk 6 May 31, 2002 12:52 AM
Looking for C-130 Herc Electrics Jumpin Jarhead Foamies (Kits) 40 Feb 12, 2002 03:05 AM
C-130 w/4-400's. Short flight-Help!! RonJ Foamies (Kits) 6 Jul 06, 2001 10:30 AM
