Old May 27, 2004, 12:45 AM
Lorduss is offline
Find More Posts by Lorduss
Joined May 2004
what are your thoughts on the front break from CNR?
im considering buying the front disk break setup, kinda bummed i have to buy a new front rim right after i glued my new front tires to my stock rim, can anyone show me the upps and downs to the front disk break, are there any real down sides to it? the bike defintly doesnt stop quick with just a rear wheel slowing it down, skids quite easy. your thoughts are appreactied.
Lorduss is offline Find More Posts by Lorduss
Old May 27, 2004, 05:15 PM
mollycbr123 is offline
Find More Posts by mollycbr123
STeve B in NC
mollycbr123's Avatar
North Carolina, USA
Joined Sep 2003
You can always use the rear skidding to slide the bike out and help in turns! Have you got stock tires on? If so, aftermarket tires may make the back stick a bit better, or lowering the brake adjust on your Tx to where the wheel doesn't break loose so easily may help you slow down qiucker.
The most of the guys that have front brakes like them. Those of us who haven't tried them just adapt. Only disadvantage I can think of is increased weight from the brakes and extra servo. Especially if you like to pop wheelies!
One day soon I'll get my set of Pat's brakes installed on one of the bikes and will give better feedback.
HTH
STeve B in NC
mollycbr123 is offline Find More Posts by mollycbr123
Old May 27, 2004, 10:41 PM
JANSSENM is offline
Find More Posts by JANSSENM
New York
Joined Sep 2002
Lorduss,
I like having the front brakes. It make your cornering time alot shorter. But you won't be able to turn the bike while you are on the brakes. Not like just having the rear brakes, you could turn even while you are on the brakes. It does take a bit of getting use to after you have driven the bike with just the rear brake. But it would give you an advantage when you are racing. You could out brake someome that don't use them.
janssen
BTW Steve, you'll love Pat's brake set.
janssen
JANSSENM is offline Find More Posts by JANSSENM
Old May 28, 2004, 12:56 AM
Drillah is offline
Find More Posts by Drillah
I'll be back..bwap bwaap
Drillah's Avatar
Seattle
Joined Oct 2003
Why can't you turn while the front brake is applied? That's trail braking.
Do they bind up or somthing? If so then I think they need adjusting.
Drillah is offline Find More Posts by Drillah
Old May 28, 2004, 05:30 AM
philb is offline
Find More Posts by philb
omaha-ne
Joined Apr 2004
The braking on the front wheel would make it try to caster itself back to center, I believe.
philb is offline Find More Posts by philb
Old May 28, 2004, 09:07 AM
nuovaic is online now
Find More Posts by nuovaic
nuovaic's Avatar
Wetherby, UK
Joined Dec 2003
Also depends on brake bias. if set 70/30 or higher, the bike would scrub off speed faster braking in a straight line, then off the brakes to lean into the turm. At 60/40 or less it is possible to keep braking while leaning into the turn, just easing off as you lean more / slow down. I would definately go for the front brake, if only to see the front forks bottom out under hard braking!
John
nuovaic is online now Find More Posts by nuovaic
Old May 28, 2004, 10:22 AM
scaulfi is offline
Find More Posts by scaulfi
Big thrills w/o hospital bills
scaulfi's Avatar
Brisbane, Australia
Joined Sep 2003
I have mine set like that too,... 60/40 works for me, i can still be braking fast into a tight corner and have it turn in without any problem, but the more front applied to the setup makes it harder to turn it in..! My 2 C's...
shaun
scaulfi is offline Find More Posts by scaulfi
Old May 28, 2004, 01:46 PM
Deano1661 is offline
Find More Posts by Deano1661
Bikes R Us is back!
Deano1661's Avatar
Manchester U.K.
Joined May 2004
I don't know what bias i've got set up on my bike but if I try to turn while braking I just lose the front end I think i'm still too used to my HOR with tyre caps "just nail the brakes and tip it into the corner" that's probably why i've worn out my C.N.R. brake disc, but the front end sure dives good
Deano1661 is offline Find More Posts by Deano1661
Old May 28, 2004, 06:45 PM
scaulfi is offline
scaulfi's Avatar
Brisbane, Australia
Joined Sep 2003
BTW,... Lorduss.. The front brake kit from CNR is really from NF... CNR don't make a front or rear brake, plus i couldn't tell you how many times i've asked him to make some sets up too!...
Oh well,.. i guess Pat's the winner here, his brakes work exellent and look very reallistic aswell..!!!
shaun
Discussion What are your thoughts on the GeniusRC 490DX? PcKSnipE Mini Helis 24 Feb 01, 2009 12:30 PM
Discussion What are your thoughts on Clubs banning certain types of flying? Aero65 AMA (Academy of Model Aeronautics) 99 Nov 22, 2007 08:24 PM
What are your thoughts on the parkzone p51 mustang peiviper Parkflyers 2 Aug 12, 2005 09:07 PM
Question What are everyones thoughts on this wireless Camera set up? bobsean Aerial Photography 6 Feb 15, 2005 09:33 PM
Micro Servos for $ 8.95 each new in box What Are Your Thoughts? Synthetic Radios 21 Jan 13, 2004 05:15 AM
