Old May 26, 2004, 02:24 AM
buzzbee is offline
Find More Posts by buzzbee
buzzbee's Avatar
Boulder , CO
Joined Oct 2003
Tips for Bending Landing gear for Smoothe
Would love to hear how others have done this. I snapped mine tonight, so I am done building. I was using a 4" shop vise to hold it and pushing slowly on it.
buzzbee is offline Find More Posts by buzzbee
Old May 26, 2004, 08:24 AM
Alan Trefrey is offline
Find More Posts by Alan Trefrey
Ipswich, MA, USA
Joined Feb 2000
I use a mini torch to anneal the spot where i am going to make the bend. You can only bend it once, not back and forth, so plan ahead. Hope this helps
Alan Trefrey is offline Find More Posts by Alan Trefrey
Old May 26, 2004, 08:57 AM
Tim Jonas is offline
Find More Posts by Tim Jonas
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I use a K&S wire bender. Higley also makes one.
Tim Jonas is offline Find More Posts by Tim Jonas
Old May 26, 2004, 09:21 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
buzzbee,
Email me your address and I'll send you some more wire.
I just use pliers to bend mine. I've been using this type of gear for a while so I'm pretty used to doing it.
Doug
CoClimber is offline Find More Posts by CoClimber
Old May 26, 2004, 09:26 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
I used a vise and a brute force to bend wire up to 5/32". When it comes to making the bend sharp, you bend it by hand to shape and then pound the joint with a hammer on the vice jaw to make it a perfect 90.
Here is a pix of the MFG gear and my stiffer replacement in 5/32" wire. just take your time and be picky on the angles. Match the precisely as you go.
Kirby
kepople is offline Find More Posts by kepople
Old May 26, 2004, 09:49 AM
nose_first is offline
Find More Posts by nose_first
nose_first's Avatar
Riverview, FL
Joined Dec 2002
i curse a lot when bending mine - it doesnt help much, but i do feel better. if the mountain models planes werent so damn good i wouldnt bother with it once you fly it, you will forget about the trouble of bending the wires.
i think next time i will send a few extra bucks and just have doug bend them for me
nose_first is offline Find More Posts by nose_first
Old May 26, 2004, 10:04 AM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
Here is a bit more help, as well.
Old May 26, 2004, 10:22 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
I think cursing does help. It shows that inanimate object who is boss. I have a few choice words I save for hitting my thumb with a hammer as well.
Kirby
DC Ross is offline
Find More Posts by DC Ross
DC Ross's Avatar
Redmond, WA
Joined Aug 2003
I subscribe to the "Beat with a hammer" school of thought as well.
Here's my "technique":
1. Mark the center point with a Sharpie
2. Stick it in a vise so the mark is just barely above the jaws
3. Hammer a 90 angle into it, take it out, beat the remaining 20 (or until it lines up with the landing gear mount)
4. Measure & mark " in from the ends
5. Stick it back in the vise (again, with the mark just barely above the jaws) and hammer about 55 into it for the wheels.
I haven't snapped or have had to redo anything using this method, and it takes all of five minutes.
Here's a story for you: A friend of mine built a Dandy, and he was telling me what a pain it was to bend the Tail wire. Granted, there are some complex angles, but nothing outrageous. I told him to bring it over and I'd finish bending it for him. It turns out he was using the main landing gear wire! I've never before or since seen such a beefy tail wire
Good luck and have fun with it!
DC Ross is offline Find More Posts by DC Ross
Old May 26, 2004, 10:24 AM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
I'd almost pay someone to do it, if there was anybody local to do it.
Old May 26, 2004, 10:32 AM
citabria is offline
Find More Posts by citabria
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
I've learned that close is good enough. My gear never match the plans (or each other) exactly, but you can't tell once they're on the plane. They are working just fine so I figure if it ain't broke don't fix it.
Scott
citabria is offline Find More Posts by citabria
Old May 26, 2004, 02:30 PM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
Kirby
as a matter of fact, i think doug should revise the build manual to include cursing as part of the step - just to help everyone out
along with a picture showing the placement of the small brace (affectionately known as the 'Jeff" brace that goes in the middle of the sport wing - between the plywood)...and not just because i forgot to put it in... err i mean just because i wanted to save weight on my plane
Old May 26, 2004, 03:31 PM
Squirelly Flyer is offline
Find More Posts by Squirelly Flyer
I write; therefore, I am.
Squirelly Flyer's Avatar
Redmond, WA
Joined Apr 2003
Hmm, I could do that, Nose First...any choice of language the cursing should appear in?? ASCII (@#!!@*&$#)? Yiddish (OY VEYH!!)?
~Liz
Squirelly Flyer is offline Find More Posts by Squirelly Flyer
Old May 26, 2004, 03:46 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
I used to curse. But then I bought a wire bender from Micro Mark. I curse no more.
SchiessCo is offline Find More Posts by SchiessCo
Old May 27, 2004, 07:29 AM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
still have to get the angles correct, which eludes me thus far....
Bending new landing gear for my SS? micsaund Beginner Training Area (Aircraft-Electric) 6 Jun 21, 2005 10:53 PM
Tool for bending landing gear piano wire? mgdon Beginner Training Area (Aircraft-Electric) 9 Apr 28, 2005 01:39 AM
need tips for attaching landing gear doors CzechSix Parkflyers 2 Jul 01, 2004 09:18 AM
Hook on landing gear for a zagi! funflyer Foamies (Kits) 2 Aug 24, 2003 03:03 AM
Landing gear for Robbe 109 Dave Seay Electric Plane Talk 7 Jan 01, 2002 06:41 PM
