Old Jan 09, 2002, 05:45 PM
Rob R is offline
Find More Posts by Rob R
Harrisburg,PA
Joined Jan 2001
Making the Big MONGO electric??????????
The local hobby shop has a couple different size mongo kits. I was looking at them and want one. I want the big one. But I want to make them electric. I really really would like to covert the 16 foot Mongo16 to electric. Would it make a good electric coversion. What motor(s) battery packs, etc would I need to make it fly as good and perform as good as a Zagi with a 450Turbo. They also have the Mongo SR to. But I want the monster 16 foot one!!!!!! What setup would I need to make it perform like a well powered Zagi. How much do you think it would weigh? Could you hand launch it or need a cadapult? Sure would take a lot of Zagi packaging tape to cover it!!!!!!
Rob
Rob R is offline Find More Posts by Rob R
Old Jan 09, 2002, 06:38 PM
JayParke is offline
Find More Posts by JayParke
Idaho
Joined Oct 2001
Awesome. The Mongo16 electrified. Wayyyy cool. I definately want to see that finished. I didn't think they made them Mongos anymore. If you do a search for Mongo I "think" you will find someone that has already electrified one. Maybe it wasn't the 16 foot one though. I really want the Mongo SR.???, "one or two sizes below the 16", for sloping but have to wait till spring to see if the new slope spot is going to work. And if so then.....
Josh
I'm not much help but I just wanted to say COOL.
Ohhh, hey also here is a link to a site with pics. of the Mongo just incase someone doesn't know what it is and wants to see what's going to be converted. http://www.fatlion.com/bash/pictures.html Last pic.
JayParke is offline Find More Posts by JayParke
Old Jan 09, 2002, 06:49 PM
Rob R is offline
Harrisburg,PA
Joined Jan 2001
I don't think they do make Mongo's anymore. The local hobby shop has a couple kits of them! The 16 foot mongo should be awesome if I can get the right setup in it to make it perform. I saw greg's review on when he made his Mongo Jr. Electric. Seems neat. I'll keep you posted
Rob!
Old Jan 09, 2002, 07:04 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Re: Making the Big MONGO electric??????????
You could try about 3 to 4, 1 amp hour sealed batteries for the pack, about 4 to 6 Mongo motors with mongo props
Or, strap a weedwacker motor on her! Just toying of course, GL
FANMAN is offline Find More Posts by FANMAN
Old Jan 09, 2002, 09:40 PM
Dan H. is offline
Find More Posts by Dan H.
Crashez-vous sans stress!
Dan H.'s Avatar
Chicago
Joined Nov 2001
Originally posted by Rob R
What motor(s) battery packs, etc would I need to make it fly as good and perform as good as a Zagi with a 450Turbo. [snip] How much do you think it would weigh? Could you hand launch it or need a cadapult?
Rob
Motors?...let's see...Briggs & Stratton, Lawn-Boy, Kirby Vacuum....
How much would it weigh-- Is that with pilot or without?
Need a catapult? Heck, it is the goshdarn catapult! Woohoo!!
Dan H. is offline Find More Posts by Dan H.
Old Jan 10, 2002, 08:27 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Rob,
Unless you can fly out of your backyard, I would not recommend "electrifying" the Mongo-16. The 8' Mongo would be enough of a handful to convert.
For a rule of thumb, consider this in your design. For the 6' Mongo Jr., using 2 Magnetic Mayhem Reverse (MMR) direct drive motors powered by 7 or 8 cells of CP2400SCR provides excellent power and duration. The trick was to obtain proper CG.
For the 8' Mongo, 3 or 4 MMRs are required. Since you'll be fighting to obtain proper CG, you may wish to start with 3 motors but design the second system for 4 motors...just in case.
Each system might include:
  • 2 MMRs
  • GP C-50 ESC
  • 8-cells of CP2400SCR
  • AeroNaut or APC 7x4 prop
Regards and have fun!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 10, 2002, 04:40 PM
Rob R is offline
Harrisburg,PA
Joined Jan 2001
How about two of the Jeti 45/3 motors as a Twin and about 16 to 18 cells? Would that work????
Yeah I have a huge field in the back of my yard where I can fly it.
Old Jan 10, 2002, 05:43 PM
Steve Wrona is offline
Find More Posts by Steve Wrona
I am M I G H T Y !
Steve Wrona's Avatar
Ipswich, England
Joined Feb 2001
What a fundamentaly insane idea!
Ok, what about a GROSS (144) of GWS DX-A's swinging Gunther props! All them lil' buggers poking out of the LE, screaming away and yanking that 16 footer into the blue!
Hey Bleriot, this would be your big chance to smolderize 12 dozen GWS mot's at once!
Steve
"That is one hefty Mongo, Jerry!"
Steve Wrona is offline Find More Posts by Steve Wrona
Old Jan 10, 2002, 05:56 PM
Fred Bronk is online now
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
A guy here has the 8 ft Mongo with a MMR and geardrive. It fly's great!
So for the 16 look at 2 MM (one reverse, one normal) and run CR props. 8xCP1700's for each would do just fine!
Fred Bronk is online now Find More Posts by Fred Bronk
Old Jan 11, 2002, 07:57 AM
Rochester, NY, USA
Joined Aug 2000
What setup would I need to make it perform like a well powered Zagi?
Rob,
Since the above quote was one of your goals. Be carefull between selecting a power system that will simply make it fly and one that achieves your goal.
If you have the resources to stick 2 brushless motors on a chunk or foam...by all means, go for it!
Also, in Fred's suggestion above, remember that whether you use a MM or MMR is determined by the type of gearbox, offset or planetary, and that it switches again since you are running the prop in reverse for a pusher configuration.
For Sale Big APC Electric props wollins Aircraft - Electric - Power Systems (FS/W) 0 Jun 18, 2007 11:10 PM
don't want to start a mess - "big" electric question dgoss Electric Heli Talk 4 Feb 19, 2005 01:21 AM
Fs Big Apc Electric Props RGHCOWNER Aircraft - Electric - Airplanes (FS/W) 5 Sep 22, 2004 08:33 AM
Making a BIG boat ESC for my rigger :) KreAture Racing Boats - Electric 14 Jul 03, 2004 02:33 PM
Making a big wing strong enough FlyingW Electric Plane Talk 1 Jan 24, 2003 10:02 PM
