May 29, 2004, 05:57 PM
Central Coast, CA
Joined Apr 2004
You are so correct in this. But the only way a fixed pitched blade helicopter that developes the systom of blade lag, is to describe it as blade stall. The wobble is of course caused by a blade lagging, this is considered to me as a classic blade stall, or retreating blade stall in all respects of the cause. Thanks for pointing out that this is actually a blade lag, instead of a blade stall, which occur's in real helicopters, and in these Micro Helicopters, blade lag or retreating blade stall are.....terms of the same outcome, crash, or in real helicopters, death. Please believe, that what you quoted is true, and I've flown helicopters, UH-1N's for twelve years as a test flight engineer, That's all I did is smooth rotor's for the Airforce, This is a classic Rotor Retreating Blade stall, due to the retreating blade lagging the light weight blades cannot keep up with the torque of the main rotor, thus lag, causing vibrations and wobble........classic systoms of the same cause...and the outcome is always crash....
