Old Nov 17, 2004, 07:57 AM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
If nothing else, anyone owning a Aerohawk should get my Tips and Tricks paper to trimming in and setting up your heli. I based it on the Aerohawk Rotor head, but anyone else that has a different model, dragonfly/hummer/esky/jabo is more then welcome to add to it.
G109
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Nov 19, 2004, 03:16 PM
Central Coast, CA
Joined Apr 2004
Update: I got the blades and rotorhead in, and after careful evaluation it's clear to me that these rotor heads have the same identical problem as the Aerohawk rotor blades. The rotor head has too much flex, the blades have excessive coning.
A kit is being developed as I write this. Which will fix all adverse flight problems with these model helicopters: Hummingbird, Dragonfly, Esky, Jabo and well basically all of the clones based on the Hummingbird.
There are suttle differences in rotorheads between them all with the way they are molded. There is no one perfect solution to this other then the spring has to be adjusted either alittle wider or smaller to fit your model. I believe the hardware should all be the same, 2.5mm screws and washers. I am not perfectly confident that the stiffener plate I want to offer is going to fit every rotorhead either, I believe it should, but again there are minor differences in them all.
The G109A Kits: Aerohawk/Skylark/XR-1
Blade Advancing Springs
2.5mm Stainless Steel Screws
2.5mm Fender Washers
2.5mm Nylon Loc-Nuts
Blade Root Carbon Fiber Reinforcement Strips
The G109B: Hummingbird/Dragonfly/Esky/Jabo & Clones
All necessary bolts/nuts/washers/spacers to add the springs correctly and safely.
Rotorhead Stiffener Plate
I'm going to get some setup photos as soon as the stiffener plates come in.
G109
Old Nov 19, 2004, 03:59 PM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Sounds good G109!
Look forward to seeing some pictures, and maybe even testing them for you!
Duane
Minimole is offline Find More Posts by Minimole
Old Dec 01, 2004, 01:38 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Got my set comming as we speak. Looking forward to some successful liftoff and hovering!
Justin
roccobro is offline Find More Posts by roccobro
Old Dec 01, 2004, 08:33 PM
Central Coast, CA
Joined Apr 2004
Everyone that has paid orders.......are being sent in the AM Mail.....!
Thanks.....again....
G109
Old Dec 01, 2004, 10:45 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
G, my kit for the Aerohawk arrived today, thanks! I'll be testing it this weekend. More later...
BobRCnut is offline Find More Posts by BobRCnut
Old Dec 01, 2004, 10:51 PM
rjpmodel is offline
Find More Posts by rjpmodel
United States, TX, Cedar Park
Joined Dec 2002
I have a Rex comming and I am still trying to figure which motor to get. I have been talking to hotrod37ford and seen his posts for his multiplex 480-4. He seems to be getting good performance. I have a hacker B40-18s and have just done a comparison of this motor with the 480-4 and it looks very similar. It is the same size and weight and has a KV=3550 which would work good with the 11 pinion ? This is a very high quality(also expensive) motor. Can anyone tell me why this motor might not be a good choice to try?
rjpmodel is offline Find More Posts by rjpmodel
Old Dec 02, 2004, 12:29 AM
Central Coast, CA
Joined Apr 2004
Well as far as I can see.......this post is really in the wrong thread.....Sorry.
I don't think that anyone of us FP guys.......are even close.
G109
Old Dec 02, 2004, 05:27 AM
hingus2000 is offline
Find More Posts by hingus2000
Wolverhampton, UK
Joined Jun 2004
hi
ive put my blades on my hummer with like90's, ill get some pics in a couple of days and test it over the weekend. I need a small enough spanner to tighten the little bolts.
i figured the best way to put them on was screw from underneath,
so from the top it is:
bolt
head stiffener
blades
head
spring
washer
screw
thanks!
hingus2000 is offline Find More Posts by hingus2000
Old Dec 02, 2004, 06:30 AM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
i just hold the bolt with a pair of pliers and then screw from the top.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Dec 04, 2004, 12:40 AM
Race Miata is offline
Find More Posts by Race Miata
Race Miata's Avatar
Vancouver, Canada
Joined Nov 2004
Cool mod!
I'm new to this board but I started RC micro heli since June and has been frequently visiting another RC heli board. My Esky Honey Bee FP has started some tail bounce problem and I came up with my rubberband mod which works similar to this spring mod. I basically fold each main blade forward and slip a carefully-chosen rubberband thru' the flybar and the main blade. When the blades are unfolded, the right amount of tension from the rubberbands works like the spring mod does except that the spring mod is more elegant. I'll consider replace my rubberbands with springs.
Race Miata is offline Find More Posts by Race Miata
Old Dec 10, 2004, 09:48 PM
reptilerick is offline
Find More Posts by reptilerick
sticky toed flyer
reptilerick's Avatar
Methuen, Mass, United States
Joined Sep 2004
sorry dupe
reptilerick is offline Find More Posts by reptilerick
Old Dec 10, 2004, 09:49 PM
sticky toed flyer
Joined Sep 2004
Just wanted to let you know that my blade fix kit came in yesterday.
Thanks G.
Also what is this motor mount kit I've read about?
Old Dec 10, 2004, 10:07 PM
Central Coast, CA
Joined Apr 2004
Great! I hope it does what almost over 100 others have found......the end to the wobble for you too....You heard about the CD-ROM mounting system I have......that's great.....I do......and I've been flying mine for over three months testing....and it's as good as any machined mounting system out there........IMO. Alot of Pilots have purchased the mount I offer.....and all have had really good success with it. Funny, how this goes......I've offered a refund to anyone who wasn't happy with their purchase and not one has asked. It's obvious to me......that everyone flying the spring kits.....and the mounts are flying successfully......like me....it's awesome!
I custom each mount.......so PM me with the details of what you have in mind....there's so many options.....and I want you have what you need......in the kits.
G109
Old Dec 15, 2004, 11:41 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
Guys;
Just got my head spring kit installed and I love it. Couldn't be easier to install and I am now able to run my blades VERY loose which obviously helps them survive impacts with furniture (and Pets).
The kit works, and for the price that Geoffrey109 asks, you'd be hard pressed to put together the pieces yourself for less.
Steven
Popsflyer is offline Find More Posts by Popsflyer
Hummingbird Elite fixed pitch blade question. Greybird Micro Helis 3 Apr 03, 2005 06:30 PM
Fixed Pitch Blade Fix.....Kits Geoffrey109 Aircraft - Electric - Helis (FS/W) 40 Mar 20, 2005 03:40 PM
Geoffrey's fixed Pitch Blade fix haddorh Micro Helis 3 Feb 03, 2005 03:10 PM
My Thoughts on Fixed Pitch Blade Fixing (aka The Dreaded Wobble) aeropenguin Micro Helis 18 Jan 17, 2005 10:41 AM
Fixed pitch blade on zoom. vinager5 Mini Helis 0 Nov 08, 2004 11:33 AM
