Old May 23, 2004, 03:55 PM
Sean Plummer is offline
Find More Posts by Sean Plummer
Tempe,AZ, USA
Joined Jun 2001
Hangar 9 1.50 size P-51 ARF Conversion
At the Hobby shop yesterday and the Hangar 9 1.50 P-51 was on sale. Opened the box and decided that the Thunder power 10s4p would fit. I have wanted a large warbird for sometime now, and this is it. C50 XL Acro ?? will work. the C50 mount will also fit.
I plan to document the conversion with online photos during the next weeks....only the electric conversion details will be shown, as the model has been recently reviewed in printed magazines (MAN Jan 04).
Note: I am super busy with Family, Work and Testing Motors, please forgive me if I do not cover every detail or question. I will do my best as time permits...
Sean Plummer
Hacker Brushless USA
Sean Plummer is offline Find More Posts by Sean Plummer
Site Sponsor
Old May 23, 2004, 04:02 PM
Tempe,AZ, USA
Joined Jun 2001
This conversion will have battery access through the Top of the Fuselage, This work must be done first.
Let's Begin by cutting the "Hatch". Using x-acto knife, I poke through from the inside to the outside of the fuselage. Use the tip of the knife to mark the cut line. I followed the Ply Formers on the inside of the fuselage as the photo shows.
Site Sponsor
Old May 23, 2004, 04:05 PM
Tempe,AZ, USA
Joined Jun 2001
Next, we "Saw" the hatch from the outside using the x-acto marks and tape as a guidline for the cut. I use a very fine Razor type saw for this work.
Site Sponsor
Old May 23, 2004, 04:08 PM
Tempe,AZ, USA
Joined Jun 2001
The hatch is now freed from the fuselage and held together with tape, leave the covering on the "Hatch" until the new formers are attached. This is a delicate stage be careful with the hatch as it is formed with the grain.
Site Sponsor
Old May 23, 2004, 04:13 PM
Tempe,AZ, USA
Joined Jun 2001
Next, sand the Original bulkheads in the fuselage flush, so the "Hatch" formers can be made.
Site Sponsor
Old May 23, 2004, 04:16 PM
Tempe,AZ, USA
Joined Jun 2001
Note: The 12" sanding block is used to ensure flush and accurate fit of parts.
Shape the 1/16" plywood following the contour of the Original fuselage bulkheads.
Site Sponsor
Old May 23, 2004, 04:18 PM
Tempe,AZ, USA
Joined Jun 2001
The hatch formers are now glued to the "Hatch". The new "Hatch" can now be final fitted to the fuselage. Remove the covering and Using the sanding block contour the "Hatch" back into the fuselage, this should not take long as the 'Hatch" was originally the top of the fuselage. It is helpfull to align the balsa grain of "Hatch" and the top of the fuselage during the sanding.
Site Sponsor
Old May 23, 2004, 04:26 PM
Tempe,AZ, USA
Joined Jun 2001
Test fit the "Hatch" using masking tape as a hinge. Final adjustments will now be made, using Balsa, C/A and sanding Block to achieve a perfect fit.
Site Sponsor
Old May 23, 2004, 04:30 PM
Tempe,AZ, USA
Joined Jun 2001
The Hatch is now shaped and sanded smooth, ready for covering material to be re-applied. Usually new covering film will need to be purchased that exactly matches the orginal colors. In this case Ultra-Cote.
Site Sponsor
Old May 23, 2004, 04:59 PM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
Ok?! What's next?
Eagerly awaiting more.
<VBG>
Crash
crashsiegel is offline Find More Posts by crashsiegel
Old May 23, 2004, 05:07 PM
Joe Ford is offline
Find More Posts by Joe Ford
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
I too am watching with great anticipation...cant wait to hear the flight report.
Joe Ford is offline Find More Posts by Joe Ford
Old May 23, 2004, 06:38 PM
DrBill is offline
Find More Posts by DrBill
I need a new plane STAT!!
DrBill's Avatar
Rhode Island
Joined Sep 2003
Sign me up for this thread!!!
DrBill is offline Find More Posts by DrBill
Old May 23, 2004, 09:03 PM
FAA is offline
FAA
Find More Posts by FAA
FAA
Master Model Collector
FAA's Avatar
Connecticut, United States
Joined Apr 2002
Excellent Thread !
The AXI 4130 series are also a good candidate for this size.
Nick
FAA is offline Find More Posts by FAA
Old May 24, 2004, 08:09 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Any chance itíll be anything but a purple motor? Doubt it.
Best of luck Sean!
jrb is offline Find More Posts by jrb
Old May 24, 2004, 09:53 AM
Splummer is offline
Find More Posts by Splummer
Joined Dec 2001
We Understand the interest in the AXI 4130, I have tested multiple out runners during the past 3 years and Hacker has introduced the"Baby" recently.
I would be happy to try the AXI 4130 in this model, IF IT WILL WORK...Keep in mind this Airplane has retracts and flaps, plus dual servos on the elevator. I will install 9 servos in the model. I feel weight will be an issue and any thing less than 16 lbs all up will be a gift.
I am not shooting for a lazy weekend model for this kind of invesment, I want the model to acheive very fast speeds, in fact I will probably document 2 Hacker system solutions. First will be 60 amps full throttle on 10S4P, 2220 watts. Second, will be a High power TEST set-up, 90amps full throttle on 10S4P, 3000+watts. I have already bench tested these system and simply need to determine prop clearance on the finished model.
Back to the AXI 4130, We have an open account with Hobby Lobby, tell me what will work and I will Order it immediately.
One more thought, We also own a Radar Gun to document top speed, this is getting more fun all the time!
Best Regards,
Sean Plummer
Splummer is offline Find More Posts by Splummer
Site Sponsor
Article Horizon Hobby's Hangar 9 Brand Ultimate Trainer P-51 Mustang PTS ARF Review raythomas Beginner Training Area (Fuel) 14 Aug 27, 2014 12:28 PM
Sold Hangar 9 1.20 size Edge 540 ARF NIB jus10stephens Aircraft - Fuel - Airplanes (FS/W) 1 Aug 24, 2006 06:47 PM
New Hangar 9 1.50 sized P-47 Brill 1 Sport Planes 18 Aug 05, 2005 07:11 AM
Hanger 9 1.50 P-51 Tawg Fuel Plane Talk 1 Jan 04, 2005 08:52 AM
60 size P-40 ARF conversion fbw4 Scale Kit/Scratch Built 14 May 12, 2003 08:24 PM
