Old May 22, 2004, 10:24 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
In need of some basics
I am fairly new to LiPoly battery packs, having used NiCads and NiMH's for some time now. I understand the configuration of a LiPoly battery pack is something such as: 3s2p, 1300 mAh. As I understand it, this example would describe a LiPoly pack made up of a total of 6 cells, each cell having 3.7 volts available (when suitably charged). Three of the 6 cells are connected in series, to provide 11.1 volts total for this 3 cell "pack". A second "pack" of 3 cells is also wired in series to provide 11.1 volts. The two packs (3 cells each) are then conneced in parallel, so the finished battery pack will have 11.1 volts available, at a total capacity of 2600 mAh. Not sure if this is correct.
What I have a problem figuring out is a 2s1p configuration. Is this two cells in series, with the two cells also connected in parallel? Don't see how this is possible without shorting out something. Same thing for 3s1p. I would like to see a diagram of these configurations, to better explain them. Pehaps someone could point me in the right direction to some literature, a website, or whatever that would help a newbie learn the wiring arrangements possible for LiPoly battery packs.
Many thanks in advance.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Old May 22, 2004, 11:27 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
RD: You have the first part right. The nomenclature used is XsYp to indicate the pack. It's overkill when there are no parallel cells in the pack. Hence, a 3s1p pack is simply 3 cells in series.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old May 23, 2004, 04:04 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
If you have a look round the forum you'll find this has been discussed many times. The xS1P terminology is unpleasant and technically incorrect but seems to have stuck.
It may work better for you if you think of the xP part as the number of series connected packs which are connected together in parallel. As you correctly said 3S2P is 2 packs of 3 cells in series. 2S1P is simply 1 pack of 2 series-connected cells (obviously since there's only one it isn't really connected in parallel with anything which is why the terminology is rather confusing).
Steve
steve lewin is offline Find More Posts by steve lewin
Old May 23, 2004, 09:34 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
It's not too late to lose the 1P. Whenever I talk about a series of 2 or 3 Li cells, I simply use 2S or 3S without the 1P. So far, no one has expressed a problem understanding what I'm talking about. On the other hand, the 1P confuses a lot of people.
Dave Hederich is offline Find More Posts by Dave Hederich
Old May 23, 2004, 09:47 AM
dhungarland is offline
Find More Posts by dhungarland
dhungarland's Avatar
Danville, Virginia, United States
Joined May 2002
can someone explain how to gauge what volts to use - meaning do you just look at your motor's max voltage capability and that is it?
dhungarland is offline Find More Posts by dhungarland
Old May 26, 2004, 10:21 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Edified
Steve, Dave:
Many thanks for the clarification on xSxP. If you happen to recall a specific thread or message in the forum that goes into this in futher detail, let me know. I will try to search past posts to find what I can. Your info, however, has cleared up much of the confusion.
RD
Latest blog entry: Big Red Cadillac
Discussion I am in need of some custom electronics...please help! customminatures Scratchbuilt Indoor and Micro Models 2 Apr 24, 2007 02:55 PM
Discussion New Member, New 450XL CDE CCPM, and in need of some help. code Mini Helis 11 Aug 14, 2006 06:47 PM
FS: Modified Herr Aquastar in need of some TLC DougKierc Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2005 01:52 PM
n00b in need of some tail rotor help Niven Electric Heli Talk 2 Sep 29, 2003 01:04 AM
In need some help in the case of the stuttering Razor phoneguy Power Systems 6 Aug 03, 2003 10:32 PM
