Old Jan 08, 2002, 07:42 PM
Rob R is offline
Find More Posts by Rob R
Harrisburg,PA
Joined Jan 2001
Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!!
I just bought a Jeti Brushless 15/4 motor. I had bought a Cheap Jeti Brushless speed control off of a friend and bought a new one from hobby lobby. I hooked up the one I bought from my friend. Had it running in the correct way. All as I did was push the connecters of the motor and speed control together. Then next time I started in up the speed control started to smoke. What made it do that?????????? i saw that the one plug of the speed control was off just a very little tad off the motor. Is that why???? I'm going to put my other motor on it later but want info first. You get 3 little gold pins with the speed control. What are they for????? I think they might help it hold it in place???? Do I solder anything???? What made my speed control smoke?? All I did was push the speed control connecters and wires into the motor connectes and wires and that was it . I need Help because I don't want that happening again.
Rob
Rob R is offline Find More Posts by Rob R
Old Jan 08, 2002, 08:29 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
The controller comes with male connectors in case the motor you have didn't come with them. You don't need them for the Jeti motor.
What battery connectors do you have? What you describe sounds like hooking the battery up backwards to the controller......
Yes, I have done it before.
BEC is offline Find More Posts by BEC
Old Jan 10, 2002, 06:27 PM
Rob R is offline
Harrisburg,PA
Joined Jan 2001
I don't think my battery was hooked up backwards. But I don't know for sure. When it started to smoke I quickly unpluged it fast. I use Tamiya connecters with it. If the one plug for the motor wasn't completly plug into the speed control would that fry it. It was just only out a very little bit.
Rob
Old Jan 10, 2002, 06:37 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Tamiya (molex) connectors are junk, and cannot handle high amps. Plus they don't always make contact.
Perhaps a connection was not made on one of them, that could have caused the problem.
For my BL setups, I use 4mm pins on the motor/controller side (female on cont) and AF zero loss for the batteries.
Fred Bronk is offline Find More Posts by Fred Bronk
FS New Jeti Brushless Speed Control 04 amp ifome Aircraft - Electric - Airplanes (FS/W) 0 May 16, 2005 08:51 PM
FS: Jeti brushless speed control SammyB Aircraft - Electric - Airplanes (FS/W) 5 Jul 11, 2004 03:04 PM
FS Jeti Brushless Speed Control (NIP) Flyboy70 Aircraft - Electric - Helis (FS/W) 0 May 21, 2004 02:40 PM
FS Jeti Brushless Speed control Mmarshall Aircraft - Electric - Airplanes (FS/W) 3 Nov 08, 2003 12:48 AM
Jeti 08 brushless speed control Steve H. Aircraft - Electric - Airplanes (FS/W) 3 Jul 22, 2003 08:49 PM
