Old Jan 08, 2002, 05:51 PM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
Direct drive rotating core sensorless brushless motor for 99.00$. AXI 2820/10
AXI 2820/10 ....99.00$
Nominal Voltage 8.0 V
Operating Voltage 7-12 V
No Load Motor Speed 8,800 RPM
RPM per Volt 1,100 RPM/V
Max. Efficiency 79%
Max. Efficiency Current 25-30 A
Max. Loading 40 A/60 s
Blocking Current TBA
Dimensions 35.2x54.5 mm
Shaft Diameter 5 mm
Weight w/cables 161 g
Propeller range (direct drive) 10x6" - 12x8"
250/150 - 300/200
Recommended Power and Propeller Settings Model Weight Power Pack Propeller
1000-1500 g 7 cells 12x8"/300x200
1300-2000 g 8 cells 11x7"/280x180
1400-2500 g 10 cells 10x6"/250x150
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Jan 09, 2002, 02:08 PM
D.FLinn is offline
Find More Posts by D.FLinn
London Ont. Canada
Joined Sep 2001
Info
Any other info on this AXI motor?
Is this the only size? what controller will be best and last where can I get one?
thanks
D.FLinn is offline Find More Posts by D.FLinn
Discussion Direct drive brushless motor for heli phanquang_toan Electric Motor Design and Construction 4 Dec 02, 2006 09:14 AM
want to wind a brushless motor for direct drive sirdirk007 Power Systems 18 Feb 18, 2005 06:56 PM
Brushless Motor for $3.00 babblefish Power Systems 12 Jun 02, 2003 06:25 AM
Brushless Motor for The Sky Scooter? Coyoteair Sport Planes 3 Oct 15, 2001 10:55 AM
jetti brushless motor for ecco8? johnpmartins Electric Heli Talk 7 Aug 06, 2001 08:26 PM
