Old Feb 09, 2015, 03:18 PM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Actually I was thinking something like this would not harm the airflow too much and would add to the "roundness" of the hull :
Olivier_C is online now Find More Posts by Olivier_C
Old Feb 09, 2015, 05:59 PM
Silverware is offline
Find More Posts by Silverware
Got Quads?
United States, OH, Centerville
Joined Jan 2015
Yes! That would make it look even better!
Silverware is offline Find More Posts by Silverware
Old Feb 10, 2015, 01:47 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
First drawings, and my tiny black panther, because I saw in the Youtube comments I should feature a cat for extra Internet points, so there it is.
Main arm is made with the thickest foam I have, 30mm.
Also 30mm for the "central" right solar panel :
20mm for the top and bottom panels :
Making the angle for the panels :
Old Feb 10, 2015, 01:50 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Sanding because the angle was wrong...
Dry fit :
The other central panel :
Gluing like that so both sides are the exact same :
Wife : "Are you sure it's going to fly ?"
Me : "Absolutely not, you might be right..."
Old Feb 10, 2015, 01:51 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
My custom tool to cut 2 lines spaced 5mm :
That's to insert two 6mm carbon tube, to stiffen the main arm, one each side :
Some slight issue with blade clearance :
Putting another 6mm carbon the other side :
Old Feb 10, 2015, 01:52 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
The landing gear is locking the bottom of the main arm :
I tried to fly like this, it worked :]
checkign balance :
I like this view :
4 blasters *pew* *pew* :
The 2 sides completed :
Old Feb 10, 2015, 01:56 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
A shame I'll have to cut these, it's looking bonkers imho.
Testing the colors again...
That's after a test where I tried tome 7" props instead of 8", the Tie felt on its back and there was splinters of carbon everywhere
To be continued, next step is reducing all 4 panels in size, because I wrote above, it does not fly as-is, too heavy and too much airflow against the bottom of the lower panels.
RC hobby, not always working the 1st shot
Old Feb 10, 2015, 10:02 AM
Baddmove is offline
Find More Posts by Baddmove
I'm Tri'n, are you Tri'n?
Baddmove's Avatar
United States, WA, Pullman
Joined Sep 2013
Looking good my man, looking good!!
Baddmove is offline Find More Posts by Baddmove
Old Feb 10, 2015, 11:11 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
This is the amount I'm going to shave of each panel, old size is blue, new size is orange.
.8 scale factor, so -36% area and -36% weight.
Also moving the COG backward a bit so I have the option to fit the Gopro and fly FPV.
Old Feb 10, 2015, 11:17 AM
simontan is offline
Find More Posts by simontan
simontan's Avatar
United States, TX, Plano
Joined Dec 2006
Instead of cutting down all of the panels for airflow, what about just hollowing out the bottom panels? That way you'd be able to maintain the overall lines, size, and scale while still shedding some weight and improving airflow. Either way, looking forward to seeing the final product airborne!
Next you need to figure out a way to rig some laser pointers as blasters during night flying
simontan is offline Find More Posts by simontan
Old Feb 11, 2015, 01:31 PM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Yes that's an option, but I think that, right now, the issue is first with vibrations, aggravated by overweight.
So if I remove the inside of the panels, I'll gain weight, but I'm fairly certain it will make vibrations even worse.
Anyway, cutting is done now !
Gained 40gr per side, soweight is down from 420 to 340gr, lighter than the Falcon.
Still looks like a spaceship, *phew* :]
Old Feb 11, 2015, 10:42 PM
waimser is offline
Find More Posts by waimser
Joined Mar 2014
I think it actually looks better cut down.
waimser is offline Find More Posts by waimser
Old Feb 12, 2015, 04:31 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
LIFTOFF!!! WOOWHOOO!
After many many MANY attemps and trimming and different settings and 14 (yep fourteen) broken propellers, it's now airborne for real and stable, and if it flies in the garage it will fly anywhere.
The Falcon flew at the first shot, but god this one was tough to tweak.
I called my 2 boys to witness the thing hovering and we where all 3 like "Bwehehehehehee"
End of this week : Scale details, blasters, thruster, etc and paint.
Old Feb 12, 2015, 05:07 AM
daveracer is online now
Find More Posts by daveracer
Born los er
daveracer's Avatar
Australia, VIC, The Basin
Joined Aug 2014
Congratulations Oliver another triumph!
Persistence pays off
daveracer is online now Find More Posts by daveracer
Old Feb 12, 2015, 07:19 AM
FunN4Lo is offline
Find More Posts by FunN4Lo
Free fall is not free
FunN4Lo's Avatar
United States, LA, Baton Rouge
Joined Aug 2014
Can't wait to see the outdoor maiden. Now all you need to do is copy the quad so you can do a chase scene
FunN4Lo is offline Find More Posts by FunN4Lo
Cool Millenium Falcon - Design #1 today - PLANS ADDED!!! SGTalon Foamies (Scratchbuilt) 49 Dec 21, 2015 07:44 AM
Discussion Millenium Falcon-5 feet long out of cardboard dll932 Life, The Universe, and Politics 5 Nov 18, 2014 08:39 AM
BladeRunne® Converted to Millenium Falcon bEbOp ¿? BladeRunner Heli 1 May 18, 2005 03:04 PM
Article The Millenium Falcon Dennis Weatherly Electric Plane Talk 0 Feb 01, 1998 12:00 AM
