Old Jan 24, 2015, 09:05 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Build Log
Millenium Falcon, Tie Interceptor, Despicable Bomber, and other Quad-foamies
Peace here young padawans, below is the build log for the Millenium Falcon add-on for my 335mm quad.
It's a module that directly fits on my DIY quad, the "Prophecy 335", that I detailled there :
http://www.rcgroups.com/forums/showthread.php?t=2263855
Takes barely 2 minutes to equip my 335 with this "skin", just have to remove the GPS, the Gopro, and the 5.8GHz transmitter and that's all, it locks itself inside the frame with no extra step required.
This one flies line-of-sight only, no FPV.
First step, the design, tricky part is to have the whole setup balanced.
Because I'm removing the Gopro at the front to gain weight, the Falcon will have to be slightly offtset to the rear.
Then printing on A4 sheets and taping it all...
Main material is this insulant, in 20 and 30mm thickness.
It's heavier than EPP, but also much stronger, and easy to cut clean.
Also, it's almost the proper color of the spaceship.
Quick check for the balance, seem ok-ish, lucky me !
Olivier_C is online now Find More Posts by Olivier_C
Old Jan 24, 2015, 09:09 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
This "hook" thing slides in the place for the Gopro at the front, tight fit is required so the props are not hitting the foam.
I went for 10mm of free space between the tip of the blade and the foam.
A quick flight in the garage, must be sure it's flying before I put more effort in the project.
Weight of the add-on is 210gr for now, will try to keep it at 300-350gr top, so the quad flies decently.
FPV Quadcopter - Millenium 335 (1 min 25 sec)
Old Jan 24, 2015, 09:15 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Ok now that I know it's airworthy, let's improve.
I remove the "thruster" at the back...
Glue gun, best tool in the world.
The two side tunnels should help with some vibrations I noticed in the maiden flight :
Making cylinders, 1 corner at a time...
Smash and stamp !
Sihlouette is better now :
Old Jan 24, 2015, 09:21 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Adding the cockpit, it's hollowed, to limit the unbalance :
Adding these thin strips of foam for visual thickness when seen from the side :
Making a new thruster :
Radio antenna, yes I know in the old movies it was circular, but in the trailer for the new movie it's a smaller rectangle.
So a rectangle it will be for now, better aerodynamics.
Flying forward with so much surface should be enough of a challenge as-is.
My younger boy made the little turret :
How it locks into the frame at the front :
It's still about balanced, good thing.
Old Jan 24, 2015, 09:34 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Testing some paints, must find the proper color, and also a kind that does not harm the foam, will have to be acrylic.
Will paint with compressed air, after the next flight.
The 2 lights at the front, serial, so each get only 6V instead of 12V according to specs.
12V was really bright, I don't plan to fly this in pitch black night...
The famous thruster !
Top LED strip is blue, bottom is white.
Plan is to have the LEDs reflect against the top and bottom curves.
Blue is on top because I expect this one to be dimmer than the white.
I'l maybe add aluminium tape so it reflect more, will see.
Yay, gorgeous blue-ish-white, sometime plans are working as intended !
Weight for now is 310gr.
Compared to the normal fitting with a Gopro 4 and a VTX and a GPS, that's barely 150gr more.
Not really afraid of extra weight, more worried about inertia and vibrations.
To be continued, may the Force be with you.
Old Jan 24, 2015, 10:17 AM
exnihilo is offline
Find More Posts by exnihilo
Joined Dec 2014
That's freaking awesome! Can't wait to see the maiden!!
exnihilo is offline Find More Posts by exnihilo
Old Jan 24, 2015, 12:32 PM
FunN4Lo is offline
Find More Posts by FunN4Lo
Free fall is not free
FunN4Lo's Avatar
United States, LA, Baton Rouge
Joined Aug 2014
Pure genius. Subscribing to follow. Do you have a little Haun and Chewy to pilot the craft?
FunN4Lo is offline Find More Posts by FunN4Lo
Old Jan 24, 2015, 04:50 PM
tippytoe is offline
Find More Posts by tippytoe
United States, PA, Reading
Joined Mar 2009
This is really cool. Looking forward to seeing it when you have a little paint and weathering on her. I do the same thing to my machines also. Multirotors make excellent Sci-Fi projects!
tippytoe is offline Find More Posts by tippytoe
Old Jan 24, 2015, 04:55 PM
Grifftech is offline
Find More Posts by Grifftech
Joined Nov 2011
Bloody brilliant!!!
Grifftech is offline Find More Posts by Grifftech
Old Jan 24, 2015, 05:14 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Crazy cool man. I like how it easily connects to your copter.
RCvertt is offline Find More Posts by RCvertt
Old Jan 25, 2015, 06:37 AM
eirlink is offline
Find More Posts by eirlink
click HERE 2 C my BLOG
eirlink's Avatar
Ireland
Joined Mar 2013
Just subscribed to watch a genius at play.
eirlink is offline Find More Posts by eirlink
Old Jan 25, 2015, 10:54 AM
n-2-stuff is offline
Find More Posts by n-2-stuff
Scott
n-2-stuff's Avatar
Clovis,Ca.
Joined Sep 2006
The PROPHECY 335 looks a bit different now
n-2-stuff is offline Find More Posts by n-2-stuff
Old Jan 26, 2015, 06:21 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Thanks for the kind words guys !
I made another test, still indoor, flying outside was not an option, wind and snow.
I'll try to paint this week, after I add some details with Depron, also I'd like to make it looking less like a plank when seen from below.
Then hopefully next week-end a real flight outside.
Millenium Falcon 335 - 2nd flight, improved hull + lights (2 min 27 sec)
Old Jan 27, 2015, 04:07 AM
daveracer is offline
Find More Posts by daveracer
Born los er
daveracer's Avatar
Australia, VIC, The Basin
Joined Aug 2014
Awesome mate!
You must be a great dad too
daveracer is offline Find More Posts by daveracer
Old Jan 27, 2015, 11:19 AM
BuffaloJustin is offline
Find More Posts by BuffaloJustin
BuffaloJustin's Avatar
United States, SC, Lexington
Joined May 2014
Very cool! Cant wait to see it all finished up.
BuffaloJustin is offline Find More Posts by BuffaloJustin
Cool Millenium Falcon - Design #1 today - PLANS ADDED!!! SGTalon Foamies (Scratchbuilt) 49 Dec 21, 2015 07:44 AM
Discussion Millenium Falcon-5 feet long out of cardboard dll932 Life, The Universe, and Politics 5 Nov 18, 2014 08:39 AM
BladeRunne® Converted to Millenium Falcon bEbOp ¿? BladeRunner Heli 1 May 18, 2005 03:04 PM
Article The Millenium Falcon Dennis Weatherly Electric Plane Talk 0 Feb 01, 1998 12:00 AM
