Old May 21, 2004, 04:02 PM
Hovertime is offline
Find More Posts by Hovertime
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
How to measure no load current of a brushless motor?
I would like to know standard procedure to do this?
My guess - full throttle, but what woltage to use?
Hovertime is offline Find More Posts by Hovertime
Old May 21, 2004, 09:43 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Depends on the motor, but 6V would probably be OK.
..a
Old May 21, 2004, 11:36 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
What confuses me is that i get higher no load current as voltgae goes up, but at the same time it should be the same at any voltage in theory , and motocalc for example shows same current at different voltages too....?
Old May 21, 2004, 11:37 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
I have always assumed that no load current is constant, and does not change with voltage, if its not so - then its meaningless since we all use different voltages ,,....
Old May 22, 2004, 01:54 AM
Cranky1 is offline
Find More Posts by Cranky1
Lipoly not Lipo-suction
Cranky1's Avatar
Brisbane Australia
Joined Nov 2003
The no load current will change with voltage as the higher the voltage the faster it's tuning the motor. There won't be a big change though. The no load efficiency of the motor will be greatest at one particular voltage. Be carefull running brushless motors no load. Some manufacturers say for their motors it's a big no no. If you're only after the no load amps you should be able to get it off either the box it came in or a web site somewhere.
Cranky
Cranky1 is offline Find More Posts by Cranky1
Old May 22, 2004, 02:09 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
The current will rise as the source voltage goes up. How much it goes up depends on the motor. The cheap motors usually see a much greater change in current. The better motors will have much less change.
Steve
sneu is offline Find More Posts by sneu
Old May 22, 2004, 02:41 AM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Cranky
I though that needed increase in power is coming from increased voltage, as W = V x A ......
Be careful running brushless motors no load. Some manufacturers say for their motors it's a big no no.Cranky
Well thats true for any motor, or engine, but as long as I do not exceed max rpm i think I'm safe.
Old May 22, 2004, 02:44 AM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Steve
That might be the case as I'm having trouble with a cheap one
Then it is time for new question-what voltage is considered standard for no load current testing, and what voltage do manufacturers publish?
Is it some preset voltage - say 6V or voltage at best efficiency or what?
Old May 22, 2004, 05:23 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
One would presume that Io was measured at the motor's nominal operating voltage, but who knows? Some manufacturers don't quote an operating voltage, and some don't specify Io at all!
The problem with brushless motor 'constants' is that they can change depending on the controller used, and its programming. I suppose a manufacturer could use that fact as an excuse for not publishing the constants...
When making your own measurements, the most accurate way is to use a voltage slightly less than your expected application, eg. measure Io at 6V if you will be using a 7.2V battery. In most cases Io has only a weak dependence on voltage, so the exact test voltage is not very important. Just bear in mind that if you operate the motor at much higher voltage than usual, Io may be a bit higher (and efficiency a bit lower) than expected.
As to why Io increases with more voltage, my understanding is that the motor needs some current to magnetise the stator - which is constant, and some to overcome friction and eddy current losses- which increase with speed. At low to medium speed the magnetic component dominates, so Io remains relatively constant.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 22, 2004, 07:24 AM
FLL is offline
FLL
Find More Posts by FLL
FLL
Towaco, NJ
Joined Mar 2003
As Andy, and Astro Bob B. in his book, say, 6 volts is a good source to check no load current and set timing. I've found below that the Io reading will be too low. At 6v up to 8v the Io will level out until too much voltage will force the Io upward. Any no load measurements must be made quickly as the motor will heat up rapidly and change your readings. The higher the voltage used the quicker the heat up.
Frank
FLL is offline Find More Posts by FLL
Old May 22, 2004, 10:01 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
A good rule would be to make the measurement at the normal operating voltage.I have not seen any standard for making measurements.
Steve
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
It's my understanding the the no load current for brushed motors is relatively constant regardless of applied voltage, because the majority of this current is the result of brush friction which is independent of RPM. There will be a smaller variable component from windage and the magnetizing current.
In brushless motors, the story is different and it appears that there are a number of other factors which influence Io, which is usually smaller in magnitude than the Io of brushed motors.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old May 22, 2004, 12:38 PM
Fishnut is offline
Find More Posts by Fishnut
Fishnut's Avatar
Joined Feb 2004
You don't get something (more rpms) for nothing--even at "no load". It seems reasonable that (milli)amps would go up as rpms go up. Among other things, HP is related to RPM and it takes 746 watts to make one hp at 100% eff. The formula I found on google is hp = rpm x torque / 5252 (constant). Granted torque goes down as rpm goes up (at the higher revs), but I don't believe they cancel eachother out.
Edit: The above is all wrong. I forgot that the voltage is being increased. DOH!
That said, I have seen the rate of increase in milliamps go down at a repeatable place for each motor.
JMO
Kurt
Fishnut is offline Find More Posts by Fishnut
Old May 22, 2004, 12:49 PM
Toronto Canada
Joined Dec 2002
You are not actually getting more RPM for nothing.
You are applying more voltage and therefore more power, it's just that the current is approximately the same.
This is frequently analyzed in larger motors as a constant current source.
In a motor which was 100% efficient, Eg would equal the applied voltage and there would be no current under no load conditions.
Old May 22, 2004, 01:35 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
The reason it goes up somewhat is frictional damping, which the classic model of an electric motor doesn't touch, as it's usually a pretty small component in the motor itself, especially with a ball bearing motor. Friction increases with velocity, which creates a torque about the shaft. Asking the motor for more torque means more amps.
Comatose is offline Find More Posts by Comatose
Discussion Motor No Load Current Cantona156 Power Systems 4 Apr 22, 2007 12:48 AM
Question How do I measure no load current cooper998 Power Systems 17 Feb 03, 2007 06:08 PM
how to check no load current? brianb10 Power Systems 4 Aug 10, 2004 11:06 AM
How to measure no-load current? Giz Power Systems 8 Jul 02, 2004 09:39 AM
"no-load current" -- what does it mean? joey221 Power Systems 3 Mar 29, 2002 04:49 PM
