Old May 21, 2004, 12:19 PM
Kregg is offline
Find More Posts by Kregg
Virtual Cockpits
Kregg's Avatar
www.wrightrc.com
Joined Dec 2001
LiPo w/o correct BEC cut off?
I have a Hacker B20 12L 4:1 with a Hacker "Master/Jeti 18-3P" controller. Jason Schulman recommended using a 3x2100 li po pack with a 10x4.7 prop on my Ultimate 3D foamie. Unless you specify otherwise, this is the set up I will be using.
My question is about my Master/Jeti controller. It was purchased from Hacker when I bought the motor. I have never used LiPo batts before and I'm unclear about the BEC cut off point. My Master/Jeti 18-3P BEC controller is about 2 years old and was designed for Nicad & NihM cells. The Hacker man told me I could use the older control but the cut off was not changeable and that I should simply land when the power sags to keep from running the voltage to low. This sounds simple, but I'm worried about damaging these expensive LiPo cells.
Can I just stop when it "sags" or another way or should I spend more bucks and buy a new controller with programable cut off points?
Thx,
Kregg
Kregg is offline Find More Posts by Kregg
Old May 21, 2004, 02:09 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Check out the Li-Savers.
mw
Mark Wood is offline Find More Posts by Mark Wood
Rx unit w/o twitches when Tx off Spacecookies Radios 12 Jul 14, 2005 06:26 AM
3S series li-pos BEC cut off voltage AllenS Castle Creations 3 Dec 09, 2003 03:29 AM
BEC cut off point Alfred Power Systems 6 Jun 08, 2002 05:23 AM
Range check adivice - short range after BEC cut off !!! JensJakob Foamies (Kits) 0 Aug 08, 2001 01:38 AM
