Old May 20, 2004, 09:03 PM
XTheOwl is offline
Find More Posts by XTheOwl
Cleveland
Joined Nov 2002
Fuel filling valve location
Hello,
I am very new to RC Gas engines.
I am installing a "Kwik Fill" fueling valve that goes on the fuel line between the gas tank and the engine.
The engine is a OS .46 AX, with a remote needle valve.
It turns out just about the only place I can fit the valve is on the line that goes between the needle valve and the carburetor, and not the longer line that goes from the tank to the needle valve.
Is it a bad idea to put the valve between this short line between the needle valve and the carb? Or will this work OK?
XTO
XTheOwl is offline Find More Posts by XTheOwl
Old May 20, 2004, 09:05 PM
Flying kevin is offline
Find More Posts by Flying kevin
LowbudgetFlyer
Flying kevin's Avatar
Morristown, TN
Joined Mar 2004
I put my in the back near the fuel tank.
Kevin
Flying kevin is offline Find More Posts by Flying kevin
Old May 20, 2004, 09:21 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Is this what you are talking about?
Viper Pilot is offline Find More Posts by Viper Pilot
Old May 20, 2004, 09:29 PM
God is good
Banjul
Joined Jan 2001
If I understand you correctly, Do Not connect the Kwik Fill between the needle-valve and the carb. If you did, it would by-pass the needle-valve completely.
Place the Kwik Fill between the fuel tank and the needle-valve input nipple . . . . . just think "between the tank and the engine".
The Kwik Fill can be placed almost anywhere on the plane that you wish.
Hope this helps.
Viper
Old May 20, 2004, 09:38 PM
gabenelson is offline
Find More Posts by gabenelson
gabenelson's Avatar
Orangevale California
Joined Mar 2004
I don't use fuel filler valves myself, but I can imagine that the restriction of the needle valve would cause a problem. I have always filled through the feed line from the tank and the needle. To do this you pull the line off the tank side of the needle and fill through there. Locate the line that runs from the tank to the muffler and pull it off at the muffler. When the tank becomes full, fuel will come out of the fuel line that went to the muffler. You can make a catch can out of a spare fuel tank if you want to catch the spilled fuel.
By the way, I would like to make a small correction to your post. The OS .46AX is a glow fuel engine, not gas. It is a common mistake, but there is a difference.
Have fun with your new engine.
Gabe
gabenelson is offline Find More Posts by gabenelson
Old May 20, 2004, 10:36 PM
XTheOwl is offline
Cleveland
Joined Nov 2002
Viper: Yes, that link is exactly what I have. Also, I am not sure what you mean by bypassing the needle valve. The order I was thinking of hooking things up was:
Tank -- Needle Valve -- Fill Valve -- Carb. Fuel would flow through the needle valve both when filling and when going to the engine while running, so the needle valve would not be bypassed.
Gabe: Do you mean that the needle valve would restrict the flow of fuel while filling? (And yes, I shouldn't have said gas, I meant nitromethane/methanol; I'm not THAT new to engines. )
I know the ideal placement is between the tank and the needle valve input, but it really is gonna be a pain to do this. It would fit oh-so-well between the needle-valve output and the carb.
Thanks for the replies, anyone else have a reason why this location would be a bad idea?
Thanks again,
xto
Old May 21, 2004, 04:34 PM
ETIGER05 is offline
Find More Posts by ETIGER05
Joined May 2004
fuel valve
you certainly DO NOT want to put the valve between the Needle valve & the carb .LOL getting fuel into the tank! it will take forever to fill. it belongs mounted either on the plane or make a aluminum bracket & mount it close to the remote needle.(not a big fan of those things either)fuel line should be kept as short as you can without putting stress on lines. Some of these units are more trouble than they are worth. certainly it gives you two more places for air leaks.
ETIGER05 is offline Find More Posts by ETIGER05
Old May 21, 2004, 07:27 PM
Dano13 is offline
Find More Posts by Dano13
Cub Fanatic
Dano13's Avatar
Lytton Springs, Texas
Joined Feb 2004
Going back to your initial post, is this a fully cowled aircraft, or can you easily get at the fuel line going to the engine (remote needle location)?
If you can get to the tank line fairly easily, gabenelson's reply is your best bet.
While the "quick fill" valves are a nice addition, sometimes "straight and simple" is the best bet. Even if it is a cowled engine, it can't take much more than, what, 2 minutes to remove 4 screws, slide (tilt, whatever) it out of the way, fuel up using the line from tank to engine, and re-attach the cowling.(?)
dano
Dano13 is offline Find More Posts by Dano13
Old May 21, 2004, 09:57 PM
ETIGER05 is offline
Joined May 2004
refueling
Instead of removing the cowl ,use a pair of hemostats to reach in & remove the lines. you can get at all but the worst installations pretty easy. you can get these at medical suppy outlets , micro mark tools & sometimes flea markets
Old May 22, 2004, 01:28 AM
Dano13 is offline
Cub Fanatic
Dano13's Avatar
Joined Feb 2004
I agree, but have seen too many folks over aggressive with the hemostats and actually making punctures or splits in the fuel line. That is why I suggested a 4 screw removal of being able to shift the cowling to get at the inlet fuel line without special tools.
Even with hemostats, you need to be able to reach in, disconnect the feed line (without cutting or punturing), HOLD it in a position to allow a fueling (filling) hook-up, then re-connect to engine when done. Why bother with that when I can do the above? The prop and cowling don't have to be completely removed, the cowling only shifted to one side or the other to allow getting at (by hand) the fuel inlet line. You might be suprised at how fast I can remove and re-install 4 #6 screws!
Just my .02...no harm, no foul intended...
dano
Old May 22, 2004, 11:46 PM
ETIGER05 is offline
Joined May 2004
hemostats
Unless you are truely ham hamhanded I have rarely had a problem tearing or cutting line with these things.whole idea is to remove the line not squash it& there are serationed catches on the finger end you can preset . It does take some time to remove the prop, screws(which wear holes a little more each time and seem to get lost in the grass!) wrestle the cowl off (scale plane ) just to refuel each time esp if you fly a lot each time out --Noooooooooooo THANK YOU!
I have seen people create home made refuelers with piece of 1/8 hard plywood & two sections of brass tubing. works pretty well.
Old May 23, 2004, 10:22 AM
God is good
Banjul
Joined Jan 2001
I dunno about all youse guys!!! Sounds like a whole lotta work to fill your tank!!!
I know the K.I.S.S. syndrome, but this filler works very well, and you can forget about rempoving the cowl, or fiddling with the ol' hemostats.
Try this filler - Sullivan
Instead of spending 20-30 minutes fueling, you can spend it flying.
Viper
Old May 23, 2004, 11:35 PM
ETIGER05 is offline
Joined May 2004
filling & hemostats
well, I guess when you get a scale airplane, you'll understand ."fooling " with the hemostats is not a big deal . they are , as far as Im concerned ,indispensable & very handy when working around models. I have seen SOME of these units leak after a while & it does give you two more places for air to leak into the system. LOL with the remote needle valve. usually these things are not set up very well by the designers as far as entry piont alignment for the fuel lines. The KISS principle has a lot going for it you bet.
Old May 24, 2004, 11:36 AM
God is good
Banjul
Joined Jan 2001
I've used the Sullivan for two seasons now, on three planes (all cowled), without a single leak.
I'm fully aware of the many other products that DO leak, but this one is a winner!!!
VP
Old May 24, 2004, 04:03 PM
voodoo28 is offline
Find More Posts by voodoo28
"Foamin at the mouth"
voodoo28's Avatar
Cooper City, Fl
Joined Jun 2003
why not just use a fuel dot?...much easier to deal with..and cheaper.
voodoo28 is offline Find More Posts by voodoo28
Question fuel filler valve stevenc Motorcycles 4 Mar 22, 2007 04:40 PM
Sold BVM trigger valve, JC fuel filters, valve seattle_helo Aircraft - Fuel - Jets (FS/W) 4 Sep 04, 2006 03:03 AM
For Sale Conley Glow Fuel Check Valve rino Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 05, 2006 04:05 AM
