Old May 19, 2004, 06:27 PM
Rod Carson is offline
Find More Posts by Rod Carson
West Chester, PA
Joined Jan 2004
GWS j-3 Cub build question...
I have almost completed my cub. I am very pleased with it. I do, however, have a question regarding the linkage (wire) from the servo's to the contol arms. I find that the distance from one to the other is great enough to cause significant "flexing/bowing" when given TX commands. Is this normal? If not, what suggestions can you offer to remedy this?
Rod
Rod Carson is offline Find More Posts by Rod Carson
Old May 19, 2004, 08:18 PM
bobbygee is offline
Find More Posts by bobbygee
bobbygee's Avatar
Round Rock, Texas
Joined Feb 2004
Rod
1.- Check to see that the rods aren't rubbing against something along their length.
2.- You may have too much throw in the control setup, so that it's maxing out the control surface movement while there's still movement left in the servo.
3.- If not 1 or 2, try a thicker ( stiffer ) control rod.
BobbyG
bobbygee is offline Find More Posts by bobbygee
Old May 20, 2004, 11:05 AM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
or support the control rod in the middle somewhere with a coffee stir. That size of pushrod that comes with the kit bows pretty easy but it's past the point of too much throw usually. I've got 5 yrs. experience but I'm building the same plane
cadconversions is offline Find More Posts by cadconversions
Old May 20, 2004, 11:49 AM
West Chester, PA
Joined Jan 2004
cadconversion-
Tell me a little more about a support in the middle....My only challenge is that the plane is now completed. Thus, making access to the control wires (where they cross especially) challenging at best...
Thanks gents-
Old May 20, 2004, 05:20 PM
Around the World
Scottsville, KY
Joined Jun 2002
Rod, I really wouldn't worry about them. The flex was noticeable in my pico FD but it didn't hurt the flight at all. I suspect the same for the cub.
Park Zone J-3 Cub Prop question Snow Bird PA-FL Parkflyers 1 Oct 14, 2004 08:36 PM
GWS J-3 Cub NIB space ghost Aircraft - Electric - Airplanes (FS/W) 8 Oct 13, 2004 05:29 PM
GWS J-3 Cub motor pgjoh1 Electric Plane Talk 2 Feb 23, 2003 02:02 PM
How does the GWS J-3 Cub(fuse version) fly compared to the Tiger Moth? mefly2 Parkflyers 7 Jun 07, 2002 12:04 PM
GWS J-3 Cub building tips RookieOne Parkflyers 3 May 08, 2002 08:55 AM
