Old May 19, 2004, 05:58 PM
artmonster is offline
Find More Posts by artmonster
R U killing the kittens?
artmonster's Avatar
Chaos, UC
Joined Jun 2003
Building from 3-views?
Any good places to go to learn techniques on building from 3-views.
to tell you the truth.....Im a bit stumped on how to start.
I'd like to build foam slopers from 3-views.....but I just stare at them and wonder what to do next.
any tips and/or techniques pages for people wanting to learn how???
...now I feel a bit dumb.....
artmonster is offline Find More Posts by artmonster
Old May 19, 2004, 06:18 PM
Brian Koester is offline
Find More Posts by Brian Koester
Blue Stick's Dad
Brian Koester's Avatar
Westchester, Ca
Joined May 2003
I use 3 views from the Internet. I bring them into an illustration program or a page layout program and draw a new line overtop of the 3 view that I've imported. Now is an excellent time to start thinking about things that help later. Like if you can import in the root wing profile, you can build it right into your drawing and when you cut it out of foam it'll fit like a glove. Also you can make sure that the decalage is at 0-0. Be sure to use thin lines because when you blow up the drawing the lines get thicker too. Then print out your drawing and take it to Kinkos or some place that has a large format xerox machine. Kinkos has on that goes 36" or so wide by whatever long. Set it to whatever enlargement you want and presto—full size plans. Mount those on a piece of 1/4 hardboard and cut it out and you now have a template for a bandsaw.
Brian Koester is offline Find More Posts by Brian Koester
Old May 19, 2004, 06:23 PM
slopeiron is online now
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
The best way I've found is to blow up the side and top views at Kinko's and trace them onto a chunk of urethane foam. There is a little more info in this thread:
http://www.rcgroups.com/forums/showthread.php?t=222175
Hack off the big pieces with a handsaw and shape what's left down to your marks. After that, it's just a matter of beveling down the corners evenly, then finally rounding off the corners. Glass, fill, sand smooth then paint with scratch filler primer, wetsand and you've got your plug. How's that for a super condensed course on plug building.
Russ.
slopeiron is online now Find More Posts by slopeiron
Old May 19, 2004, 06:29 PM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
BTW, you can also take a look at my website, here:
http://www.ferminslopeships.com/slop...plug/plug.html
I fully documented the building of my 109 plug. It was built from Dave Platt's plans, but maybe there will be something helpful there. Be sure to check the links under the 'Plug Details' section. It got to be too much material, so I divided it up into subsections.
Russ.
Old May 19, 2004, 06:37 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Russ.
Lotta work there. Looks like a rewarding project though. One possible soruce for plans might be peanut scale plans? Not sure, but it seems like you might be able to enlarge them to the size you want to build a plug like you have done on your site Russ? I only mention peanut scale (free flight rubber powered models) because there are some plans online you can download free...and free is good.
InTheLift is offline Find More Posts by InTheLift
Old May 19, 2004, 08:51 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
By "foam" I am going to take it that you mean EPP, right?
My very first scratchbuild project, the Waco CG-4A, was exactly as you describe. Going from 3-views is a great plan and a LOT of fun. You have a couple of options, with Brian Koester's being a great suggestion (re-tracing the 3-view lines in a vector drawing program so that they can be zoomed up to scale). Russ's option works well too, but it ends up making your lines really thick because they'll be zoomed up from tiny size. That can make your work less accurate if you're not careful. I'd like to expand on that, if I a may...
1) First off, decide what size wingspan you want to build your model at. This can be dictated by a number of factors including what size radio gear you have on hand (or are willing to purchase), how big your car is, etc.
2) After deciding the wingspan, take into account that most PSS subjects benefit from the slight elongation of their wingspans, and sometimes parts of their fuselages, in order to make them better gliders. This means that you'll actually want to model your subject at a smaller scale than a direct downscaling of the fullsize plane would dictate, and then scale the wings (and perhaps fuse length) UP to accomodate your desired wingspan.
Example:
The fullsize P-51D Mustang has a ~37ft. wing and a ~32ft. fuselage.
In 1/10 scale, that would produce a model with a 44.4" (37ft./10 = 3.7ft. x 12in. to a foot = 44.4") wing and a 38.4" (32ft./10 = 3.2ft. x 12in. to a foot = 38.4") fuse.
However, to make this a better glider, maybe you want to scale up the wingspan of your 1/10 scale glider to 48" and the fuse length to 40" (for example). If you look at the dimensions of most commercially available warbird-style PSSers, you'll see they almost all do this to some degree or another.
3) Once you've got the above figured out, go to your 3-view and, using a drawing program as Brian K. described, scale up your drawing so that it can be printed out at full size. Mainly you are only concerned about the side and top views of the fuselage here, the wing will be whatever you end up deciding in terms of wingspan and taper (most PSS warbirds have pretty simple single tapered wings)
4) Print out your drawings in sections using your home printer. Cut out these drawings, tape them together, and then pin them on top of a hunk of EPP.
5) Cut out the side and top profiles using a hand saw, bandsaw (preferred) or whatever, then shape to your heart's content.
6) Get some wing cores cut, buy some balsa, basswood and hardware, and you've got yourself a kit. Have at it!!!
See, that wasn't so bad, was it? It's easy, fun, and super pleasureable. Enjoy!
Steve
surfimp is offline Find More Posts by surfimp
Old May 19, 2004, 09:47 PM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
Yikes. My bad. I just quickly skimmed over the original post and missed the part about artmonster wanting to build "foam" slopers from 3-views.
Russ.
Old May 19, 2004, 09:53 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
But your advice, with the exception of the glassing part, is the same thing as I wrote, I just spelled out the details a bit more
Steve
Old May 19, 2004, 09:57 PM
hellcatman is offline
Find More Posts by hellcatman
hellcatman's Avatar
So. California
Joined Jan 2004
Steve has the right idea. A very good program to do the drawing in is ModelCAD. It's a 2D cad program that sells for about $55.00 and you can download it. That is exactly how I built the Challenge ME 109. The amount of detail that you can get is only limited by how much time you put into it. Attacted is a jpg of the ME 109 drawings I did from tracing around a 3 view I downloaded for free.
Rich
hellcatman is offline Find More Posts by hellcatman
Old May 19, 2004, 11:06 PM
artmonster's Avatar
Chaos, UC
Joined Jun 2003
Sweet....You guys rock.
I do have a lot of design software...Im a design junky......as I have my own graphic/print/web business here in Colorado.
Check out ArtMonster Design Arts if youre intersted at all.
I have design Cad 3D MaX ...but I am a lot better at throwing things together in Illustrator....just much more familiar....but working in Cad more as its more geared toward accuracy.
I just didnt know where to start in the process of taking a three view and turning it into a fuse/wing combo.....
And yes...EPP is my material of choice here in the Mtns...Our LZ's are pretty chunky/rocky....EPP is pretty much my insurance for a multiple flights I want to get into glass ships, but I dont think they would survive as long where I fly...or actually land....We fly crunchy thermal ships....but stop breathing during our approaches...hehe
Anyway....thanks for pointing me in the right direction.....I cant thank everyone enough here in the forums for info...its priceless.....I love how you can just throw a question out in the air, and you get responses that help you on your way....
I have a lot of three views.....I just need to S*** or get off the pot...and start my first scratch built warbird......just need to choose which one.
My dad flew A-4's in VietNam......that would be cool...but Im a little weary about flying delta wing slope ships........I always loved the WWII HellDiver.....what a mean machine.......*whirr......*bzzzzz........"must make decision".......
Old May 19, 2004, 11:31 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Illustrator will be perfect. Just open up your 3-view, trace the outline of the side and top profiles with your pen, ditch the 3-view, rescale your canvas and paths to whatever size you need, stroke 'em (the paths!!), print and you're in "bidness"
Steve
Old May 19, 2004, 11:38 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Oh, and as for first-time projects...remember to choose something with a decent glider-like planform. The AT-6 is not a good choice, in other words; how will you ever get enough lead in the short little nose to balance it? (Ask TAWG all about this LOL)
Straight-winged jets can often be good, especially the early ones or the more modern trainers from various international locales. The F-14/F-15/F-18s seem like they're tough to get flying nice, from what I've read (at least if you want them to remain even reasonably scale). More sailplane-like planforms (i.e. WARBIRDS) generally seem to have the most satisfying performance, from what I've read.
Of course, you could always do a real combat glider...CG-4A, Horsa, Hotspur, Hamilcar, DFS-230, Me-321 Gigant...they need little/no modification to fly well! I should know, I've built two off that list...so far
Steve
Old May 20, 2004, 02:25 AM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
Avoid delta wings. VERY difficult to cut them without the tip area over burning the foam and deforming the airfoil. Plus I've never seen one fly better than just floating along
Old May 20, 2004, 02:56 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
here's a link to nearly all the 3views you will ever need
http://www.dfrc.nasa.gov/Gallery/Graphics/index.html
steve wenban is online now Find More Posts by steve wenban
Old May 20, 2004, 07:43 AM
jcarstan is offline
Find More Posts by jcarstan
Dunetop Flyer
jcarstan's Avatar
Cape Cod, Mass., USA
Joined Dec 2002
Excellent topic. When I shaped my Do-335 fuselage I was fortunate to have the cross section templates for various fuselage points. If the 3 views don't show the cross sections, how do you make templates to shape the fuselage to make the airplane look like the original?
Jan
jcarstan is offline Find More Posts by jcarstan
Question New plans/planes from 3 views? WarrrEagle! Foamies (Kits) 23 Nov 02, 2007 08:36 PM
Discussion 16% semi-scale F18 Hornet(255% size)from 3-views 8kasl Pusher Prop Jet Models 33 Jun 21, 2006 09:38 PM
Discussion Looking for Info on Building Model from 3-Views easug The Builders Workshop 10 Feb 26, 2006 09:41 AM
Building a Tupolev ANT-4 from 3-views Martin Hunter Scale Kit/Scratch Built 14 Feb 09, 2005 08:42 AM
3-views from Dryden jhopkins Scale Kit/Scratch Built 1 Jan 21, 2002 06:09 PM
