Old May 19, 2004, 09:28 AM
Rajesh L G is offline
Find More Posts by Rajesh L G
Bangalore, India
Joined Nov 2003
prop rpm vs thrust chart
I am looking for prop rpm vs thrust chart for GWS props. Couldn't find this anywhere on the net. Please direct me if you know some place where this is available.
-- Rajesh
Rajesh L G is offline Find More Posts by Rajesh L G
Old May 19, 2004, 09:33 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Thrust is not a constant, static value (unless you're building a helicopter, or a model design pretty much just to hover)..
It varies significantly with airspeed..
www.motocalc.com
..a
Old May 19, 2004, 09:53 AM
Bangalore, India
Joined Nov 2003
Andy,
I know it changes with airspeed, I am looking for static thrust figures. Need it for my experiments, static thrust gives me an idea how well I am doing. The problem is I have built a tach, but don't have a thrust measurement setup yet.
I have checked the motocalc site, didn't see this information there. Is it possible to get this table from motocalc ?
-- Rajesh
Old May 19, 2004, 02:25 PM
mgdon is offline
Find More Posts by mgdon
United States, NC, Belmont
Joined Mar 2004
Static thrust calculator
Here's a great staic thrust calculator for electric props with links to calculators for many but not all APC and GWS props:
http://members.jcom.home.ne.jp/42232...aticthrust.htm
It's from a German Club and appears to be fairly accurate.
Don't worry about the electric part of the calculation-doesn't seem to make much difference for just thrust calculations.
mgdon is offline Find More Posts by mgdon
Old May 19, 2004, 02:27 PM
mgdon is offline
Joined Mar 2004
P.S.-in the "U min"you put the rpm
Old May 19, 2004, 11:18 PM
Bangalore, India
Joined Nov 2003
Thanks for the link, Don. I had seen this link earlier, but its prop choices stops just above the sizes I am interested in. I am looking for props from 2.5x0.8 to 6x3. I tried the generic calculator, but the figures for the same dia and pitch differs significantly from that given by the GWS calculator. So I believe the results for smaller sizes would not be accurate either.
Old May 20, 2004, 09:40 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
I don't know whether this will help you, but it's a simple spreadsheet which I stripped off a much larger version which I use for motor and propeller analysis.
It would be relatively simple to expand it to create graphs of Thrust vs RPM for most props.
You will need to know the motor constants Io, Ra and kV.
If you are interested only in power, RPM or thrust output, the spreadsheet may still be used by putting in any motor constants and adjusting the voltage until you achieve the RPM or whatever variable that you require.
A couple of caveats.
The sheet was not written in Excel, but is Excel compatible and for this reason I haven't protected the fields.
The fields with formulas should be protected.
There are 2 hidden rows which store the results of an intermediate quadratic equation. They should not be removed.
The spreadsheet was originally written for nicads. It may be used for lipoly cells by either modifying the sheet or by noting that the nominal voltage for lipolys is 3.6 Volts or 3 times that of a nicad. The cell resistance for lipolys is higher as well.
All propellers are not created equal. Propellers of the same dimensions from different manufacturers can have different areas and therefore different thrust and drags.
This doesn't mean that one propeller is more efficient than the other but these differences should be compensated for. The easiest way is by changing the pitch slightly.
The spreadsheet is based on power and thrust formulas published years ago. These equations were known as the Abbott equations.
Power (WATTS)=P(in.) X D(in.)^4 X RPM^3 X 5.33 X 10^-15
Thrust (oz.)=P(in.) X D(in.)^3 X RPM^2 X 10^-10
The constants in these equations may be modified to suit the brand of propeller that you are using.
Although I have found them to be reasonably accurate, the thrust equation does not take into account the thrust from a stalled propeller.
Props with pitch/diameter ratios greater than 0.6 are statically stalled and the thrust measurement given by this program would be slightly higher than reality for these props (as are many other programs), if not compensated for. The power measurement, however, is reasonably accurate.
The measured static thrust in these instances would approximate that of a propeller of the same diameter with a max pitch of 0.6 the diameter. This could be implemented in the spreadsheet.
That being said, I have found the spreadsheet extremely useful for comparison purposes or for determining if you are going to burn out your motor from excessive current.
The term Eg used in the spreadsheet is the voltage generated by the back EMF of the armature. It gives an indication as to how much of the applied voltage is doing useful work. All other fields are self explanatory.
Perhaps someone proficient at Excel could clean it up a bit.
The file is not actually a .zip file but an Excel .xls file.
After downloading, rename the file propeller.xls.
EDIT: I have uploaded a cleaned up version in which all the input variables are placed on one line. All formulas remain the same except for the thrust field which compensates for propellers with pitch/diameter ratios greater than 0.6.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old May 23, 2004, 01:21 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Included in the attached zip archive is an Excel spreadsheet with all my measurements for GWS props, and a thrust calculator. To calculate thrust at another rpm, enter your rpm along with the prop's diameter, pitch, and tconst from the measurements section.
If you have a prop that is not listed, you can try guessing its tconst by comparing to a similar prop that I have tested. In general, slowfly props have higher tconst than hyperdrive, and a higher pitch/diameter ratio also increases pconst (up to a point, then it decreases as the prop stalls).
Note that my tconst is NOT the same as Motocalc's tconst (which is calculated from power, not rpm!).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 24, 2004, 07:46 AM
Bangalore, India
Joined Nov 2003
Thank you, Bruce, that was the data I was looking for. The spreadsheet is quite useful to get approximate results once one measurement data is available to determine the constant. The problem is constant varies a lot from prop to prop, so atleast one measurement has to be made before the equation can be used.
Martyn,
Could you explain the statement "Props with pitch/diameter ratios greater than 0.6 are statically stalled" ?
-- Rajesh
Old May 24, 2004, 07:59 AM
Toronto Canada
Joined Dec 2002
The pitch angle of a propeller blade (in degrees), varies along the length of the blade. The angle is greatest at the root and decreases linearly towards the tip.
It is for this reason that its pitch is specified in inches and not degrees.
Most airfoils with these aspect ratios stall at pitch angles from 12 to 17 degrees (depending how it is measured).
Therefore a propeller with a majority of its pitch greater than 17 degrees is fully stalled and creates little thrust, but lots of drag.
It can be demonstrated mathematically that the pitch of a propeller blade with a pitch/diameter ratio=0.6 has a pitch angle at its tips of approximately 11 degrees.
This means that the angle of the blade as you approach its root is greater than 11 degrees and is proportional to the distance from the tip.
Half way down the blade the pitch would be 22 degrees and stalled.
This also means that you can trim the tips from a propeller to reduce its diameter but stilll maintain its pitch (in inches).
The majority of thrust from a propeller comes from the outer portion of the blade because thrust is proportional to the diameter to the third power.
If the pitch angle at the tip is 11 degrees, the majority of the blade is at a pitch angle greater than 11 degrees and is becoming stalled.
As the aircraft increases its speed through the air from rest, the angle of attack of the propeller will decrease and the blade will become unstalled. This is why real aircraft have variable pitch propellers, so they can have efficient thrust at low speeds and still achieve high airspeeds by increasing the pitch.
For pitch/diameter ratios less than 0.6, the portions of the blade which generate most of the thrust are unstalled.
Most formulas for thrust do not take into account this non-linear characteristic of propellers and any thrust measurements made statically do not accurately represent the true performance of a propeller if its pitch/diameter ratio is greater than 0.6.
Old May 28, 2004, 10:49 PM
nolasco is offline
Find More Posts by nolasco
nolasco's Avatar
New York, NY
Joined Dec 2000
Can someone do me a favor? I do not have Excel at home and therefore cannot check out my RPM vs. Thrust numbers. But using the site given by MGDON, I am getting some pretty wild numbers for the following RPM figures using GWS props:
5x3 at 15000RPM is calculated as 7+ oz thrust
6x3 at 12400RPM is calculated as 10+ oz thrust
8x4.3 at 6600RPM is calculated as 9+ oz thrust
The thrust numbers look just too good to be true. But if the actual thrust is within 75-80% of calculated figures, I am about to be a very happy person.
Jun Nolasco
nolasco is offline Find More Posts by nolasco
Old May 28, 2004, 11:06 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Hi Jun - I can't give you exact data for those rpm numbers, but they are not too far away from reality.
I have measured on my test stand:
5x3 GWS HD: 14280 rpm = 5.85oz, 18990 rpm = 10.00oz
6x3 GWS HD: 12720 rpm = 7.92oz
6x3 Cox: 11980 rpm = 9.01oz
8x4.3 GWS RS: 6750rpm = 9.72oz
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 29, 2004, 12:36 AM
nolasco is offline
nolasco's Avatar
New York, NY
Joined Dec 2000
Thank's Phil!!! Now I am really going to be a very very happy camper once I get my custom-built motors.
Jun Nolasco
Old May 30, 2004, 12:38 AM
mgdon is offline
Joined Mar 2004
Nolasko,
If you go to Bruce Abbots reply (no.8 above), he has Text prop thrust included along with the excel one.
You don't need excel to open it.
Some examples from his chart:
If you open it remember the thrust figures are in grams so you have to divide them by 28.3 to get ounces.
5/3-10,200= 97.9 grams of thrust= +- 3.46 oz.thrust (he doesn't go higher for 5/3's
6/3-9500= 155 grams= +- 5.48 oz.
8/6 ( he doesn't include 8/43) @ 6100= 11.3 oz.
I agree with you that the website I mentioned is a bit optimistic or we're not reading it correctly.
I believe Bruce Abbotts chart is much more accurate.
Old Feb 13, 2012, 04:28 AM
dbacon is offline
Find More Posts by dbacon
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Just visited this forum and I wanted to say thank you for all the info. I am building small foamies now of 28 ounces down to 1.5 ounces, and I think your work will be helpful.
This should be a sticky thread, too valuable to not be!
dbacon is offline Find More Posts by dbacon
Question Prop speed vs. Thrust for GWS Warbirds rc_ron Parkflyers 47 Aug 20, 2004 08:07 PM
MM Dandy RPM vs Thrust ZRS4 Parkflyers 11 Feb 29, 2004 11:06 PM
GWS RPM vs Static Thrust???? ZRS4 Power Systems 4 Feb 29, 2004 12:16 AM
prop speed vs. thrust mikekosatka Power Systems 17 Jan 04, 2003 06:57 PM
prop rpm vs. static thrust/pitch speed opualuan Power Systems 2 Feb 19, 2002 07:48 AM
