Old Sep 06, 2001, 11:31 AM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Rittinger ME-262 (again!)
Well, all those lovely posts were sent off to data heaven, so I thought I would start the thread up again.
I am nearly ready to glass. Finally installed the three nylon wing bolts lastnight and cut the canopy to shape. Here is a pic of its current status.
I have a couple more pics here:
http://albums.photopoint.com/j/Album...253&a=13726048
Slope Nut is offline Find More Posts by Slope Nut
Old Sep 06, 2001, 11:42 PM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Glassed one side of the wing, tail feathers, and bottom of the fuse. The nacelles are all glassed up. Tomorrow nite....glasing of the top wing, other side of the tail feathers, and the top of the fuse. Nearly ready to primer!
Greg
Old Sep 07, 2001, 01:07 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Stop pushing me. Everytime I see something about this thing I am tempted to build it!
Looking good.!
How much carving in this one compared to the Sportwin?
Kirby
kepople is offline Find More Posts by kepople
Old Sep 07, 2001, 01:27 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
The only real carving on this thing is the nose block (took two minutes) and the front and rear blocks for the nacelles. If you have a sanding block with 60 grit or a dremmel it takes about two minutes to shape them, then hit them with the 220 fine grit and finish them off!
Greg
Old Sep 07, 2001, 01:40 AM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Jeez, you are really turning into a building machine. Looking good!
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Sep 07, 2001, 05:16 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
Geez Greg, I want to come down and rub you to see if some of the modelling magic rubs off!! The 262 looks great!
Dave
dottney is offline Find More Posts by dottney
Old Sep 07, 2001, 08:07 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Keep 'em coming. Can't wait to see it painted!!!!
J Morgan is offline Find More Posts by J Morgan
Old Sep 08, 2001, 02:13 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Just finished putting glass on the other sides of the parts. Tomorrow its the wipe down layer of epoxy, then on to primer sunday. Should be painted by mid-week.
Greg
Old Sep 10, 2001, 07:38 PM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Finished sanding off the primer from the fuse and most of the wing. Have to do the tail feathers and the nacelles. Should be ready for paint this weekend!
Greg
Old Sep 12, 2001, 11:02 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Here is the current status of the ME-262 (almost ready for paint)
Old Sep 26, 2001, 10:23 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
ME-262 is painted! I am going to put on the panel lines and dull cote the entire airframe in the next couple of days, then hopefully fly it in a week or so (soccer kids infest every field suitable for flying this thing )
Old Sep 26, 2001, 11:46 AM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Wow, man, your gettin good at this scratch building thing! Told you it was easy....
LOOKS FANTASTIC!!!!
mrittinger is offline Find More Posts by mrittinger
Old Sep 26, 2001, 04:52 PM
kepople is offline
kepople's Avatar
Joined Jun 2001
Hey Slope...Beautiful!
Question: I am building a K&A A-10 and am about to cover it. I wonder what the advantage of glassing versus using covering?
Is Glass Lighter? Is it More Durable?
Last one:
Could you desribe how you glassed your plane?
I have used heavy fliberglass to build a boat, but nothing this light. The A-10 needs to be as light as possible.
Thanks for the help.
Kirby
Old Sep 26, 2001, 05:07 PM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Hey Kirby,
Check Jim Ryan's website out under DOWNLOADS. I use his method for glassing all my planes (home.fuse.net/ryan). It is more durable than covering, and because its attached with epoxy, it never bubbles, shrinks, or comes loose (unless something terrible happens ). The big benefit for me is there are no seams, and it paints great! Plus, its a permanent finish that will never need replaceing. You may need to touch up areas after a season or two, but not have to pull all the covering off and re-apply it.
I do not think you want to glass the A-10 wing. I built one, and it needs to be exceptionally light. I would prefer to cover the wing with shirnk covering, and then glass the fuse, because it has lots of plastic on the top deck. It will be easier to get a matching finish if you glass the fuse and then paint it (rather than paint the plastic and then film cover the lower fuse sections). You may want to get some lite cloth and try glassing an old plane, or a piece of balsa to see how it works.
Greg
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
I just want to say what an honor it is to have people building my designs
Mark
Discussion ME-262 flies in Germany again sblack Electric Ducted Fan Jet Talk 3 Apr 27, 2006 08:01 PM
Discussion Me-262 rides again! nauga Slope 1 Dec 29, 2005 09:58 AM
ME-262...again! InTheLift Slope 29 Jul 07, 2005 11:33 PM
42" ME 262 (Mark Rittinger design) Tumbler Electric Ducted Fan Jet Talk 17 Jun 22, 2005 12:11 PM
Building my S400 Me 262 (designed by M. Rittinger) jfrabat Pusher Prop Jet Models 134 Mar 30, 2005 11:37 PM
