Old May 18, 2004, 08:09 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Where to buy thin EPP sheets? (2, 3 & 4 mm)
Looking for blade cut 2, 3 * 4 mm blade cut EPP sheets 1.0 lb so I can make up some of these fun new designs, but this stuff does not seem to be available locally.
These guys have 1.3 lb sheet in 3 and 4mm but would ideally like the 1 lb that is getting called out.
http://www.flyingfoam.com/foamsheet.html
Also, I've lost my links for the small carbon fiber supplies. Like the 1mm stuff.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old May 18, 2004, 08:16 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
Hey Wayne--
I've gotten into flying these little things-- got a Shock Flyer to start-- but now want to build my own. Have some depron coming-- would like to get together with you and compare notes---
Tim
timmig is offline Find More Posts by timmig
Old May 18, 2004, 08:28 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Sounds good to me.. As I recall you live out here near me...? Lake Forest.
I've built up a proto-type CD rom motor conversion to play with. Thinking of building up one of the 19-20" wing span 3D trainers. Build some of the bigger once I build up a more powerful motor.
-Wayne
Site Sponsor
Old May 18, 2004, 08:41 PM
skyhiflyhigh is offline
Find More Posts by skyhiflyhigh
los angeles
Joined Mar 2004
sloper steve has the 1# epp but still hasn't figured out how to machine slice it, hippo dan is supposed to have 3mm in rolls or fanfold or something but the shipping is high to so cal so he's suggesting people gang up an order
skyhiflyhigh is offline Find More Posts by skyhiflyhigh
Old May 18, 2004, 09:42 PM
pappatop is offline
Find More Posts by pappatop
pappatop's Avatar
The Woodlands, Tx
Joined Nov 2003
They're all linked from my homepage:
http://pappatop.devnul.org/
pappatop is offline Find More Posts by pappatop
Old May 18, 2004, 10:48 PM
los angeles
Joined Mar 2004
been on your site before and just looked again and can't find the link. u do have some good contruction techniques but couldn't figure out how the 20# mono on the spars help. is the 18# tyvek better or thicker than the priorty envelopes and should u line the whole inside of the fuse with it or some tyvek some strapping tape
Old May 18, 2004, 11:39 PM
JONBOYLEMON is online now
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Carbon sources
http://www.nyblimp.com/
http://ecom.citystar.com/hang-em-hig...ARS+%2d+Carbon
http://www.homefly.com/products.asp?id=8
I just ordered some carbon rods from David @ homefly and the shipping was lightning quick. The post office ripped the shipping tube in half but the rods were undamaged. Dave was great to deal with, I screwed up my original order but he changed it for me after I emailed him. This was over a weekend. Great service.
JONBOYLEMON is online now Find More Posts by JONBOYLEMON
Old May 19, 2004, 04:51 AM
pappatop is offline
pappatop's Avatar
The Woodlands, Tx
Joined Nov 2003
Foam Sheets:
http://www.flyingfoam.com/ (site seems down. talk to Bob Melon bob@flyingfoam.com )
or
http://www.edgerc.com/
The 20# monofilament and Tyvek add ridgidity and strength to the wing spar.
The Tyvek is almost the same thickness as the envelopes and goes on the exterior ONLY of the fuselage. Henkel Brand "Clear Duck Tape" reinforces the EPP Fuse halves on the inside, and 3/8" wide strapping tape reinforces the "backbone" of the fuse.
I can't post a Screenshot of the plans which detail the preparation and Tyvek application on the fuse, their too big. The pictures loose their legability when shrunk. PM me with your e-mail if you want a copy.
The weight of the two fuse halves combined is 1.4 oz.
Cheapest Carbon Rod:
http://www.goodwindskites.com/merch/...?cat=framework
Old May 19, 2004, 12:43 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Originally Posted by pappatop
Foam Sheets:
or
Thanks for the links!!
Both of the sites above seem to be sourcing the same material in 1.3#. No sources for the 1#? Anyone? or am i wasting time trying to track something down that is only available in Japan?
Thanks!
-Wayne
Site Sponsor
Old May 19, 2004, 12:59 PM
3d_Crazy is offline
Find More Posts by 3d_Crazy
3d_Crazy's Avatar
Fort Worth, TX
Joined Nov 2003
I've found some #1.0 density EPP Foam, but they don't already come sliced.
Good Luck!
3d_Crazy is offline Find More Posts by 3d_Crazy
Old May 19, 2004, 01:49 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
OK, maybe I missed somthing.. Is there a way to slice our own?
-Wayne
Site Sponsor
Old May 19, 2004, 02:51 PM
pappatop is offline
pappatop's Avatar
The Woodlands, Tx
Joined Nov 2003
Yeah, hotwire. But it aint fun!
Old May 19, 2004, 03:25 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Hot wire on 1# EPP would defeat the purpose of 1#. I'd be better off with the 1.3 sliced in terms of weight. Right?
-Wayne
Site Sponsor
Old May 19, 2004, 05:49 PM
pappatop is offline
pappatop's Avatar
The Woodlands, Tx
Joined Nov 2003
You could build a wire slicer which would work similar to a band saw, just uses braided steel wire for the "saw" blade. I've considered doing it but really don't have the room at home for it!
Old May 19, 2004, 08:02 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Yeah.. No space here either.. Already have a drill press in my kitchen.
-Wayne
Site Sponsor
Where can i get thin epp sheets in the UK zagi-man Scratchbuilt Indoor and Micro Models 8 Mar 17, 2005 04:18 AM
I can do thin EPP sheets DrDHalko Foamies (Kits) 7 Jan 14, 2004 01:33 AM
Need motor GB, 3oz thrust, 1/2 to 3/4 oz aireze Scratchbuilt Indoor and Micro Models 2 Jul 04, 2003 02:47 AM
berg 6 channel 1,2,3,4,5,6 Kevin Graehl Radios 2 Jul 07, 2002 08:13 AM
